Introducing DELTA mini
We make the world’s fastest recharging portable power stations, and it was time for something that was heavy-duty but also super easy to carry. DELTA mini has enough capacity for a TV at a tailgate party plus everyone’s phones. It’s also powerful enough to run most corded power tools while recharging the cordless ones.
DELTA mini’s 882Wh capacity
DELTA mini has way more capacity than most personal batteries, but it’s still portable enough not to cramp your style. Run a projector for 9 hours, recharge a laptop 12 times, use a circular saw non-stop for 30 minutes – or do all three if you want to watch a movie while finishing the deck.
EcoFlow DELTA mini
LCD screen
See exactly how many watts are coming into fine-tune your solar setup. See how many minutes are left to manage your usage better. The display is full of info to let you know exactly what’s going on.
Twelve outlets
AC plugs for appliances, USBs for personal devices, and DC plugs for travel gear make it versatile for basically any application. And with 1400W of output, feel free to use them all at the same time.
EcoFlow DELTA mini ports
X-Stream Fast Charging
DELTA mini recharges from 0–80% in 1 hour and to max capacity in 96 minutes. That’s twice as fast as the closest competitors, and all without a power brick. Between the wall and DELTA mini, there’s only a cable.
Portable
It’s half the weight of a car battery with twice the usable capacity. This 24-pound power station lifts easily with two handles that balance perfectly with the unit’s center of gravity.
DELTA mini handles
First time to solar?
Maybe you have them, maybe you’ve never tried, but using solar panels is an excellent option for the outdoors. DELTA mini can input 300W of it, and our MPPT maximizes efficiency. We recommend two EcoFlow 160W solar panels to get all 882Wh in as fast as 4 hours.
EcoFlow DELTA mini + solar panels
Lasts longer
A cycle life of 800 is 60% more than the going standard and even most smartphones. If you used half of DELTA mini’s total capacity every single day for four years, the battery would still have 80% of its original capacity.
Wireless connections
DELTA mini connects with the EcoFlow app either through your Wi-Fi network or directly to your phone. From there, you can customize settings, monitor metrics, and power off groups of outlets.
Get all these great features in a small package when you shop DELTA mini.
Share this article
Thanks for joining us!
Please check your email.
spot_img
Popular posts
RELATED POSTS
