How Many Panels in a 5kW Solar System?
Embarking on the journey toward energy security?
Depending on the size of your household, a 5-kilowatt solar system can be an excellent investment.
Navigating the panel selection process requires a deep dive into panel efficiency, space considerations, and power needs.
In today’s blog, we’ll demystify the variables and lay out a clear path to harnessing solar power efficiently. With an emphasis on high-quality options, such as those offered by EcoFlow, you’ll be poised to make an informed decision to power your home sustainably and reliably.
What Is a 5kW Solar Power System?
A 5kW solar panel system can deliver up to a maximum of 5 kilowatts for at least part of the average day in your location.
No solar system — no matter how big — can produce electricity at night.
If you’re shopping for an on-grid solar system, it will automatically switch to Eskom power when electricity production is insufficient for your household consumption.
If you’re going off-grid altogether, the electricity stored in your solar batteries must keep your house running at night.
It’s essential to understand the distinction between kilowatts (kW) and kilowatt-hours (kWh) when shopping for any solar power system.
Watts and kilowatts measure how much electricity a system can output at any given moment.
Watt-hours (wH) and kilowatt hours (kWh) measure how much electricity a system can deliver over time.
Simply put, kW indicates the maximum number of appliances you can operate simultaneously.
Kilowatt-hours (kWh) measure how long you can run them for.
You may be familiar with kWh from your electrical bills. That’s how utility companies measure your electricity consumption.
Understanding kWh is essential if you’re considering purchasing an off-grid solar power solution. You’ll need sufficient solar battery storage capacity (measured in wH/kWh) to keep your house running at night. Or at other times when your solar panels aren’t generating sufficient electricity to meet your needs.
How Many Solar Panels Do I Need for a 5kW System?
The number of solar panels you’ll need to reach a 5kW AC output capacity depends primarily on the type of solar panels you choose and their individual power output.
Some solar panels will have higher electricity yields than others. Additionally, the rated power of each panel helps determine the total number you’ll need. A panel with a higher rated power, like EcoFlow’s 400W Rigid Solar Panel or 400W Portable Solar Panel, means you’ll need fewer panels that produce lower wattage to achieve your energy goals. But you should be prepared for panels with a higher rated power to be of a larger size.
Let’s explore how these variables shape your solar energy system.
EcoFlow DELTA Pro | Expandable Home Backup Power
DELTA Pro integrates seamlessly with your existing wiring to provide uninterrupted power in a blackout. Expandable to 7.2kW of AC output and 25kWh of LFP battery storage. Recharge with solar panels, household electricity, EVSE, or an inverter generator. Keep your whole home running during extended outages.
Solar Panel Type
There are two main types of solar panels to consider – monocrystalline and polycrystalline. But before we get into that, it’s essential to understand what “efficiency” is in terms of solar panels.
Solar panels have an efficiency rating, expressed as a percentage, representing how much sunlight your solar panel can convert into electricity. For example, a solar panel with 20% efficiency converts around 20% of the sunlight it captures into usable electricity.
The more efficient your solar panels are, the more you’ll be able to get out of your available space.
Now, let’s talk about monocrystalline versus polycrystalline solar panels.
Monocrystalline Panels
Monocrystalline solar panels, constructed from a single, high-quality crystal structure, offer better efficiency than their polycrystalline counterparts.
By opting for monocrystalline silicon cells like those EcoFlow offers, you maximise your space and ensure a higher energy yield. Their sleek design and longevity make them a superior choice for a robust 5KW system.
Polycrystalline Panels
Polycrystalline panels, on the other hand, are made from multiple silicon crystals. They’re more cost-effective but tend to have a lower efficiency rate compared to their monocrystalline counterparts.
For those prioritising efficiency and space-saving, monocrystalline panels are recommended.
Solar Panel Output
Considering the rated power output of each solar panel is critical when planning a 5kW system. This figure, typically measured in watts (W), indicates the amount of electricity a single panel can produce per hour under ideal laboratory conditions.
However, it’s important to note that Standard Test Conditions will rarely exist in reality.
For that reason, solar panels don’t always produce their full rated power wattage during daylight hours.
To reach a 5kW capacity, you’ll need to consider the wattage of individual PV panels. For example, with 400W panels, fewer units are needed compared to 100W panels.
The higher the output per panel, the fewer panels you require. Of course, you can usually expect solar panels with a higher rated power to be larger and take up more space than a  panel with the same efficiency rating and a lower rated wattage.
How Many Monocrystalline Panels Do I Need for a 5kW System?
For those taking their initial steps with solar power, a 5kW system is an excellent choice, balancing the energy demands of a typical home with the benefits of solar technology. On average, South Africans consume around 300kWh of electricity monthly per capita.
However, for homes of four bedrooms or more and multiple occupants, monthly electricity consumption is likely to be closer to 800kWh or more.
A 5kW setup is considered relatively small, but these setups often have enough energy to meet the needs of a household. Whether this is the case for you will vary based on your electricity usage.
Let’s say you choose EcoFlow’s 400W Rigid Solar Panel, a monocrystalline option boasting an impressive 23% efficiency rating.
To determine how many panels you need, it’s essential to consider the following factors:
  • Average peak sunlight hours in your location
  • Temperature
  • Shading
  • Available surface area that receives direct sunlight and is suitable for installation
All of the factors above will significantly impact how much electricity a solar power actually produces, regardless of its rated power wattage.
A helpful rule of thumb for estimating the electricity output of a high efficiency solar panel is to assume it will produce 75% of its rated power wattage during daylight hours.
Again, using the EcoFlow 400W solar panel as an example, you can estimate that it will produce 300W of electricity during daylight hours (400W x 75%).
For 5kW of electricity generation potential, you would need an estimated 17 400W solar panels (5000W / 300W = 16.66).
It’s essential to remember that the above is just a helpful way to achieve a rough estimate of how many solar panels you’ll need.
If you want to ensure you don’t buy too few solar panels (or too many) to meet your electricity production needs, learn more about calculating solar panel output.
How Much Roof Space Do I Need for a 5kW Solar System?
The space required for a 5kW solar system depends on the size of your solar panels and the number of solar panels you need to achieve 5kW of electricity generation on an average day.
Choosing the right panels is essential to get the most out of your space. While portable solar panels are ideal for those on the go, you’ll want to opt for rigid panels for a permanent installation.
Remember, monocrystalline solar panels are more efficient than their polycrystalline counterparts – meaning you’ll get more electricity production out of your available roof space.
Calculate how much roof space you need based on the dimensions of your panels. Keep in mind that, for safety reasons, you’ll want 25% of your roof to remain free of panels.
Remember, proper spacing between panels is crucial for maintenance and performance, so the actual area required will be somewhat larger.
Always consult a professional installer to ensure your roof can accommodate the system with the necessary spacing and positioning while maintaining structural integrity.
Purchasing a 5kW solar installation is one of the most significant steps you can take towards sustainable living.
Selecting a system that meets your electricity production needs requires careful consideration of panel types and energy output.
Opting for high-quality monocrystalline Ecoflow solar panels ensures industry-leading efficiency and durability.
Discover how EcoFlow can illuminate your path to clean energy.
Explore our range of solar solutions tailored for varied needs and spaces, and join the green revolution today.
