Table of Contents
Connecting solar panels to an inverter is essential in any home solar system. This article explores the different types of inverters available and explains step-by-step instructions for connecting everything in your system.
By following proper installation guidelines, including planning what kind of system you need, through the different wiring steps involved, and finally turning on and testing your system, you ensure your solar system’s safe and efficient operation. Then, you can start generating clean, free energy from the sun.
Let’s dive in!
Types of Solar Panel Inverters
First, let’s examine some of the different types of solar panel inverters. Then, you can build a powerful and adaptable home solar system and gain independence from South Africa’s struggling electrical system.
String Inverters
String inverters are the most common and cost-effective option for household solar installations. Here, solar panels, also called photovoltaics, are connected in series like in a string. That string is then connected to a single inverter, which converts the combined DC output from all the panels into AC electricity.
Microinverters
As you can probably guess from the name, microinverters are small inverters that connect directly to each photovoltaic module. Instead of converting the combined output of a series of panels, they convert the DC to AC electricity at each panel.
Microinverters are more efficient and reliable than string inverters because each module can function independently without affecting the entire system’s performance. For example, when a single panel gets shaded, it won’t affect the output of the whole system.
The EcoFlow PowerStream Microinverter easily integrates with your home’s electrical system and synchronises with your grid to ensure safe and reliable power delivery to your home.
Hybrid Inverters
Hybrid inverters combine the features of string and battery-based inverters. They handle DC input from a photovoltaic panel and a battery, allowing them to store energy or use it directly, providing a versatile and efficient solution for those going off-grid.
Power Optimizers
Power optimisers are another hybrid solution that combines the features of string and microinverters to improve efficiency and flexibility. They are installed on the panels to optimise each module’s DC output. The output is then sent to a centralised inverter, converting the DC electricity to AC.
Steps to Connect Solar Panels to an Inverter
It is essential to plan ahead and do your research, ensuring you understand the entire process. This will ensure the most efficient operation and keep you safe during installation and use. Only plug in or turn on your system once everything is fully wired to prevent the serious risk of electrical shock.
If you’re uncertain of your electrical skills, hire a professional electrician.
1. Prepare For Installation
Don’t just dive in and connect EcoFlow Solar panels to an inverter. You should plan ahead and prepare for your installation. You need to factor in your energy needs, the best location for your photovoltaics to maximise your energy potential and the size of the inverter you need. You may also need to apply for solar panel permits.
Finally, ensure you have all the equipment, tools, and safety gear you need for the installation process.
One important consideration is whether you want to stay on-grid or go off-grid. Staying on-grid means you don’t need to purchase batteries. However, going off-grid gives you complete energy independence, and you don’t have to worry about blackouts.
Considering an EcoFlow Portable Power Station for backup during blackouts is still a good idea if you plan to stay on the grid. Another option is an EcoFlow Dual Fuel Smart Generator that can use petrol or propane but runs more efficiently than traditional fossil fuel generators.
2. Solar Panel Installation
Your photovoltaics should be installed in the most suitable location, as determined by the sun’s angle, shade, roof, and other factors. Your EcoFlow Photovoltaics can be installed in series or parallel. Series connections are recommended for those needing higher voltage, with specific inverters, or homes with long cable runs to help compensate for voltage drops.
Parallel connections are best for those requiring higher current and for locations where panels face uneven shading so that when one is shaded, it does not impact the entire array’s performance.
3. Connect the Charge Controller to the Battery
These devices are critical to ensure the current is constant, which helps prevent damage to the inverter. The most common type of charge controller is the MPPT, which is used in most residential photovoltaic arrays.
Before connecting the controller to your panels, connect it to the battery using a stranded copper wire. Be sure to match the negative (-) terminal on the controller with the negative battery terminal. The positive (+) terminals are likewise connected to each other.
Charge controllers are built into all-in-one products like EcoFlow Solar Generators, so buying a separate unit is unnecessary.
4. Connect the Battery to the Inverter.
Now, connect the battery’s positive terminal to the inverter’s positive terminal, then connect the negative terminals to each other. Check the back of your inverter, as it may have additional instructions.
Again, if you use an all-in-one product, like an EcoFlow Inverter Generator, this will also already be built in.
5. Connect the Solar Panels to the Charge Controller
Now, connect your photovoltaics to your charge controller if they’re not built in.
6. AC Wiring
After connecting the panels, batteries, charge controller, and inverter, next we connect the AC output from the inverter to your home’s electrical panel. This often involves installing a dedicated circuit breaker, which will help ensure safety and prevent possible overloads.
Consult a licensed electrician if you’re not confident in your ability to perform household wiring.
7. Test Your System
Now, it’s finally time to turn everything on and see if it works. If your battery is dead and the sun is not shining, you will need to wait for the sun to shine so that your batteries will charge. Otherwise, if there is power in the battery, it should start supplying energy right away. If it doesn’t, turn it off immediately and check all your connections carefully to look for the issue.
8. Maintenance
Regular maintenance helps keep everything running in good condition and ensures safety. Clean your photovoltaics about every six months. At that time, check all the electrical connections to ensure they are secure and no animals have been chewing the wires. This will ensure maximum efficiency and safety.
Yes, you can connect photovoltaics directly to an inverter, but it’s not recommended because photovoltaics don’t provide a stable current. It’s best to connect them to a charge controller that regulates the charge, protecting the inverters from damage.
Solar panels should always be wired to an inverter through a charge controller first rather than connected directly. This helps ensure the DC current is consistent, preventing dangerous spikes or fluctuations than can damage it.
From preparation to photovoltaic installation, connecting an inverter to your system is not something you just do. Take your time, do your research, and always read the specific instructions that come with your device(s), as some require specific wiring set-ups. Don’t forget to leave the power off during all wiring stages to prevent the risk of serious electrical shock.
If you don’t have room for photovoltaics, the EcoFlow Inverter Generator is a great alternative. It uses both petrol and propane for versatile options. You can also combine it with a solar generator to increase efficiency even more.
