Table of Contents
Ah, or amp hours, is a rating reported on batteries. Some batteries have high Ah, while others have much lower ones. The Ah of a battery is one factor to consider when determining the best choice for you.
Keep reading to learn more about amp hours, how to calculate them, and what they mean for your battery.
What Is an Amp?
An amp is a measure of electrical current. A higher amperage means a higher volume of electrons flowing.
Essentially, amps describe the volume of electrical charge, current, flowing through the conductor or object.
What Are Amp Hours?
Ah, or amp hours, is a unit of measurement for quantifying a battery’s capacity. This rating is provided to inform you how many amps can be delivered to your device for a particular time at a specific rate.
For smaller batteries such as AA or AAA batteries, the amp hours are reported in milli-amp hours, or mAh. One milliamp hour is 1000th of 1 amp hour. This rating is useful in determining the battery capacity and understanding how long your device will run on a single charge.
When choosing the right option for you, paying attention to the amps needed for your devices is crucial to ensure you don’t run out of power.
What Does Ah Mean on a Battery?
We can use Ah to describe battery capacity. The Ah rating indicates how many amps the battery is capable of providing for one hour.
For example, if a battery has a 5Ah rating, it can provide 1 amp of current for 5 hours. Of course, this is all under ideal conditions. The reality is that weather conditions and temperature can impact the number of running hours you’ll get from your device.
Often, manufacturers report capacity in watt-hours (wh). For example, the DELTA Pro has a capacity of 3600Wh.
You can convert amp-hours (Ah) to watt-hours (Wh) with the below equation if you know the voltage (V):
Wh = Ah x V
For accurate comparisons between battery capacities, it’s best to compare based on watt-hours, as voltage plays a role when it comes to amp-hours.
How Do You Calculate Battery Capacity?
You can calculate the Ah on a battery by multiplying amps (A) by time (t). Here, time refers to discharge time and is often reported in hours, but it can be in minutes or seconds. With “Ah,” time is reported in hours, hence the “h.”
Below is the equation for ampere-hours:
Amp hour (Ah) = Current (I) x Discharge Time (T)
The units of battery capacity are Ah. For example, if you have a battery that can provide 5 amps of current for 2 hours, the below calculation can determine its capacity:
Amp hour (Ah) = 5 amps x 2 hours
Amp hour (Ah) = 10Ah
In this case, it has a capacity of 10Ah.
You might see a C-rate on a battery, which is closely related to the Ah. The C-rate describes the charging and discharging ability of the battery. You could look at it as the current at which the battery is charged or discharged. The Ah is multiplied by the C-rate to give the current (A) that the battery provides or is charged at.
Understanding Ah Ratings
Now you know what Ah means for an individual battery. The Ah rating gives you an idea of how long you can keep certain devices powered. To compare the battery capacity of two different batteries, you’ll want to convert the amp-hours to watt-hours to get an accurate comparison.
Does a Higher Ah Rating Mean More Power?
A higher Ah rating doesn’t necessarily equal more power. Rather, it means a high number and density of cells are providing current, so the electrical current can move with less resistance.
Several factors impact performance besides Ah, however, so there are many more factors to consider when choosing the right battery for you. This includes AC output, battery chemistry, and much more.
Whether or not a higher Ah battery is better depends on what you consider to be better. A higher Ah doesn’t mean one battery is better than the other, especially as many factors come into play when it comes to choosing the right battery for your needs, including battery chemistry, AC output, and so much more.
Watt-hours (Wh) are equal to amp hours times the voltage of the battery. You can calculate the watt-hours of a battery using the below equation:
Watt-hours (Wh) = amp-hours (Ah) x voltage (V)
In comparing the storage capacity of two batteries, you always need to compare the watt-hours, not amp-hours, unless the listed voltages are the same.
Understanding Ah is an important component of being able to understand whether or not a battery will meet your needs. Now, you’ll have a better understanding of battery capacity to help you choose the right power solution for you.
At EcoFlow, we have a wide range of power solutions, including an excellent selection of portable power stations that are suited to a wide range of needs. Explore what we have to offer today to take your power into your own hands!
