Table of Contents
Whether you’re a homeowner or business owner, you may be wondering if outdoor lighting is a sound investment to install on your property.
Outdoor lighting can be a practical and easy solution to adding significant value to any property. Below, we’ll explore its many advantages and investment benefits.
So, let’s get started.
Why Is Outdoor Lighting a Good Investment?
Enhanced Safety and Security
It’s no wonder that adding reliable light sources to your outdoor space is an excellent safety and security measure. In fact, keeping outdoor lights on can actually help to deter burglaries, so it’s an overall great investment for your home and peace of mind.
There are plenty of light fixtures that can help to up the safety of your home. The best options are either motion-censored or timed light fixtures that are designed to come on when activated. These fixtures are excellent investments and can allow you to sleep soundly throughout the evening knowing that your home is safe.
There are even some light bulb options that can be used in case of a power outage. This added level of security will ensure your home stays well-lit even if it were to go off the grid completely.
Curb Appeal
A well-lit house stands out from a poorly lit one. Just by adding in some outdoor lighting, you can totally transform the exterior of your home making it the brightest and most appealing spot in the whole neighborhood.
Spotlights and ambient lighting are great options to showcase your home and highlight its beauty. With the EcoFlow RIVER 2 Max, you can power up any type of lights you would like to ensure your home continues to stand out night and day.
Energy Efficiency
Outdoor lighting fixtures are often built with energy-efficient designs. The vast majority are powered by solar energy and will help keep your space lit while also keeping energy costs to a minimum.
You don’t have to worry about drastically increasing your energy costs as these light fixtures are very inexpensive to run. If you switch to these energy-efficient solutions, you may even notice a decrease in your monthly bills.
Depending on the lighting option you choose to go with, make sure to pay attention to the wattage requirements for the specific bulbs you will be using. Energy-saving bulbs may require a different level than other traditional bulbs, so do some research and ensure you have the right equipment to fully enjoy the new installation.
Highlight Landscaping Features
If you take pride in your front or backyard’s landscaping, why not showcase it? With the proper outdoor light fixtures installed, you can easily draw attention to the beautiful yard you work so hard to keep.
Outdoor lights can help to accentuate the many features of your yard, some of which may have been overshadowed before. This simple solution can give a facelift to your yard and will help to enhance the overall view.
Increased Property Value
Believe it or not, most homeowners are looking for a house that already has outdoor lighting installed. If you are planning on putting your house up for sale any time soon, consider this your sign to install some outdoor lighting!
Front and backyard spaces that are well-lit are highly sought-after features that more and more homebuyers are looking for when touring houses on the market. Taking this extra step and investing in some unique outdoor lighting will help to have your house selling faster than you could have imagined.
Ambiance and Mood
If you enjoy hosting outdoor parties and get-togethers, you know that nothing is more important than setting the ambience and mood before the guests arrive.
Proper lighting is key to setting the vibe for the party to come, and outdoor lighting fixtures are excellent tools for achieving the exact look you want. EcoFlow Portable Power Stations will make easy work of this task by allowing you to set up any lighting fixtures that you want.
Whether you are looking to hang lights from above or would rather have a few dimly lit spotlights shining in different directions, you can let your creativity take over and find the perfect spot to place the lights without fear of having to find a way to power them. A portable power station will do all the work for you and is easy to move around wherever you may need it to go.
Extend Your Time Outdoors
There’s no quicker way for an outdoor party to lose its momentum than when the sun goes down, and the area is no longer well-lit. With the proper outdoor lighting fixtures, you can easily keep the party going as long as you please without having to find ways to entertain your guests in the dark.
With EcoFlow RIVER 2 Series Portable Power Stations, you can easily keep any and all light sources powered up for the long haul. This will make your evenings last a lot longer and will ensure your guests are comfortable and enjoying the stay no matter how late the party may go.
Long-Term Savings
While you may be worried that keeping outdoor lights on would increase your electricity bills, there are energy solutions designed to mitigate this concern. Solar-powered lights are widely used for many outdoor fixtures and can actually save you money in the long run.
By investing in products like an EcoFlow Solar Generator, you will reap the rewards over the years with reduced electricity costs just by harnessing energy from the sun.
What’s the Best Way to Power Outdoor Lights?
Now that you see the investment benefits of installing outdoor lights, it’s time to move on to the installation process. There are tons of outdoor lights for you to choose from, depending on your home’s specific needs. Below are some of the more common ways you can get these lights installed as soon as possible.
Use Solar Power
As mentioned above, solar-powered lights are becoming more and more common. By installing some solar panels around the yard, you can easily supply a sufficient amount of power to any of the light sources you choose to install. Portable power stations can convert this stored energy to power all types of outdoor lighting fixtures.
Another great thing about using solar-powered lights is that you will not have to undergo a huge installation process. Unlike other permanent lighting fixtures, solar-powered lights do not require wires or access to an electrical source, making them incredibly easy to install and remove if needed.
Solar lights also work automatically, meaning you do not have to lift a finger to charge them or power them up once they have been properly installed. These eco-friendly lights are a great investment for your home, and you’ll continue to reap the rewards for many years to come.
Plug Them Into an Existing Outlet
If you’re not in the market to invest in solar, you can also use existing outlets to supply power to your lights. This is easiest to do with string lights or other lighting options that have a lengthy cord, though you can always employ an extension cord if necessary.
These lighting options are best for porches and patios as there is typically a power source nearby. You can also opt to keep a portable power station nearby to supply power to these items if it comes down to it.
Install Battery Operated Lights
If you do not have access to an existing electric outlet, there are other options. There are tons of battery-powered lighting options on the market for you to find exactly what you are looking for.
These options are great, especially if you are working to set up some lighting in areas that do not have easy access to a power source. You won’t have to sacrifice the area’s beautification by running an extension cord throughout the yard—simply install the required batteries and replace them when needed.
These options are also expensive, making them a great temporary solution if you are in the planning stages and are looking to get an idea of what types of lighting fixtures would look best in your yard.
Hardwired Electric Lights
A more permanent way to install your lights is to have them hardwired. To do this, you will likely need to employ the help of a professional as this requires the skills of an electrician.
The nice part about these lights is that they will have a constant supply of power just as the lights you have inside. With this option, you do not have to worry about plugging them in or powering them up, they are just ready to go whenever you need them.
Yes, adding outdoor lighting to your property inherently increases its value. Many prospective homeowners are eager to find a house that is well-lit both day and night. This feature offers a level of safety and security and increases the overall curb appeal of your home.
As you can see, there are so many great reasons why you should invest in outdoor lighting. This simple addition to your home can make the world of a difference and is a worthy investment that you can enjoy for many years to come.
Are you ready to take the first step and set up some outdoor lighting in your space? Learn more about how the EcoFlow Solar Generator can help you to create the outdoor space of your dreams.
