spot_img
What Is a Solar Generator?
This article serves as a starting point to get in the know regarding “solar generators”. What is a solar generator? Do they actually work? What do I need to know before I buy one? What can I use them for? Read on and find out…
what is a solar generator featured image
At its most basic level, a solar generator is the combination of a large battery with solar panels. They work by capturing sunlight via your solar panels, storing the energy captured by sunlight into a battery, and then converting that energy into AC power for you to use. They typically come with wall outlets, USB outlets, and even DC outlets too.
While the term isn’t entirely accurate, as they don’t generate power in the way fossil-fuel-powered generators do, the term has stuck. We prefer to go by the term “portable power station”, but for the purposes of this article, we’ll be using “Solar Generator”.
Do solar generators really work?
In short, they work for anything a traditional generator can be used for without the fumes, smell, or high maintenance. While it’s true that a big limitation in the past has been output, with solar generators lacking when it comes to powering heavy-duty devices, this has been remedied in recent years with EcoFlow’s X-Boost technology. More on that later.
The key thing that sets solar generators apart from their archaic counterparts is that you’ll need to charge them rather than give them fuel. If you’re charging with solar panels, you’ll just want ones with an solar panel connector for maximum compatibility, such as EcoFlow’s range of portable solar panels, and of course, sun. You can read more about what kinds of solar panels you might consider here.
That being said, solar isn’t the only way to charge up. Almost all solar-powered generators can charge via wall outlets too, with some supporting a bunch of charging methods. In this way, solar generators are much more flexible than traditional generators. EcoFlow DELTA Pro for example lets you use wall outlets, car outlets, solar panels, Smart Generators, or even EV charging stations. Storing renewable energy is now easier than ever.
delta pro ev charging
What Are the Different Types of Solar Generators
As you can see, there are a lot of things to like about solar generators  – but it’s key to choose the right one. Here, we’ll cover different types to help you pinpoint which option is best for you.
On-Grid Solar Generator
Many people rely on the electricity grid to power their homes. However, during grid outages, the lights go out, and you don’t have a way to power your house. With an on-grid solar generator, you’ll have a source of backup power to rely on during an outage.
With a grid-tied system, you can enjoy the benefits of solar while still being tied to the grid, allowing you to benefit from reduced electricity costs and even net metering in some cases.
Off-Grid Solar Generator
An off-grid solar generator, in contrast, is a standalone generator completely disconnected from the grid. Your solar panels will store excess electricity in a solar battery for use when the sun isn’t actively shining. There are even portable off-grid solar generators suitable for use in various activities, such as camping, RV trips, and more.
Hybrid Solar Generator
Hybrid is used to describe two distinct types of solar generators. The most common definition is a generator that combines electricity production from PV panels with another fuel source – typically fossil or biofuels. Diesel and solar hybrid generators are common in the marketplace. The main advantage of this type of hybrid solar generator is that you have a backup energy source when your PV panels don’t produce enough electricity to meet your needs.
Hybrid can also be used to describe a grid-tied solar power system that also incorporates a solar battery. Unlike with off-grid solar generators, on-grid solar power systems do not require a solar battery. However, adding one to your system provides greater energy security in case of a blackout.
Additionally, if you use net metering to sell excess electricity back to your utility, you won’t be able to do so if there’s a failure in the grid. Without a solar battery, any excess electricity that you produce will go to waste.
5 Benefits of Using a Solar Generator
1. Clean Energy at No Cost
Solar generators allow you to reduce your reliance on the grid and take advantage of free, clean electricity that doesn’t produce greenhouse gases when operating.
Not only is it environmentally friendly, but the electricity also doesn’t cost you anything. Reduce your reliance on fossil fuels and enjoy this supply of free, clean energy for the entire lifespan of your panels – typically about 25 to 30 years
2. Low Maintenance Costs
Solar generators don’t share the moving parts that fuel or gas generators do, and they don’t use liquid fuel. As a result, you’re much less likely to need to worry about the costs associated with repairs.
3. Clean and Quiet when Operating
Who likes the sound of a noisy gas generator? While generators can be convenient, the sound and pollution they generate are a major downside. Solar generators, on the other hand, are both clean and quiet when they run, giving you peace of mind and maintaining a peaceful environment – all the while keeping your essential devices powered.
4. Good Investment
While gas-powered generations can last for multiple decades, they require a variety of maintenance to be done to keep them operating, and you need to continuously buy fuel to use them. In contrast, solar generators may come with a high initial investment, but they provide a reliable source of energy that doesn’t share those same costs and, in fact, can boost the value of your home.
5. Light and Simple
Of course, some higher-capacity solar generators can come in at higher weights. However, they tend to be lighter in general than their gas-powered counterparts, making them easier to deal with.
What should I consider before buying a solar generator?
Okay, so let’s assume you’re on board with the idea of solar generators replacing traditional gas generators, or perhaps as a generator alternative. What factors should you then consider with this new technology?
Capacity: The thousand-watt question
The first and most important factor you’ll want to look at is how big the battery itself is since you won’t be using a tank full of gas to power your appliances. A larger battery usually means more capacity, which is measured in ‘watt-hours’. The more watt-hours, the longer you can power your appliances before needing a recharge. Let’s take two extremes for comparison when it comes to capacity and portability:
EcoFlow RIVER 2
Perhaps the most portable solar generator going, EcoFlow RIVER 2 is the smallest of the EcoFlow RIVER 2 series and comes in at 256 watt-hours. It’s almost like a giant powerbank with AC, DC, and USB outlets to power your devices. It’s great for short trips, camping, or just to throw in your on-the-go bag.
EcoFlow RIVER 2 Max Portable Power Station - EcoFlow RIVER 2 Power Station LiFePO 4 Black
EcoFlow DELTA Pro
EcoFlow DELTA Pro — on the other hand — is the largest deviation from old-school generators. It comes in at 3600Wh and can be expanded all the way to 25,000Wh with extra batteries & smart generators. It can integrate directly with your home circuits via accessories and can power your home for days on end during an emergency. And, you can monitor it all from your phone. That’s a whole lot more functionality than a traditional generator.
EcoFlow DELTA Pro large solar generator in shed
Solar Generators vs Traditional Gas Generators
Advantages
  • Portable: Compared to a traditional gas generator, solar generators are much more portable, making them a good option for emergencies, outdoor events, camping, and more. While those with a larger power capacity can be heavier, some ultra-portable options are available, like the EcoFlow RIVER 2 Solar Generator.
  • Low Maintenance: Without the moving parts that gas generators have, there are fewer chances that your solar generator will require repairs compared to the repairs and maintenance that will likely be required of a gas generator.
  • Charge Anywhere There’s Sunlight: You can use your panels to charge your battery anywhere you can set them up that has adequate sunlight – giving you tons of possibilities. For example, the EcoFlow DELTA Pro Solar Generator (PV400W) from the EcoFlow DELTA Solar Generator selection features a LiFeP04 battery, and it can achieve a full charge in just 3.5 hours with three 400W Portable Solar Panels.
  • Environmentally Friendly: Unlike gas generators, which burn fuel and release emissions, solar generators can create clean energy from sunlight to power your devices, making them significantly better for the environment. You can even opt for a whole-house generator and substantially reduce your carbon footprint.
Disadvantages
  • Higher Upfront Costs: Typically, solar generators come with a higher initial investment. However, the electricity they produce to power your appliances comes from the sun and doesn’t cost anything, which can help you lower electricity costs over time.
  • Require Charging: Solar batteries require charging, typically using energy from the sun, which can sometimes be time-consuming. However, some batteries will support additional forms of charging.
How many watt-hours do I need?
Here, a bit of math comes in handy. Just add up the amount of watts your devices require and multiply that by how many hours you’ll need to use them for. Then, leave yourself a buffer for conversion inefficiencies. Here’s an example:
Let’s say an extended power outage hits and you need to power a fridge for 4 hours. A large fridge can use up to 200W an hour, especially if turn-on cooling is required. In this case, you need a battery with more than 1000Wh (200×4). A good fit here might be the 2000Wh EcoFlow DELTA Max, with 2000Wh you’ll be able to keep your fridge running throughout the blackout, with a spare 1000Wh or so left over to account for any inefficiency. With that leftover energy, you could even use your microwave and charge up your devices, too.
You can browse a bunch of solar generator sizes here, varying from 210Wh–3600Wh.
Output & Outlets: What can you run on a solar generator?
Different solar generators come with different sets of outlets and can run different things. At a minimum, you’ll want AC wall outlets so you can plug in your appliances with ease, as you would at home. However, newer offerings are much more convenient, offering fast-charge USB outlets, DC outlets, and even wireless charging pads. A good middle ground might be the EcoFlow DELTA, a 1200Wh power station that allows you to power up to 13 devices at once.
EcoFlow DELTA solar generator powering multiple devices
Beyond just outlets, you’ll also want to consider how much the solar generator outputs. Older, cheaper models tend to lack output, meaning you won’t be able to power larger appliances such as microwaves. However, all EcoFlow solar generators have high output capability and come with X-Boost technology allowing for surges in output requirements.  EcoFlow DELTA Pro, for example, can even power appliances that require as much as 4500W. That’s AC units, heaters, and the like all covered.
Battery Chemistry: LFP vs. NCM Batteries
An important factor that you might not know about coming from a fossil fuel generator is battery chemistry. Different solar generators use different kinds of batteries. The two main ones are NCM batteries and LFP batteries. Each has its own advantages.
EcoFlow DELTA Max Interior
Lithium Iron Phosphate (LFP) Batteries: The workhorses
LFP batteries — named after their elements (LiFePO4) — are designed for long-term, regular use. If you’re looking for a solar generator to be used as a home battery, you’ll likely want an LFP battery since you’ll be cycling it multiple times a week. These have a cycle life almost 5 times that of the NCM alternative. The sacrifice LFP batteries have is that they’re heavier, so if you opt for an LFP battery, make sure it’s easy to transport. EcoFlow DELTA Pro or any of the EcoFlow RIVER 2 series would be a good pick here.
Lithium Nickel Manganese Cobalt Oxide (NCM) Batteries: Flexibility first
NCM batteries can be smaller, lighter, and work just fine in temperatures as low as -20°C. They’re the default pick for most portable solar generators as they are easy to carry around, throw in your trunk for camping, or move around the house. the EcoFlow DELTA series uses lithium (with the exception of the Delta Pro, which uses LFP). The downside of LFP is that lower cycle life of around 800 cycles before degradation to 80% capacity. That won’t be as big a factor if you’re only using yours for trips.
Solar Input: What solar panel do I need?
Solar-powered generators don’t necessarily work with any solar panel. You should check the solar input that your solar generator supports to ensure that you can use the solar panel you have or intend to buy. EcoFlow’s solar generators all have high solar inputs for their size. Ranging from 110W for the EcoFlow RIVER 2, to 1600W for the largest model, EcoFlow DELTA Pro.
plugging in portable solar panels
Just like with fossil-fuel generators, solar generators are used for a ton of applications, here are three of the most popular applications:
Solar generators for home backup
Blackouts are on the rise across the US, and energy prices set to increase due to scarcity and inflationary pressures. As a result, people are using solar generators to power their home appliances as a source of renewable, emergency power. In general, larger portable power stations like EcoFlow DELTA Pro are a good go-to for full home backup, with smaller solar generators such as EcoFlow DELTA being good for powering the essentials.
We wrote a dedicated article on this here, that’ll take you through how people backup their homes with solar generators.
Solar generators for camping
Another popular use for solar-powered generators is camping. The attraction is that you can take your campsite to the next level with outlets. We take them for granted indoors, being able to just plug in whenever we need them, now we can do it in the wild. Just make sure not to check your slack messages, perhaps boil yourself a brew instead.
Here, you’ll likely want to opt for a power station that puts portability first such as EcoFlow RIVER 2 Pro, since you’ll be carrying it around with you. However, if you’re going all out, EcoFlow DELTA Pro or Max works here too.
EcoFlow RIVER Max plus solar generator for camping
We wrote a full article exploring this topic further here.
Solar generators for RVs & Vanlife
Did you know vanlife is booming? Since the pandemic, people are looking for alternate ways to travel, and some have even taken the move to the road permanently. Solar generators and RVs or vans are an ideal match. They provide power to your setup, paired with portable solar panels attached to your roof, you’ll have renewable energy on the go. Here, your pick depends on your needs. Large RVs might warrant a large power station, with small vans only requiring a kilowatt-hour or two for a few small appliances and devices.
Here’s some more detail on the topic with another piece we put together.
EcoFlow RIVER 2 Power Station LiFePO 4 Black - EcoFlow Official
Which solar generator is right for you?
With all that in mind, you’ll be starting to formulate an idea of what you need. Calculate how many watt-hours you require, then weigh up your priorities following that. Outlets, solar compatibility, charging methods, and of course portability. To make the choice a little easier, we’ve put together two articles for some further reading, one on the more portable EcoFlow RIVER 2 series, and the other on the EcoFlow DELTA series.
River Series Comparison
EcoFlow DELTA Series Comparison
As you can see, there are a lot of things to consider when it comes to choosing the right solar generator for your needs. With everything we’ve covered here, you might have an idea of the right one for you. Consider everything from portability, compatibility, size, and more to make sure you make the right choice.
Ready to purchase your ideal power solution today? Check out the EcoFlow DELTA Series Solar Generators we offer at EcoFlow to find your perfect fit.
Kris Haagensen
Kris Haagensen
Born and raised in the UK, Kris is a 4.0 International Business grad from Sheffield Business School. After working in the tech industry for half a decade in Shenzhen, China, he's now Lead Copywriter at EcoFlow. Kris is a renewable power enthusiast & uses solar generators to run his DJ gear in exotic locations.
spot_img
