EcoFlow DELTA Series Comparison: Which Portable Power Station Should You Get?
The EcoFlow DELTA series offers industry-leading portable power stations for home backup, power outages, and outdoor adventures. This portable power station comparison breaks down performance by capacity, output, portability, solar capability, battery chemistry, and more, helping you quickly find the right product for you.
0
3859
[elementor-template id=”313″]
6 Tips for Choosing a DELTA series Portable Power Station
EcoFlow DELTA portable power stations come in all shapes and sizes, with plenty of features that give you power for pretty much any situation. Before we start comparing each unit, we’ve prepared a simple breakdown of 6 tips to consider when choosing a portable power station. Here’s everything you need to know.
First off on the list we have capacity. A portable power station with a large capacity gives you power for almost any situation. The larger the capacity, the more runtime you have, which means you can stay powered on for longer. If you’re looking for everyday power for everyday devices, a portable power station with a smaller capacity can get the job done. Or, if you’re in the market for emergency power or home backup during outages, consider getting a portable power station with a big expandable capacity, like the new EcoFlow DELTA Pro.
Output
More output means more power options. Get a portable power station with a high output so you can power your appliances like fridges, dryers, or even power tools. All EcoFlow portable power stations come with X-Boost technology, which extends the output just in case you need to power the heavy-duty stuff.
Portability
Nobody wants to lug around a huge battery on road trips, off-grid adventures, or even at home. If you’re looking for a portable power supply that’s easy to transport, portability is a must. Smaller portable power stations like the EcoFlow DELTA mini or the EcoFlow DELTA combine the best of both worlds, giving you a large capacity and a lightweight power supply for power on the go.
Fast Charging
When disaster strikes, having a portable power station that charges up quickly makes a world of difference. And even if there isn’t a power outage, chances are you don’t want to wait around for half a day to charge up. All EcoFlow portable power stations feature X-Stream fast charging, which lets you safely and rapidly charge up quickly. Newer additions to the EcoFlow DELTA series like the EcoFlow DELTA Pro feature brand-new charging methods like 6500W MultiCharge.
If you’re looking for a renewable power supply to give you more charging convenience, portable power stations with solar charging options are a must. Most battery generators have solar charging integration, but some give you higher solar inputs, which means you can charge up faster with clean solar generation.
Whether you call it a portable power station or a solar generator, they’re all fundamentally battery-powered devices. One other thing to look out for is the battery chemistry and battery management system that they use. EcoFlow portable power stations all come with a unique battery management system that regulates current, voltage, and temperate in real time. The type of battery chemistry will depend on the type of application you use your battery for. For example, LFP batteries, such as those found in the new EcoFlow DELTA Pro portable home battery, are designed to give you the most battery life cycles for years on end. Other DELTA series portable power stations sport NCM batteries, which favour smaller, lighter, and more portable setups.
That covers the most important things to consider when choosing a portable power station. Read on to compare EcoFlow DELTA series portable power stations.
EcoFlow DELTA Pro
Capacity: 3.6-25kWh Expandable Capacity
A huge 3.6-25kWh expandable capacity means you can power your home during extreme blackouts for days on end. A single DELTA Pro unit gives you 3.6kWh of capacity, which you can use for several hours of heavy-duty use. And if that’s not enough, you can expand your capacity up to a huge 25kWh. That’s enough capacity to power you through almost anything.
Output: 3600-7200W Expandable AC Output
With a single DELTA Pro unit, you have access to a 3600W AC output, which expands up to 4500W with X-Boost. This massive AC output is ideal for powering window air conditioners, washing machines, and other heavy-duty devices. If you require even more output, you can connect two DELTA Pro units together with the EcoFlow Double Voltage Hub. That will give you 7200W, 240V, which is more than enough to power your electric heaters during a storm, dryers, and other heavy-duty devices. And it doesn’t stop there either. The EcoFlow DELTA can be connected to your home circuits with the EcoFlow Smart Home Panel, giving you 7200W directly through your home circuits. In other words, that’s all the AC output you’ll ever need.
Portability: New Wheelable Design
DELTA Pro has a new upgraded design compared to other DELTA series portable power stations. It features two wheels at the bottom of the unit and an extendable handle, which means you conveniently carry 3.6kWh of power around.
Fast Charging: 6500W MultiCharge
Yep, you read that right. The EcoFlow DELTA Pro offers a record-breaking 6500W MultiCharge feature that lets you charge up as quickly as 1.8 hours.
Solar Charging: 1600W Solar Input & Rooftop Solar Integration
If you’re looking for a solar generator to upgrade your home with cost-effective renewable energy, DELTA Pro ticks all the boxes. Not only does it give you an extra way to stay powered up, but it also helps you lower your daily energy bills. Get rooftop solar integration and up to 1600W solar input to charge DELTA Pro in as quick as 2.8 hours. For off-grid power, you can also connect portable EcoFlow solar panels to the DELTA Pro. And for an extra level of convenience, the 11-150V voltage range makes DELTA Pro compatible with 90% of third-party solar panels with solar panel connectors.
Battery Chemistry: New LFP Battery
The DELTA Pro is the only portable power station in the EcoFlow DELTA series to sport an LFP battery. As a portable home battery, LFP batteries offer 6500+ cycles, which means you can continue to use it for years on end before it reaches 50% of its original capacity.
EcoFlow DELTA Pro: The Final Verdict
In addition to having the biggest capacity, output, and the most advanced power options of all the DELTA series portable power stations, DELTA Pro also integrates with an entire ecosystem of products, including the EcoFlow Smart Generator, Extra Batteries, the Smart Home Panel, and more. Throw in 3400W EV station charging, 6500W MultiCharge, smart energy management, and more — you’re looking at the most advanced leap in portable power station technology to date.
EcoFlow DELTA 2 Max
The EcoFlow DELTA 2 Max is a portable power station built for home backup and power outages. You get an expandable capacity up to 6kWh, dual charging, a 1000W solar input, and brand-new features to help you stay powered on during any emergency.
Capacity: 2-6kWh Expandable Capacity
A single DELTA 2 Max unit offers a huge 2048 Wh of capacity, which gives you hours of runtime to power your devices. You can even expand up to 6kWh with up to 2 EcoFlow DELTA 2 Max Smart Extra Batteries, ideal for powering your home devices during extended blackouts.
Output: Huge 2400W AC output
Just like the DELTA Pro, DELTA 2 Max features X-Boost technology, which lets you power heavy-duty devices with ease. DELTA 2 Max offers a huge 2400W AC output and 4800W on X-Boost that keeps your fridge, dryer, and other devices running in a power outage.
Portability: 2kWh at 22 kg
DELTA 2 Max weighs in at around 23 kg (50.7 lbs), which puts it at the heavier end of the EcoFlow DELTA series. Despite this, it still retains a handheld design so it’s easy to move around. This means you have a 2kWh battery that can be transported easily, wherever you are.
Fast Charging: 3400W Dual Charging
With just a single DELTA 2 Max and a wall outlet, you can charge up from 0-80% in just 1.1 hours. Want to turn it up a notch? You can also combine AC wall charging with solar charging to get from 0-80% in just 43 minutes with dual charging. The choice is yours.
Solar Charging: 800W Solar Input
One of the best things about solar charging is it gives you a clean, reliable way to stay in power during tricky situations. The EcoFlow DELTA 2 Max steps up to the table with a large 1000W solar input, which you can achieve by connecting it to 2x 400W EcoFlow Solar Panels or 4 220W Bifacial Solar Panels. It also has an 11-600V voltage range and a solar panel connector, letting you connect other third-party solar panels if need be. And even during cold or cloudy days, the EcoFlow MPPT algorithm automatically detects the voltage and current to give you the most efficient charging possible. Solar generation doesn’t get much easier than this.
Battery Chemistry: NCM Battery
The EcoFlow DELTA 2 Max utilizes an LFP battery and the EcoFlow Battery Management System. That means you get a battery that lasts for years. 3000 cycles to 80% capacity to be precise.
EcoFlow DELTA 2 Max: The Final Verdict
If you’re looking for a portable power station for home backup, power outages, or just to give you and your family peace of mind, the EcoFlow DELTA is a reliable and industry-leading option. In addition to an expandable output, you also get dual charging, which gives you three ways to charge up, as quickly as 0-80% in43 mins. DELTA 2 Max also pairs up with the EcoFlow Smart Generator for emergency backup power. There’s also an EcoFlow app that lets you control and monitor DELTA 2 Max remotely.
EcoFlow DELTA 2
The EcoFlow DELTA 2  is still one of the best portable power stations on the market. It has a big 1024Wh capacity that lets you keep your essential devices charged up during power outages. It also weighs only 12 kg, which makes transportation and powering up on the go a walk in the park.
Capacity: Large 1024Wh Capacity
With a 1024Wh capacity, the EcoFlow DELTA gives you enough runtime to charge essential devices like lights (10W), a fridge (120W, AC), a microwave (1300W, AC), and more. Output: Huge 1800W AC output
The EcoFlow DELTA has 6x 1800W AC outlets that provide enough power for essential devices and power tools. You can power up several devices at the same time, which keeps the whole family powered on during blackouts.
Portability: 12 kg Lightweight Design
Portable power stations are designed to be light. Use them at home, throw them in your truck, and carry them around during off-grid trips. The EcoFlow DELTA 2 is no exception to the rule, weighing in at around 12 kg and sporting a simple grip design for easy carrying.
Fastest Charging
The EcoFlow DELTA was the first EcoFlow portable power station that featured fast charging. It can charge up from 0-80% in just 50 hour, setting the standard for battery-powered generators.
Solar Charging: 500W Solar Input
Looking for a solar generator? Connect up to two EcoFlow 220W solar panels to DELTA to charge up with 440W as quickly as 3-6 hours. Say hello to clean, green solar power.
Battery Chemistry: LFP Battery
The EcoFlow DELTA features an LFP battery. The EcoFlow Battery Management System automatically regulates current, voltage, and temperature. In terms of the battery lifespan, you’re looking at 3000 cycles to 80% capacity.
EcoFlow DELTA 2: The Final Verdict
The EcoFlow DELTA 2 is your best bet if you’re looking for a reliable portable power station for emergencies or a portable power supply for off-grid adventures. It has a big 1024Wh capacity, 4 AC outlets 1800W total, and charges up super quickly. Power your essential devices and stay in charge with the EcoFlow DELTA 2.
EcoFlow DELTA Series: Compare Specs
[elementor-template id=”339″]
The EcoFlow DELTA 2 series offers the best portable power stations for home backup and emergencies. From lightweight options like the DELTA 2 all the way to portable home batteries like the DELTA Pro, our industry-leading DELTA 2 series portable power stations give you power for every type of situation.
