Best EcoFlow Black Friday Deals
Gear up for EcoFlow’s Black Friday deals, perfect for the adventurer or homebody alike. Discover unbeatable discounts on EcoFlow’s innovative solar panels, portable power stations, and more. Don’t miss this chance to equip your home or next outdoor journey with top-of-the-line, eco-friendly energy solutions at the best prices of the year!
Best Black Friday Deals for Solar Panels
Are you looking for top-of-the-line solar panels? Shop our versatile line of monocrystalline solar panels and find the perfect option for you.
400W Portable Solar Panel
EcoFlow’s 400W Portable Solar Panel, the most powerful and largest in its lineup, offers unparalleled energy efficiency for those who require substantial power on the go. With a stellar 400W capacity, it’s perfectly suited for high-demand applications, making it a top choice for RVs, camping, and home use.
Its robust design includes a high 23% conversion rate for optimal charging efficiency. Durable and adaptable, it features an adjustable angle, multi-layered design, and an IP68 waterproof rating, ensuring reliability in diverse environments. This panel combines portability with high energy output, making it a standout choice for efficient and reliable solar power.
Pros
  • High Power Output: With 400W rated power – the most EcoFlow offers – it features rapid charging capabilities.
  • Versatile Use: Ideal for camping, RVs, and home use, it’s also compatible with several EcoFlow portable power stations as well as EcoFlow’s Power Kits.
  • Durable Design: Features a robust, weather-resistant build with an IP68 waterproof rating.
Cons
  • Size: Larger and bulkier than other options, which might be challenging for compact storage.
  • Compatibility: Limited to specific EcoFlow models and systems with standard solar connectors.
110W Portable Solar Panel
The EcoFlow 110W Portable Solar Panel is a hiker’s and backpacker’s delight, flawlessly pairing with the RIVER 2 for efficient energy harnessing while on the move. This panel stands out for its portability and superior conversion rate of up to 23%, making it a powerful yet lightweight companion for outdoor excursions.
Boasting an IP68 waterproof rating and robust one-piece folding design, it’s built to endure the rigors of adventurous travel. Not only does it excel in converting sunlight into energy efficiently, but its self-supporting nature and included carrying case ensure maximum convenience and ease of use in any environment.
Pros
  • Ultra-Portable: Lightweight and compact, ideal for hiking, backpacking, and pairing with RIVER 2.
  • High Efficiency: Boasts an impressive conversion rate of up to 23% for faster, efficient charging.
  • Durable and Waterproof: IP68 rating ensures it can withstand various weather conditions.
Cons
  • Lower Power Output: At 110W, it may not be suitable for powering larger devices or multiple appliances.
160W Portable Solar Panel
The EcoFlow 160W Portable Solar Panel is designed for efficiency and convenience, making it perfect for longer camping trips and car camping. This panel balances portability with power, providing a high conversion efficiency of 21-22%.
Its one-piece folding design, combined with a case that can double as a stand, offers practicality in various outdoor settings. Additionally, its robust build with an IP68 waterproof rating ensures it stands up to diverse weather conditions.
Pros
  • Optimal for Extended Trips: Ideal for longer camping journeys with its blend of convenience and efficiency.
  • High Efficiency: Boasts a 21-22% conversion rate, allowing for quicker and more efficient charging in outdoor settings.
  • Weather Resistant: With its IP68 rating, it’s durable enough to handle harsh weather conditions.
Cons
  • Power Limitation: While suitable for longer trips, its 160W output might not suffice for powering larger appliances or multiple devices simultaneously.
220W Bifacial Portable Solar Panel
The EcoFlow 220W Bifacial Portable Solar Panel revolutionizes solar energy capture. Its unique bifacial design not only harnesses sunlight from the front but also utilizes ambient light from the back, increasing energy collection by up to 25%.
Its durable, one-piece tempered glass construction is built to withstand high temperatures. Compact and 10% smaller than comparable 220W panels, it’s designed for portability.
Pros
  • Bifacial Efficiency: Captures up to 25% more energy with its innovative two-sided design, enhancing charging speed.
  • Durability and Portability: Robust tempered glass construction and compact size make it ideal for various outdoor applications.
Cons
  • Price Point: Advanced bifacial technology may come at a higher cost compared to standard solar panels.
Best Black Friday Deals for Portable Power Stations
Shop industry-leading backup solutions and get the best deals on our portable power stations during this Black Friday season.
RIVER Pro
The RIVER Pro Portable Power Station stands out for its exceptional balance of power and portability. With a notable 720Wh capacity and 3 x 600W AC outlets, it caters to a wide range of appliances.
It has a rapid recharge capability, achieving 0-80% within just an hour. The power station also supports solar, car, and standard AC outlet charging, offering versatility in energy sources.
Pros
  • Rapid Charging: Charges from 0-80% in under an hour with X-Stream technology, ensuring quick power availability.
  • Expandable Capacity: Expandable capacity offers room to grow for those with greater power needs.
Cons
  • Limited Solar Compatibility: May not have the solar input necessary for those looking to use higher wattage solar panels.
RIVER 2
EcoFlow’s RIVER 2 presents an excellent blend of compactness and power, making it an ideal companion for backpacking and short trips. Its ability to charge rapidly to 100% in just 60 minutes means you can get back to enjoying power in no time.
Safe and durable with LiFePO4 battery chemistry, RIVER 2 promises up to 10 years of reliable use. It’s lightweight, versatile in charging options, and capable of powering 99% of consumer electronics.
Pros
  • Ultra-Fast Charging: Charging from 0-100% in 60 minutes, RIVER 2 will have you back to enjoying access to power quickly.
  • Versatile and Portable: Exceptionally lightweight and capable of being charged in four different ways, including solar, RIVER 2 is perfect for outdoor adventures.
Cons
  • Limited Power: Not suitable for those with more robust power needs.
RIVER 2 PRO
RIVER 2 PRO stands out as the versatile power solution, ideal for car camping and providing backup for a few essential home devices. With its sizable 768Wh capacity and 800W output, expandable to 1600W with X-Boost, it can run 80% of home appliances.
Charge quickly to 100% in just 70 minutes and enjoy up to 10 years of reliable use, thanks to its safe LFP battery. The lightweight RIVER 2 PRO is an efficient, portable power ally.
Pros
  • Rapid Charging: Reaches a full charge from 0-100% in just 70 minutes.
  • Versatile & Portable: Ideal for outdoor trips and home backup for a few essential home devices, with a lightweight design for easy mobility.
Cons
  • Limited for Higher-Wattage Appliances: This may not be a suitable solution for those looking to power higher-wattage appliances.
RIVER 2 Max
RIVER 2 Max is your ideal camping companion, perfect for powering small appliances on weekend or off-grid trips. This power station charges rapidly, reaching 100% in just 60 minutes, and offers up to 10 years of safe and reliable usage.
It’s lightweight and versatile, capable of running 80% of essential appliances with X-Boost. With its quick switchover speed and multiple charging options, including solar, it’s an incredibly convenient and versatile power solution.
Pros
  • Fast Charging & Longevity: Charges fully in 60 minutes and offers a durable battery life of up to 10 years.
  • Lightweight & Powerful: Ideal for outdoor adventures with the ability to run some small appliances and a lightweight design for easy transportation.
Cons
  • Limited Compatibility: Compatible with 160W solar panels and lower, less suitable for those who may plan to use existing high wattage panels.
DELTA 2
DELTA 2 stands out as an entry-level home backup solution and a reliable companion for extended road trips. It offers expandable storage capacity, pairing seamlessly with up to 400W solar panels.
Its 1800W AC output can power over 90% of household appliances. Safety and longevity are assured with its sophisticated battery management system, making it a versatile choice.
Pros
  • Expandable Capacity: Expandable capacity caters to home backup and long camping trips.
  • Versatile: It can power over 90% of home appliances, or you can plug in as many as 15 devices simultaneously.
Cons
  • Initial Investment: While cost-effective in the long run, the initial investment for the full setup can be considerable.
DELTA 2 Extra Battery
The DELTA 2 Extra Battery is designed to enhance the power capacity of your DELTA 2 portable power station. It’s ideal for expanding energy storage to meet more extensive needs, whether for home backup, outdoor activities, or RVing.
Pros
  • Expandable Power: Boosts DELTA 2’s capacity, making it perfect for those with greater power requirements.
  • Fast Recharging: The DELTA 2 Extra Battery can charge with DELTA 2 from 0-80% in 80 minutes, or from 0-100% in just 130 minutes with AC input.
Cons
  • Additional Purchase: Requires buying an extra component to increase DELTA 2’s potential.
DELTA 2 Max
The DELTA 2 Max boasts a LiFePO4 battery, Wi-Fi/Bluetooth connectivity, and compatibility with various EcoFlow products, including the WAVE, GLACIER, and Smart Generator. It’s a versatile choice for enhanced home backup and off-grid trips, offering expandable energy storage and robust power output.
Pros
  • Expandable Capacity: Easily increase power storage up to 6144 with two DELTA 2 Max Smart Extra Batteries.
  • High Power Output: Powers up to 99% of home appliances with X-Boost.
Cons
  • Initial Investment: The advanced features and expandability of the DELTA 2 Max come with a higher upfront cost compared to other models.
DELTA 2 Max Extra Battery
The DELTA 2 Max Extra Battery is specifically designed to enhance the DELTA 2 Max portable power station, providing a significant boost in storage capacity. This addition is ideal for those needing extended power for home backup, outdoor activities, or long road trips, ensuring a consistent and reliable energy source.
Pros
  • Expanded Capacity: Adds an extra 2048Wh, enabling expansion up to 6144Wh with two additional batteries.
  • Long-Lasting: It boasts a long-lasting LFP battery that can provide 10 years of use.
Cons
  • Cost: For those with higher power requirements, this is a great choice, but it is an additional cost to expand your capacity.
DELTA Max
The DELTA Max, a versatile and expandable home backup solution, is tailored for those seeking a balance between price and performance. It offers a robust 2-6kWh expandable capacity.
Pros
  • Powerful Output: Capable of powering heavy-duty devices with a 2400W output. With X-Boost, power devices up to 3400W.
  • Rapid Charging: Achieves 0-80% charge in just 65 minutes, with options for solar charging in as fast as 2.5 hours.
Cons
  • Size and Weight: While portable, its size and weight might be challenging for some users, especially when expanded with extra batteries.
DELTA Pro
The DELTA Pro, an excellent choice in portable power stations, revolutionizes home energy storage and backup. With a 3.6kWh capacity that’s expandable to 25kWh, and an AC output of 3600W (4500W with X-Boost and expandable to 7200W with two units), this unit caters to a wide range of needs, from daily home use to emergency backup. It’s a power hub designed for the highest energy demands, offering a unique blend of versatility and efficiency.
Pros
  • Massive Capacity & Output: Offers 3.6kWh capacity that’s expandable to 25kWh, as well as an impressive AC output.
  • Innovative Charging: Features incredible 6500W MultiCharge capabilities and compatibility with solar charging.
Cons
  • Size & Investment: Its substantial size and higher investment make it more suited for dedicated home backup rather than casual or light use.
DELTA Pro Extra Battery
The DELTA Pro Extra Battery is an essential add-on for those requiring substantial power capacity. Designed to complement the DELTA Pro Portable Power Station, it offers an additional 3600Wh of energy storage.
As a result, you can scale up to a whopping 10.8kWh with two extra batteries. It’s a perfect blend of portability and power, crafted to keep up with the demands of modern, energy-intensive lifestyles.
Pros
  • High-Capacity Expansion: Significantly boosts your DELTA Pro’s storage, perfect for heavy-duty power needs.
  • Versatile Charging Options: Supports various charging methods, including AC, solar, car, and even EV charging stations.
Cons
  • Additional Investment: Requires an extra purchase, ideal for users with high-end power storage demands.
DELTA Pro + Extra Battery
Upgrade your power backup solutions with the DELTA Pro + Extra Battery bundle. Offering an expandable capacity, this setup is ideal for extensive home backup requirements.
With versatile charging options, including solar, AC, and EV stations, it provides flexibility in power sourcing.
Pros
  • Extensive Capacity: Provides a substantial power reserve for extended use.
  • Flexible Charging: Supports various charging methods for user convenience.
Cons
  • Portability: The added capacity may reduce ease of movement and portability.
Best Black Friday Deals for Solar Generators
Looking for a complete backup solution? Get awesome deals and shop our great Black Friday deals on solar generators
DELTA Pro + 400W
The DELTA Pro + 400W Solar Panel combo is an excellent choice for home backup solutions. With a robust 4500W AC output with X-Boost and an impressive 23% solar conversion rate, it ensures rapid charging and a reliable energy supply.
Pros
  • High Output: Offers an impressive 4500W AC Output with X-Boost.
  • Rapid Solar Charging: It has fast charging capabilities with up to 23% solar conversion.
Cons
  • Initial Investment: It comes at a higher upfront cost than other options.
DELTA 2 + 220W Solar Panel
EcoFlow’s DELTA 2 + 220W Solar Panel bundle combines convenience and power, making it an ideal solar generator for home backup and road trips. With 1800W AC output, it powers more than 90% of home appliances.
The bifacial design offers up to 23% solar conversion efficiency, enabling fast charging.
Pros
  • High Efficiency: Up to 23% solar conversion allows for rapid charging.
  • Powerful Output: Supports over 90% of home appliances with its 1800W AC output.
Cons
  • May Require Expanding: If you have a higher power requirement, you may need to expand the capacity of your unit.
DELTA 2 Max + 220W Solar Panel
EcoFlow’s DELTA 2 Max + 220W Solar Panel is a perfect solution for reliable home backup and outdoor use, offering a 2-6kWh expandable capacity. The combination includes a high-capacity DELTA 2 Max and a bifacial 220W solar panel for efficient energy capture. With X-Boost, it can power 99% of home appliances.
Pros
  • Expansive Power: Offers a 2-6kWh expandable capacity, ideal for varied energy needs.
  • Efficient Charging: Includes a bifacial solar panel for faster charging and higher energy capture.
Cons
  • Size and Weight: The system’s size and weight may be a consideration for those with limited space or portability needs.
Best Black Friday Deals for Camping
Searching for useful and unique camping gear? Transform your camping game long-term and shop our Black Friday deals for camping.
RIVER 2 Max + 160W Portable Solar Panel + RIVER 2 Max Waterproof Bag
The RIVER 2 Max + 160W Portable Solar Panel + Waterproof Bag is the ultimate camping companion. This setup is perfect for weekend getaways and off-grid adventures, providing ample power for some small appliances. The inclusion of the waterproof bag helps keep your gear dry and protected.
Pros
  • Versatile Power: Ideal for powering some small appliances, making it perfect for family camping and off-grid trips.
  • Solar Efficiency: The 160W Solar Panel offers sustainable and efficient charging.
Cons
  • Limited to Smaller Appliances: Best suited for smaller power needs, which may not suffice for all camping requirements.
RIVER 2 Max + 160W Solar Panel
The RIVER 2 Max + 160W Solar Panel is a dynamic duo for off-grid adventures. Tailored for weekend camping, it effortlessly powers some small appliances, like a cooktop, with its reliable 1000W AC output with X-Boost.
The set is lightweight, enhancing its travel-friendliness, while the efficient solar panel ensures quick charging.
Pros
  • Efficient Energy Generation: Capable of generating up to 1.2kWh daily, suitable for various camping needs.
  • Quick Solar Charging: High conversion rate for fast charging, achieving 0-100% in just 4 hours.
Cons
  • Focused on Small Appliances: Primarily designed for smaller appliances, which may not meet the energy demands of larger camping setups.
RIVER 2 Pro + 160W Solar Panel
The RIVER 2 Pro + 160W Solar Panel is a versatile solution for car camping enthusiasts and homeowners seeking backup for a few essential devices. With X-Boost, it can power 80% of home appliances, making it ideal for outdoor adventures or as a reliable backup for critical home devices such as fish tanks and medical appliances.
Pros
  • High Appliance Compatibility: It’s capable of powering 80% of home appliances, enhancing its versatility for various uses.
  • Ideal for Car Camping: Compact and efficient, perfect for powering devices during car camping trips.
Cons
  • Limited to Essential Devices: Best suited for essential appliances but not for extensive home backup needs during prolonged outages.
Smart Generator (Dual Fuel Generator)
The EcoFlow Smart Generator (Dual Fuel) is a versatile and efficient backup power source for your DELTA Pro or other compatible portable power station, also functioning as a standalone generator. With dual fuel capability, it offers the flexibility to use either gasoline or propane (LPG). The integration with the EcoFlow ecosystem and smart control features make it an advanced, convenient option for extended blackouts and emergency power needs.
Pros
  • Dual Fuel Flexibility: Operates on both LPG and gasoline, offering extended usability and storage convenience.
  • EcoFlow Ecosystem Integration: Seamlessly charges DELTA Pro/Max or Power Kits automatically, ensuring efficient power management.
Cons
  • Complex Setup for New Users: It may require a learning curve for those unfamiliar with dual fuel generators or smart control systems.
Best Black Friday Deals for Accessories and Bundles
Want the ultimate setup this Black Friday? Shop our accessories and bundles this season for the best deals on the market.
DELTA 2 + Smart Extra Battery + DELTA 2 Handbag
The EcoFlow DELTA 2 + Smart Extra Battery + DELTA 2 Handbag Bundle provides a comprehensive and versatile power solution. This bundle enhances the DELTA 2’s capacity and convenience, making it perfect for extended road trips and emergency home backup. The handbag offers added portability and protection, ensuring your power setup is always ready and secure.
Pros
  • Extended Power: The Smart Extra Battery significantly increases the DELTA 2’s storage capacity, making it ideal for longer usage.
  • Long-Lasting: You’ll have access to long-lasting, reliable power with this bundle.
Cons
  • Additional Weight: The extra battery increases the overall weight, making the bundle less convenient for lightweight travel.
DELTA 2 Max + Transfer Switch + Waterproof Bag
The DELTA 2 Max + Transfer Switch + Waterproof Bag Bundle offers a robust and versatile solution for power management and safety. Ideal for home backup, this bundle ensures your DELTA 2 Max is always ready and protected. The Transfer Switch enables integration into home circuits.
Pros
  • Seamless Home Integration: The Transfer Switch allows for connection to home circuits for efficient power backup.
  • Expandable Capacity of DELTA 2 Max: The DELTA 2 Max has an expandable capacity for those with greater power requirements.
Cons
  • Complex Setup: Installing the Transfer Switch requires a qualified electrician.
WAVE 2 Extra Battery
The WAVE 2 Extra Battery is a compact and powerful addition to your power solutions. With a substantial 1159Wh capacity, this detachable battery is perfect for keeping your WAVE 2 running longer.
Pros
  • High Capacity: 1159Wh capacity offers extensive additional power for longer usage of your WAVE 2.
  • Versatile Design: It’s detachable and easy to carry, making it extremely convenient.
Cons
  • Higher Cost: Comes with a higher cost in order to keep your WAVE 2 running longer.
Shop the Best EcoFlow Black Friday Deals Today!
Don’t miss out on EcoFlow’s incredible Black Friday savings! Upgrade your energy solutions with our top-notch solar panels, portable power stations, and accessories at unbeatable prices.
Act now to secure these limited-time offers and power your life with EcoFlow’s innovative, eco-friendly technology. Shop today!
