How to Calculate Solar Power ROI
The price tag on a new residential solar panel system may give you sticker shock.
The average South African home requires an initial investment of about R55,000 to R250,000 to supply adequate electricity to meet a substantial portion of demand — although solar generators that provide essential home backup are available for about R25,000.
Despite the upfront costs, most homeowners see a sizeable return on their investment in clean, renewable solar power over time — not to mention protection against load-shedding and blackouts.
That’s right!
Installing a residential photovoltaic (PV) system can do more than just help the planet and save you money on your electric bills…
You can even turn a profit in the long run.
Read on to find out if investing in home solar power is worth it for you and your family.
What Is the Average ROI for Solar?
The estimated average return on investment for residential solar power systems that generate electricity in South Africa ranges from 10% to 30% (not compounded) over the lifetime of the photovoltaic (PV) modules (solar panels).
The difference between 10% and 30% is significant, to say the least.
Too many varying factors go into calculating residential solar ROI for nationwide averages to be of much use.
For example:
  • Electricity cost per kilowatt-hour from your utility provider
  • Total cost of your photovoltaic system
  • Estimated power output from the solar panels and balance of system
  • Expected lifespan of your PV modules, solar inverter, and other components
  • Government incentives
  • Grid-connected, off-grid or hybrid solar system?
However, just because there’s no easy answer to “What is the Average Solar ROI in South Africa?” doesn’t mean you can’t calculate how much you can expect to earn from your investment.
First, let’s examine how solar panels pay for themselves.
How Do Solar Panels Pay Back Their Investment Cost?
In most parts of South Africa, investing in solar panels to generate some or all of your household electricity will earn a significant return on investment.
But how long does it take to recover your initial costs?
The technical term for the amount of time it takes to break even on a residential photovoltaic system is the solar payback period.
You’ll learn exactly how to calculate yours below.
But first, let’s take a look at how solar panels save — and make — you money over time.
Energy Bill Savings
The primary way homeowners recoup their investment in residential solar energy systems is by spending less money on electricity bills.
The more kilowatt-hours your solar panels generate, the more you’ll save each month.
Depending on the size of your system and other factors, you may be able to eliminate electricity bills entirely.
The average electricity bill in South Africa varies based on location and other factors, such as whether you are on billing or prepaid.
Where you live does play a role in how much you pay per kilowatt-hour (kWh), but pricing is primarily based on Eskom’s rates.
Unfortunately, Eskom rates keep going up — the latest proposed increase for 2025 is about 36%.
According to Business Tech:
 “[The average household] will pay R2,960 more per month for electricity than they did in 2010—an increase that is far above inflation over the same period…
In contrast,
hybrid solar solutions are proving to be a far more affordable and sustainable alternative, offering households the opportunity to reduce their reliance on the national grid.”
When it comes to solar, the higher your on-grid electricity rate, the more money you’ll save — and eventually earn — per kWh of power your system generates.
Solar power is renewable
There are no ongoing costs for the electricity your system produces once you initial expenses are paid off.
Peak Demand and Time of Use
If you opt for a hybrid (solar + storage) PV system, there’s another way you can save money and increase ROI.
Look closely at your most recent electricity bill.
Chances are you’re being charged a different power rate during peak electricity time
Unlike on-grid inverter + PV module systems, hybrid PV solutions store the electricity your panels generate in a solar battery for later use.
By only using Eskom power during off-peak hours, you can save a substantial amount of money.
For example, EcoFlow DELTA Pro can store up to 25kWh power and deliver 7.2kW of AC output.
The EcoFlow app makes it virtually effortless to avoid using utility power charged at a higher time-of-use rate.
Even more importantly, 25kWh is enough power to run most homes for up to a week during a blackout.
It will more than cover you during load-shedding—even at the higher stages—and for Eskom load reduction periods.
(Source: Government Victoria)
Net Metering and Feed-In Tariffs
Feed-in tariffs and net metering are billing mechanisms between you and your electricity provider that enable you to transmit electricity your PV system generates in excess of consumption back to the power grid.
Net metering is still not widely available in South Africa.
However, NERSA proposed a net-billing tariff measure in 2023 that could eventually make feeding-in from residential PV systems more widespread.
The Western Cape’s 110% Green program offers Small-Scale Embedded Generation (SSEG) Feed-In Tariffs to many residents, enabling them to save money on electric bills.
Even in countries where net metering programs are mandatory, it’s rare for homeowners to turn a profit by selling electricity to their electricity provider.
Instead, people earn credits towards their electricity bill against power consumed from the grid.
The rate that power companies offer for electricity you sell to them is typically lower than what you pay for energy you consume from the grid.
In most instances, savings from self-consumption provide a better return on investment than selling the electricity your photovoltaic system generates.
Going Off-Grid?
Do you even need to consume Eskom electricity if you have a home solar panel array?
All renewable energy sources — like wind and solar — are intermittent.
Wind turbines don’t generate power on still days.
Solar panels don’t work at night.
Residential photovoltaic systems solve the problem of intermittency in one of two ways:
  • Energy storage
  • Connection to the national grid
Grid-connected systems typically cost less upfront than solar + backup battery storage solutions because they require fewer components.
Unfortunately, no matter which type of grid-tied renewable energy system you choose, they all have a substantial drawback.
Grid-tied solar, wind, and hydroelectric systems automatically shut down during a blackout and must remain offline until power is restored to the grid.
If you’re concerned about home energy security, a hybrid solar + storage system is a much better solution than being tied to the grid.
Your peace of mind is likely worth more than any money you save with a lower initial investment.
Government Incentives
Transitioning from burning fossil fuels for electricity generation to renewable energy sources like solar, wind, and hydropower is a global priority for governments and organisations worldwide.
Unfortunately, South Africa has been slow to incentivise individuals to adopt renewable power, and many utility-scale projects have stalled.
The Solar Energy Tax Credit was instituted in March 2023 to encourage consumers to purchase home solar power systems.
It offered 25% of the purchase and installation cost of new solar panels against provisional tax liability, capped at R15,000 per taxpayer.
Unfortunately, eligibility for the program ended on 29 February 2024 and no federal schemes have emerged to take its place.
However, there may be incentives at the provincial and municipal level, depending on where you live.
New programs are announced regularly, and existing ones are subject to change.
Do your research before purchasing a residential solar power system.
Don’t leave money on the table.
How To Calculate the Solar Payback Period
Calculating how long it will take for your photovoltaic system to recoup your upfront investment is an imperfect science.
At best, you’ll end up with a rough estimate of how many years it will take before you break even and your solar panels start making you money.
This is as true for utility-scale renewable energy systems as it is for rooftop solar.
There are simply too many variables to predict with 100% accuracy, including:
  • Available sunlight
  • The price of electricity generated by burning fossil fuels
  • Unforeseen events
All investments are inherently unpredictable to a certain extent.
But that doesn’t mean there isn’t value in determining a reasonable estimate of how long solar payback will take — and the eventual return on your investment.
Here’s how.
Solar Payback Formula
Here is the formula for calculating your solar payback step-by-step.
1. Total Your System and Installation Costs
Start by adding up all of your initial purchase and installation costs. Depending on whether you opt for an all-in-one solar generator or solar panels with separate balance of system components, your calculation should include the following items:
  • Photovoltaic modules (solar panels or shingles)
  • Solar inverter
  • Charge controller*
  • Solar Battery*
  • Monitoring system
  • Cables & wiring
  • Mounting hardware
  • Transfer switch (for integration with home circuit board)
  • Bidirectional or smart meter**
* For off-grid and hybrid systems
** For grid-connected systems
  • Installation costs
  • Permitting costs (if required)
2. Subtract Solar Incentives
Deduct any federal, state, municipal or utility provider incentives (such as tax rebates or credits) from the figure you calculated in step one.
3. Add Financing Costs
If you take out a loan or finance your residential solar power system, make sure to factor in interest and other expenses.
4. Estimate Annual Spending On Electricity Bills
The simplest way to estimate your annual spending on electricity is to add up the previous year’s bills. Or you can calculate your home kWh usage and multiply it by the average power rate. Don’t forget that electricity prices vary significantly over the course of the year — particularly in the winter months.
5. Forecast Electricity Generation From Your Solar Power System
All solar energy systems that generate electricity do so using the photovoltaic effect, which converts photons from visible sunlight into direct current (DC). It’s essential to recognise that PV modules don’t always generate their full rated power output (watts) during the day. There’s much more to predicting electricity output than adding up the rated power wattage of your solar panels and multiplying that by daylight hours. Learn how to calculate solar panel output.
6. Estimate Net Metering or Feed-In Credits
If you elect to purchase a grid-connected system and your utility provider offers net metering, estimate the annual savings you can expect based on your PV arrays’ output and the billing arrangement.
7. Calculate Your Solar Payback Period
Once you’ve made all of the above calculations, divide the net cost of your system (minus incentives + financing costs) by your expected electricity bill savings (annual spending minus the rand amount your PV array generates and net metering credits).
The result indicates the number of years your residential solar power system should take to recoup expenses.
Once you’ve achieved solar payback, ongoing electricity bill savings go straight to your wallet.
Money Saved is money earned.
Here’s an example of calculating the break-even point for a R40,000 system (including parts and installation).
  • Subtract the total solar incentives from your system cost. Assuming you qualify for R10,000 in combined incentives, the net cost of your system would be R30,000 (R40,000 – R10,000).
  • Add financing expenses (interest, fees, etc.) over the system’s lifetime to the net cost. For example, if you receive a low-interest 10-year amortised loan at 3% interest (APR), your total interest cost is about R6,300 (exclusive of fees.)
  • Total your electricity bill savings. The average electricity bill in South Africa is around R1000 per month (R12,000 p/a). If your solar power system generates 80% of your household electricity, your annual savings is R9,600. (R12,000 x 0.80)
  • Calculate payback period: Divide your system’s net cost of R36,300 (R40,000 – R10,000 + R6,300) by your annual savings (R36,300 / R9,600) = ~4 years
In the example above, it would take about 4 years to break even on your solar investment.
According to the Western Cape Government:
“The repayment of a solar PV system is close to 5 years, depending on certain factors like your electricity demand and your current electricity tariff structure. With solar panels that have a 20 – 25 year production warranty, it’s very much like buying 25 years’ prepaid electricity at 5 years’ cost.”
Once you achieve solar payback, the electricity your system generates is free and clear.
How To Calculate ROI for Solar Panels
Return on investment (ROI) is related to the solar payback period.
Instead of calculating the time it takes to break even, ROI estimates the total savings and earnings a home photovoltaic system can be expected to deliver during its lifetime.
Here’s a simplified version of the formula:
Lifetime Cost of Solar Power System – Lifetime Electricity Bill Savings = ROI of Solar Panels
Despite constant exposure to the elements, high-efficiency monocrystalline and polycrystalline silicon solar panels have an average lifetime expectancy of 25 years or more.
Many rigid solar panels don’t require replacement for over three decades.
If you purchase the right system, the ROI calculation will result in a negative number that reflects the amount of money you’ve earned by investing in solar power.
For example, if your net system cost is R36,300 and your electricity bill savings are R9,600 per year for 25 years (R240,000), your solar panel ROI is R203,700 (561%).
What Factors Affect Solar Power ROI?
There are many variables to consider when determining your return on investment (ROI): electricity costs in your area, local and state incentives, the warranty on your panels, permits, maintenance, and more.
Here are the top factors to consider:
Purchase and Installation Costs
Solar panel equipment and installation costs are the steepest financial hurdle to overcome.
A full-sized residential system often costs R50,000 or more, depending on location, installation and equipment purchase costs.
Government incentives are sometimes available to lower this initial cost.
Utility Grid Electricity Prices
The price of on-grid power ultimately determines the ROI of your system.
Of course, determining how much money you can earn on your home solar investment ignores significant additional benefits like reducing your carbon footprint to aid in the struggle against climate change and providing energy security for your family.
Putting a price tag on the intangible benefits is impossible, so electricity bill savings are a primary factor in determining financial return on investment.
In a nutshell, the higher the power rate at your location, the more money you stand to earn.
Maintenance
Residential solar systems require very little routine maintenance.
Aside from semi-annual cleaning and clearing your panels of obstructions like snow, you can set it and forget it.
Of course, solar panels occasionally fail, wiring and connections can degrade, and balance of system components like solar batteries only last so long.
That said, such failures are increasingly rare, thanks to ongoing advancements in solar panels and LiFePO4 battery technology.
Solar panels typically last 25-30 years or more, meaning you’ll recoup your investment long before the system experiences any serious issues.
Additionally, as more people opt to purchase solar power systems, the costs of replacement parts are likely to decrease drastically over time due to economies of scale.
Fees and Permits
Many provinces and municipalities offer incentives for solar power adoption.
But fees and permits may also be required to ensure safe installation and compliance with net metering programs or feed-in tariffs (for grid-connected systems).
Pre and post-installation inspections are required in many parts of the country.
Depreciation
Unlike many big-ticket purchases, solar panels have an extremely low depreciation rate.
New cars are famously said to lose half their value the minute you drive them off the lot, but that’s not the case for PV modules.
With an average lifespan of over 25 years, there’s a good chance that your solar panels may outlast the roof you install them on.
However, like everything else, PV modules aren’t completely immune to ageing.
According to NREL, the efficiency of crystalline silicon PV modules decreases by about 0.5% a year over time.
Solar panel efficiency is a specific metric that measures how much electricity a solar panel can generate per square meter of photovoltaic cells under ideal conditions.
On average, a solar panel array will generate about 80% of its initial output capacity after 25-30 years of use.
What Is a Good ROI for Solar Panels?
When calculating return on investment for home solar panel (photovoltaic) systems, it’s essential to remember that it will take some time to break even on your initial expenses. The solar payback period typically takes 8-12 years. An annualized ROI of 10% per year is considered a healthy return on investment. Most PV modules last over 25 years, leading to many years of electricity bill savings.
Don’t let the initial expense of investing in a residential solar power system put you off.
Most homeowners realise a significant return on investment over time, often in the double digits annually.
EcoFlow’s solar generators use high-efficiency PV modules to provide everything from portable off-grid power for outdoor adventures to whole-home battery backup.
Check out our selection today.
