While there are plenty of campsites with electrical hookups, many people enjoy the experience of going off-grid and fending for themselves. Although camping means getting back to nature for some, others set up camp and work remotely or simply want the added convenience of creature comforts.
No matter where or how you like to camp, read on to learn how beneficial a portable power station could be on your next outdoor adventure.
Choosing the Right Solar Powered Generators for Camping
Best Generators For…
Most Portable
60W
Foldable |
Waterproof |
4 kg* |
60W Input |
Mid-Range
110W
Foldable |
Waterproof |
6 kg* |
110W Input |
Mid-Range
160W
Foldable |
Waterproof |
7 kg* |
160W Input |
Highest Input
400W
Foldable |
Waterproof |
16 kg* |
400W Input |
Benefits of Camping with Solar Generators
If you’re still on the fence about purchasing a solar generator, then keep reading to learn why they’re the best power source for camping.
Quiet & Odorless
Solar-powered generators are completely silent and produce no emissions, so you can enjoy the peace and quiet of your surroundings without any obnoxious smells while still powering your camp.
Eco-friendly
One of the most appealing features of a solar generator is that it creates clean energy. It lends itself perfectly to camping in a natural environment, where burning petrol to cook or power lights harms the global and local environment.
Safe
Since portable power stations don’t use fossil fuel to run, they’re a safe, environmentally friendly option, especially if you’re camping in the woods. Unlike petrol generators, you can safely use them inside a tent or RV to power lights and appliances.
Long-lasting
Solar-powered generators have a lifespan of 25-35 years, depending on the quality and brand. While they may appear expensive at first, they can be considered a worthwhile investment in the long run.
Ease-of-Use
A portable solar generator includes all the technology needed to recharge and power your home appliances. Simply plug in your solar panels, connect to an EV charging station or the grid to charge the unit, and then connect your devices when you’re ready to power up.
Portability
The best portable power stations hold all the essential components you need for solar power. So unlike kits used to wire a home or RV, it’s easy to take with you anywhere. Pair with travel-friendly solar panels that fold up when not in use.
Multiple Ways to Charge
It may be called a solar generator, but some portable power stations can also charge using different sources. While solar panels are the most eco-friendly way to recharge, you can also charge from the grid when the weather isn’t ideal. Many of EcoFlow’s units can recharge to 80% in less than 2 hours. If you get caught short, you can also top off the battery while you’re in the car using your 12v charging port. Since this is the slowest charging option, it should only really be used as a last resort.
Charging using an electric vehicle (EV) charging station is still a fairly unique charging option. But it’s convenient since there are over 3000 EV charging stations in Australia.
Versatility
Even if you’re considering purchasing a portable solar generator for camping, they can also be used in other ways. Since they’re so easy to use, you can pick them up and go wherever you want. It can go with you in the car, to the office, shed, or any event where you might need backup power.
How to Charge Your Portable Solar Generator While Camping
You don’t want to run out of power while you’re off the grid, which is why there’s more than one way to juice up your portable power station.
Solar Panels
Portable solar panels are the ideal way to top up your generator when you’re off-grid. They’re convenient to store and transport, as they fold away when you’re not using them. Solar panels typically require an solar panel connector that plugs into the generator to begin charging.
AC Wall Outlet
Solar generators allow you to plug into the wallet socket at home and recharge. This is by far the fastest charging method and is perfect if you decide to take off last minute, as EcoFlow portable solar batteries have the most rapid charging technology in the world.
12V Car Charging
Car charging is the slowest option, but using your 12V socket can give your solar generator a boost when you’re on the go.
EV Charging Stations
This is a relatively new addition to portable solar generators; currently, only EcoFlow’s DELTA Pro has this function. With tens of thousands of available stations located around the USA, and 150 thousand in Europe, DELTA Pro can recharge using an EV charger in less than 2 hours.
Extra Batteries
While not the same as charging, Extra Batteries can be attached or plugged into a central unit to offer additional power. Extra Batteries are available for River, River Plus, River Pro, DELTA Max, and DELTA Pro. You can see all the Extra Batteries here.
What to Look for in a Solar Powered Generator for Camping
Charging Outlets.
Camping has changed considerably over the years, and you no longer have to rely on a pack of cards and a guitar for entertainment (but you can, and that’s awesome). Now, you can take tech with you wherever you go. Just make sure to factor in how many outlets you’ll need for all your gear.
If you’re only planning to charge a laptop, mobile, and a drone, you might only need a handful of ports. You’ll need something larger if you’re powering a whole family’s gear and high-wattage appliances.
Portability
Weight and size are essential factors to consider when you’re camping. You have a finite amount of storage space in your car or RV, and once you’ve packed your essential camping equipment, there’s not much room for extras. You also need to be realistic about the size and weight of a portable power station, especially if you want enough watt-hours to illuminate the Outback.
Charging Rates & Time
Charging rates are usually affected by the size of the battery itself. So the larger the generator, the longer it will take to charge. Solar chargers can recharge up to 80% using a wall outlet from 2-12 hours. EcoFlow’s portable power stations have the fastest recharge speeds in the industry, so even our biggest units charge in under 2 hours. Yep, that fast. Using solar to recharge a solar generator depends on how much input it allows, the solar panel’s efficiency rating, and wattage. A 12V car charger takes a while to recharge but works fine if a solar generator needs a quick power boost.
The capacity of a solar battery you choose for camping depends on a combination of factors, including the kind of appliances you want to power and how many. For example, if you plan to run a 60W mini fridge for approximately six hours, you’ll need a solar battery with a capacity of at least 360Wh.
Surge
When they first kick in, some appliances, especially those with an electric motor, such as a refrigerator, have a surge of power that is much higher than their typical wattage. A fridge that may only need around 800W will have an additional power surge of 1200W when the compressor starts. If you’re planning to power a fridge, you’ll need a solar generator with a surge rating of at least 2000W.
What is the Best Solar Generator for Camping?
Depending on how long you’re camping for and the types of devices you’re powering, we’ve got a range of portable solar power stations that can fit your needs.
For a simple overnight camping trip, a small power station with a capacity of around 200Wh, like EcoFlow’s River mini, is enough. You can easily charge your phones and laptops and light up your campsite. River mini can even boil a low-wattage camping kettle for coffee in the morning. Top up River mini using its 100W solar input capabilities.
Weekend Trips
200-300Wh could be enough to keep you powered over the weekend, and even if you run low, you can top up with solar panels. EcoFlow’s River can not only recharge using solar panels but also connects to an Extra Battery to double its capacity to 576Wh. River can power most electric appliances, including weekend must-haves such as a mini-fridge and electric frying pan.
Dry Camping
For dry camping, you might require a larger capacity solar battery if you’re unable to recharge using solar during the daylight hours. Alternatively, with a portable power station, such as River Max, you also have an additional battery that doubles the capacity. The battery is removable, so you can take it off if you won’t be using it.
Road Trips & Overlanding
If you’re planning on travelling long distances in your RV or jeep, then a solar power station that balances portability, capacity, and ability to charge high-wattage appliances is essential. If you’re frequently off-grid, choose a larger capacity battery, such as a River Pro. Add an Extra Battery, and its capacity increases to 1440Wh. With an output of 1800W, you can power a hairdryer, travel washing machine, and more.
If you’re looking for a power station with even more power, take a look at our DELTA Series. With an expandable capacity of up to 25kWh and output of 7200W, you can stay powered for days, even using high-wattage appliances.
