4 Best Portable Power Stations for Camping in 2025
Camping should be about relaxing, exploring, and staying connected on your terms—not worrying about dead batteries. A portable power station ensures that your essential devices stay charged, whether you’re capturing stunning landscapes, keeping food fresh, or powering camp essentials. But with so many options available, how do you choose the right one? Here, we break down the best choices to help you stay powered wherever your adventure takes you.
EcoFlow’s Best Portable Power Stations for Camping
Here are our top four at a glance and what situations they’re best for:
  1. Best for Backpacking or Hiking: EcoFlow RIVER 3
  2. Best for Weekend Trips: EcoFlow RIVER 3 Plus
  3. Best for Essential Device Backup: EcoFlow RIVER 2 Pro
  4. Best for Longer Trips: EcoFlow DELTA 2
For backpackers and hikers, every ounce of weight matters. The EcoFlow RIVER 3 is designed to be as portable as possible while still providing reliable power in remote locations.
Whether you’re trekking through rugged terrain or setting up camp in the wilderness, this power station ensures your essential devices stay charged without adding unnecessary bulk to your gear.
With multiple output options, it can keep GPS devices, headlamps, cameras, and smartphones powered throughout your journey.
Its fast-charging capabilities allow you to replenish battery life quickly, and solar compatibility makes it an excellent choice for extended outdoor adventures. If you need a lightweight power source that won’t slow you down, this is it.
EcoFlow RIVER 3 Specifications
  • Storage Capacity: 245Wh
  • Expandability EB300 (286Wh), EB600Wh (572Wh)
  • AC Output: 2 outlets, 300W total (Surge 600W, X-Boost 600W)
  • Solar Charge Capacity (Maximum): 110W
  • Weight: 7.8 lb
  • Dimensions: 10×8.3×4.4 in
  • UPS Auto-Switchover Time: ~20ms
  • Operating Noise Level: <30 dB
  • Charging Options: Solar/AC/Car/USB-C Charging
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Depth of Discharge: 100%
  • Warranty: 5 years
  • App Monitoring and Control?: Yes
Pros
  • Ultra-lightweight and easy to pack.
  • Charges multiple small devices simultaneously.
  • Supports solar charging for off-grid use.
  • Quiet operation, perfect for nature-focused trips.
  • Built for rugged outdoor conditions.
Cons
  • Not suitable for running large appliances.
  • Limited capacity for extended multi-day trips.
Weekend campers need a power station that balances portability with power output, and the EcoFlow RIVER 3 Plus is an excellent option for short getaways.
Whether spending a few nights in the woods or camping near a lake, this model offers enough energy to keep small appliances, lights, and essential electronics running without requiring frequent recharges.
If you’re looking for a dependable power source for weekend camping without carrying excess weight, this is a great choice.
EcoFlow RIVER 3 Plus Specifications
  • Storage Capacity: 256Wh
  • AC Output: 600W (1200W Surge)
  • Solar Charge Capacity (Maximum): 220W
  • Weight: 10.4 lbs (4.7kg)
  • Dimensions: 9.2 x 9.1 x 5.8 in (234 x 231 x 146 mm)
  • UPS Auto-Switchover Time: >10ms (True UPS for Computers/Hard Drives)
  • Warranty: 5 years
Pros
  • Ideal balance of power and portability.
  • Can run small appliances like fans and coolers.
  • Solar charging allows for extended trips.
  • User-friendly design with an easy-to-carry handle.
  • Reliable backup for emergencies.
Cons
  • Heavier than ultralight models, less ideal for hiking.
  • May need a larger power station for high-energy needs.
The EcoFlow RIVER 2 Pro provides a dependable backup solution for campers who rely on power for essential devices.
Whether you’re using a CPAP machine, charging camera gear, or running a laptop while working remotely, this power station delivers the energy you need to keep everything functional.
If you’re in an area with unpredictable weather, solar compatibility ensures continuous power and its rapid charging technology helps you get back to full battery faster. This is a great pick for anyone needing consistent, high-powered energy storage on the go.
EcoFlow RIVER 2 Pro Specifications
  • Storage Capacity: 768Wh
  • AC Output: 800W total (surge 1600W)
  • Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
  • Weight: 17.2 lbs (7.8 kg )
  • Dimensions: 10.6 x 10.2 x 8.9 in (270 x 260 x 226 mm)
  • Operating Noise Level: ~60 decibels
  • Warranty: 5 years
Pros
  • Can support higher-wattage devices.
  • Fast charging keeps downtime to a minimum.
  • Works as both a camping and home backup power source.
  • Multiple outlets for charging several devices at once.
  • Rugged and reliable for long-term use.
Cons
  • Heavier and bulkier than smaller models.
  • Overkill for campers with minimal power needs.
For extended off-grid camping, the EcoFlow DELTA 2 is a powerhouse capable of supporting a full campsite.
Unlike smaller models, it’s built for running larger devices like refrigerators, electric stoves, and power tools. It charges quickly, supports solar panel input, and provides a reliable energy source even in remote locations.
If you’re looking for a high-capacity power station that can handle demanding needs over multiple days, this is the ultimate choice.
EcoFlow DELTA 2 Specifications
  • Storage Capacity (Minimum): 1024Wh
  • Storage Capacity (Maximum): 3kWh
  • AC Output (Maximum): 1.8kW continuous output (2.7kW Surge)
  • Solar Charge Capacity (Maximum): 500W max (11-60V, 15A)
  • Weight: 27 lbs (12 kg)
  • Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options: Solar/AC/Car Charger
  • Multicharge Options?: Yes
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Warranty: Five years (no cycle life restrictions)
Pros
  • Large energy capacity for extended trips.
  • Can run high-power devices and appliances.
  • Quick charging ensures minimal downtime.
  • Works seamlessly with solar panels for off-grid use.
  • Sturdy and durable for long-term outdoor adventures.
Cons
  • Heavier and less portable than smaller models.
  • More power than needed for short or low-energy trips.
Things To Consider Before Choosing a PPS for Camping
Choosing the right portable power station (PPS) for camping isn’t just about picking the highest capacity.
Several factors determine how well a PPS fits your specific needs, from power output to charging speed. Below are key considerations to keep in mind before making a purchase.
Portability
A lightweight and compact power station is essential if you’re hiking, backpacking, or frequently moving between campsites. Look for designs with built-in handles or carrying straps for easy transport.
Larger models with higher capacity may offer more power but are less practical for mobility-focused trips.
Power Output & Device Compatibility
Not all power stations can handle the same devices. A smaller unit may be perfect for charging phones, cameras, and tablets, but if you need to power mini-fridges, CPAP machines, or cooking appliances, you’ll need a PPS with higher wattage and multiple AC outlets.
Check the continuous and surge power ratings to ensure compatibility with your essential gear.
Battery Capacity & Duration
Battery capacity determines how long a PPS can run your devices before needing a recharge. For short weekend trips, a lower-capacity unit may be sufficient.
For longer adventures, choose a model with expandable battery options or one that supports solar recharging to extend usability.
Charging Speed & Input Options
The faster a PPS recharges, the sooner you can get back to using it. Some models fully charge in under an hour, while others take several hours. Consider whether your power station supports solar, AC wall charging, car charging, or USB-C.
If you’re relying on solar panels, check the maximum solar input capacity to ensure efficient charging in off-grid settings.
Durability & Weather Resistance
Camping conditions can be unpredictable, so durability matters. A sturdy build with impact resistance is useful for rugged environments, while an IP-rated enclosure protects against dust and moisture.
If you’re camping in rain-prone or extreme weather areas, opt for a PPS with higher resistance to the elements.
Noise Levels
Some power stations operate almost silently, while others produce noticeable fan noise. If you’re camping in quiet natural environments or sleeping near your PPS, choosing a model with a low decibel rating ensures a more peaceful experience.
Are Portable Power Stations Good for Camping?
Yes, portable power stations are an excellent choice for camping, providing a reliable power source without the noise or emissions of traditional gas generators. They can charge phones, laptops, cameras, and even small appliances like mini-fridges or CPAP machines. Many models also support solar recharging, making them a great option for extended off-grid trips.
How Long Does a Portable Power Station Last on a Single Charge?
The runtime of a portable power station depends on its battery capacity and the devices being powered. Smaller models may last a few hours to a day, while higher-capacity units can power essential devices for multiple days. Using energy-efficient devices and solar charging can extend battery life significantly.
Can I Use a Portable Power Station While It’s Charging?
Most modern portable power stations support pass-through charging, allowing you to use them while they are recharging. However, charging speed may slow down if multiple devices are drawing power simultaneously. Always check the manufacturer’s specifications for safe usage.
A portable power station can make all the difference when camping, providing a quiet, reliable, and eco-friendly way to keep your devices charged and essential equipment running. By considering portability, power output, battery capacity, and charging options, you can find the perfect portable power station to meet your camping needs.
If you’re planning your next adventure, now is the time to explore your options and pick an EcoFlow power solution, like the EcoFlow DELTA 2, that will keep you connected, comfortable, and prepared—no matter where the trail leads.
