Table of Contents
How can you charge lithium-ion batteries by harnessing the power of sunlight? Here, we cover what lithium-ion batteries are, including LiFePO4 batteries – a type of lithium-ion battery chemistry – and how you can charge your EcoFlow portable power station using solar panels.
Let’s dive in!
What Are Lithium Ion Batteries?
Lithium-ion batteries are a type of rechargeable battery that is charged and discharged by lithium ions moving between negative and positive electrodes.
They are a suitable option to store high-capacity power, making them excellent for use in various scenarios, including smartphones, cars, computers, and more.
Lithium-ion batteries come in different shapes and have varying current capacity and nominal voltage.
What Is a LiFePO4 (Lithium Iron Phosphate) Battery?
One type of lithium-ion battery is a LiFePO4 battery, also known as a lithium iron phosphate or LFP battery. These have grown in popularity due to their safety, efficiency, and long lifespan. Due to their many benefits, you might see this technology used in backup power systems, off-grid energy storage, electric vehicles, and portable electronics.
This battery chemistry is used in many of EcoFlow’s portable power stations. They offer a longer life cycle, greater discharge capacity, and more safety. Not only that, but unlike traditional lithium-ion batteries, these batteries are cobalt and nickel-free.
What Do You Need to Charge Lithium Ion Batteries with Solar Panels?
If you want to charge a lithium-ion battery using solar panels, you’ll need the rest of the components of a solar power system to accomplish this.
Balance of system refers to the components – aside from PV panels – necessary for a solar power system to function. This could include some or all of the following:
- Solar battery
- Solar inverters
- Charge controller
- Battery Management System (BMS)
- Mounting hardware
- Wiring
Ensure you have all of the components necessary for your system, which could vary depending on your gear.
The good news is that EcoFlow’s portable power stations are all-in-one systems that include the balance of system components.
What Size Solar Panel Do I Need to Charge a Lithium Battery?
The first thing you want to keep in mind is compatibility. Make sure that the solar panel you’re using is compatible with the rest of your balance of system components.
The size of the solar panel you should have to charge your lithium battery depends on a number of factors, including the capacity of your battery, how quickly you want your battery to charge, and more.
How Long Does It Take a Solar Panel to Charge a Lithium Battery?
The amount of time it takes for your solar panel to charge a lithium-ion battery depends on a range of factors, including the rated power and efficiency rating of your solar panel, the amount of sunlight your solar panel is receiving, the capacity of your battery, and more.
How Do You Charge Lithium-Ion Batteries Using Solar Panels?
Before you charge your lithium-ion battery using solar panels, ensure you’re operating within the manufacturer’s guidelines for all of your gear. Ensure you use products safely to avoid damaging your equipment or causing unsafe situations.
The process to charge lithium-ion batteries with solar panels varies depending on the equipment you’re using. Make sure to familiarise yourself with the correct process for your specific equipment.
Below, we’ll detail how to charge one of EcoFlow’s portable power stations using solar panels. Most of EcoFlow’s portable power stations use LiFePO4, a type of lithium-ion battery.
1. Plan Your Layout and Obtain and Test Gear
You should begin by getting all the gear you need and ensuring everything is compatible. The EcoFlow RIVER Series portable power stations are great for on-the-go power, while the EcoFlow DELTA Series portable power stations offer more robust power solutions.
In the case of using an EcoFlow portable power station, because all the balance of system components are included, you’ll just need your EcoFlow portable power station, solar panels, and the necessary wiring and mounting hardware.
You can’t just use any solar panel with your EcoFlow portable power station. You need to make sure it’s compatible, including ensuring your battery has the required solar charging input for the solar panel you’re using.
In planning your layout, you’ll want to find the ideal positioning and wiring for your circumstances. This planning includes considering:
- Available surface area
- Average peak sunlight hours
- Obstructions
- Distance between panels
- The cable run from the last panel in the array to your portable power station
- Ambient temperature
- Direction, angle, positioning, and tilt
You’ll want your panels aimed as directly towards the sun as you can manage. The best angle will depend on where you’re located.
Planning your layout also includes deciding if you want to connect your solar panels in parallel, series, or series-parallel.
Make sure you test your chosen configuration before installing your solar panels on your roof to avoid needing adjustments once your panels are roof-mounted. It’s best to test them outside in direct sunlight.
Your panels should produce roughly 75-100% of their rated power in direct early afternoon sunlight – no PV panel will produce its full-rated power all day long. If your panel produces significantly less, you may need to make adjustments or contact support.
2. Place Your Panels and Connect Your Cables
Now that you’ve planned the ideal place and way to set up your panels, it’s time to get them placed and connected.
Depending on your type of solar panels, this may include mounting them on your roof or elsewhere if you’re using EcoFlow Mountable Solar Panels. If you opt for EcoFlow Portable Solar Panels, these allow for an even easier setup.
Assemble the mounting hardware according to the instructions and mount your solar panels if necessary. Then, connect your solar panels in series or parallel. You should have already decided which method best benefits your setup. Read more about the difference between series and parallel wiring here.
Next, it’s time to connect your solar panels to your inverter or EcoFlow portable power station. Connect the panel closest to the EcoFlow portable power station using the appropriate cable. Remember, your battery must be sheltered in weatherproof conditions.
Shorter connections are more efficient; with longer cables, more electricity is lost in transmission.
3. Test Your System
It’s time to test your system to ensure it works properly. You may need to test it for several days or a week.
Optional: Connect the System to Your Home Circuit Board and Wiring
If you want a seamless connection with your home, you can connect your collar panels to your home circuit board and wiring. This is an option with some EcoFlow portable power stations and should not be attempted without a licensed electrician under any circumstances.
You’ll need an EcoFlow Smart Home Panel or a transfer switch to do this, and a licensed electrician should complete it to avoid breaking the law and putting the safety of your home and life at risk.
What Are Lithium-Ion Batteries Used For?
Lithium-ion batteries have a wide range of uses, including:
- Toys
- Electronics
- Wireless Headphones
- Small and large appliances
- Handheld power tools
- Electric vehicles
- Electrical energy storage systems
EcoFlow uses LiFePO4 batteries, a type of lithium-ion battery, in EcoFlow Portable Power Stations and EcoFlow Power Kits. Lithium iron phosphate batteries offer advantages, including a longer life cycle, more discharge capacity, safety, and less humanitarian and environmental impact.
EcoFlow has a wide range of power solutions that are suitable for everything from keeping personal electronics charged on your next camping trip to whole-home solutions that can provide energy independence. There’s a power solution for everyone at EcoFlow.
Charging a lithium-ion battery with solar power is an eco-friendly way to keep your battery charged. EcoFlow portable power stations come in various capacities and specs for different uses and are compatible with solar charging.
Want access to environmentally friendly and reliable power anywhere there’s sunlight? With EcoFlow, it’s easy. Browse our selection of EcoFlow portable power stations and EcoFlow solar panels today!
