Table of Contents
Shopping for Christmas gifts for the camping enthusiasts in your life? There’s no better choice than practical, high-quality, on-the-go power gear from EcoFlow.
Each of our products is designed to meet the unique needs of different types of campers. Whether for the beginner camper embarking on their first adventure or the seasoned RV camper who values reliability and efficiency, this guide will help you choose the perfect gift to be cherished and used for many upcoming camping trips.
EcoFlow’s 4 Best Christmas Gifts for Campers in 2023
- Best for Beginner Campers: EcoFlow RIVER 2 Solar Generator (PV110W)
- Best for Traditional RV Campers: EcoFlow Power Kits
- Best for Stealth Campers: EcoFlow RIVER 2 Pro Solar Generator (PV220W)
- Best for Boondocking: EcoFlow DELTA Pro + Grounding Adapter & 400W Portable Solar Panel
If you’re looking for a good gift for an entry-level camper, the EcoFlow RIVER 2 is a great solar generator option that is ideal for charging personal devices on a camping trip. It gives the camper a little comfort of home when out in nature.
The EcoFlow RIVER 2 is light and portable, making it an excellent choice for outdoor adventurers or hikers who want to take power with them. It can keep your camera powered long enough to take pictures once they reach the peak of their hike or charge up your cell phone.
The EcoFlow RIVER 2 isn’t the most powerful solar generator we offer, but it’s capable of running up to 99% of your consumer electronics, allowing you to charge many of your personal devices.
Specifications
Capacity: 256 Wh
Weight: 7.7 lbs (3.5 kg)
Dimensions: 9.6 x 8.5 x 5.7 in (24.5 x 21.4 x 14.2 cm)
Battery Type: LiFePO4
Battery Life Cycle: 3000 cycles to 80% capacity
Solar Panel Charging Time: 3 hours
Pros
- Quick charging
- Lightweight and easy to carry
- Run up to 99% of consumer electronics
- A reliable LFP battery lasts up to 10 years of use
- Choose between four different charging methods
Cons
- Low storage capacity and power output
If you’re feeling generous this year and your loved one enjoys a version of glamping or going everywhere in their RV, then EcoFlow Power Kits are a compact power solution that can make a lot of things possible.
EcoFlow Power Kits boast a simple setup, so this modular system allows you to get back to adventuring in no time. RVs require an efficient use of space, so the stackable batteries in the EcoFlow Power Kit work well to maximize space. And, when the time comes to recharge, they can choose between four charging methods.
The modular EcoFlow Power Kits allow you to easily customize your setup for your needs, so specs vary based on your chosen system.
Pros
- Customizable
- Maximizes space
- Offers smart controls
Cons
- Expensive
Best for Stealth Campers: EcoFlow R IVER 2 Pro Solar Generator (PV220W)
When you pair our EcoFlow RIVER 2 Pro Portable Power Station with a 220W Bifacial Portable Solar Panel, you get an excellent power source for those who love stealth camping. The EcoFlow RIVER 2 Pro Solar Generator runs a wide range of devices, bringing camping trips to the next level.
The EcoFlow RIVER 2 Pro Solar Generator is a good balance between power and portability, able to power a wide range of devices while still being small and compact enough to carry or pack. When using the EcoFlow 220W Bifacial Portable Solar Panel, the EcoFlow RIVER 2 Pro offers quick charging times. Or, plug it into an AC outlet and go from 0-100% in just 70 minutes, thanks to X-Stream technology.
This portable panel’s high-efficiency rating and unique bifacial design help make the most out of available sunlight.
Specifications
Capacity: 768 Wh
Weight: Approximately 17.2 lbs (7.8 kg)
Dimensions: 10.6 x 10.2 x 8.9 in (27 x 26 x 22.6 cm)
Battery Life Cycle: 80%+ capacity after 3000 cycles
Solar Panel Charging Time: 4.5 hours
Pros
- Powers a wide range of appliances
- Quick recharge
- Light and easy to transport
Cons
- May not meet the power needs of some
Best for Boondocking: EcoFlow DELTA Pro + Grounding Adapter & EcoFlow 400W Portable Solar Panel
For the person in your life who’s often going off the grid, boondocking in one remote location after the next, give them enough power to stay a while and enjoy their adventures with the EcoFlow DELTA Pro + Grounding Adapter & EcoFlow 400W Portable Solar Panel.
This combination is perfect for keeping all essentials powered up while boondocking, whether in spring or winter weather, without the unwelcome additions of noise or fumes that come along with traditional generators.
They’ll enjoy fast charging speeds anywhere and any time and be able to enjoy power for their essential devices.
EcoFlow DELTA Pro Specifications
Capacity: 3600Wh
Weight: Approx. 99lbs/45kg
Dimensions: EcoFlow DELTA Pro – 25 x 11.2 x 16.4 in (63.5 x 28.4 x 42cm)
Battery Type: LFP
Cycle Life: 3,500 cycles to 80% capacity, 6,500 cycles to 50% capacity,
Pros
- Power most appliances
- Quiet, non-disruptive to nature
- Quick charging
- Expandable with extra battery
Cons
- Large and expensive
What to Consider When Choosing the Best Christmas Gifts for Campers
Power Needs
Consider the power needs of your loved one when choosing the best Christmas gift for them. Are they a beginner camper who may only need to power small appliances like lights, fans, and phones? Or are they more experienced campers who may require more extensive power sources for their RV or off-grid adventures?
Understanding their specific needs will help you choose the right gift to give them the necessary power. Consider things like capacity, AC output, and more.
Comfort Needs
Consider the comfort needs of your loved one when choosing a gift for them. Some campers may prefer a camping experience more similar to home, while others may embrace a streamlined approach. For those who love the comforts of home, being able to power their coffee maker and similar appliances could make all the difference between a good camping trip and a great one.
Utility Needs
Utility needs are essential for the camper in your life, as they’ll determine which gift will most benefit them. For example, if they love boondocking, a portable solar panel or generator could be the perfect gift.
An EcoFlow Power Kit with all the necessary cords and adapters may be more practical if they prefer traditional RV camping.
Campers typically enjoy practical, durable gifts that enhance their outdoor adventures. These gifts could include camping gear, tools, gadgets, or power solutions. It’s essential to consider the camper’s specific interests and needs when selecting their ideal Christmas gift.
Looking for the Best Christmas Gifts for Campers? Shop EcoFlow!
When choosing the perfect Christmas gift for the outdoor enthusiast in your life, EcoFlow offers a range of practical and high-quality portable power solutions. By shopping and gifting an EcoFlow product, you’re enhancing their camping experience and showing thoughtfulness and care for their comfort and convenience during their outdoor adventures. Browse our selection today!
