Table of Contents
There are tons of reasons to want a home generator. Whether it’s to offset electricity usage during peak hours, go completely off-grid, or as backup electricity during an outage, the right generator for you is out there.
In this post, we cover EcoFlow’s top generators for homes. Check them out below, as well as some things to keep in mind when shopping for your ideal generator.
EcoFlow’s Top Generators for Homes in 2024
- Best Entry-Level Generator: EcoFlow DELTA 2 + 220W Solar Panel
- Best Short-Term Solutions for Appliances: EcoFlow DELTA Max + 400W Rigid Solar Panel
- Best for Load Shedding: EcoFlow DELTA Pro + 400W Solar Panel
If you want a tremendous entry-level backup power solution, the EcoFlow DELTA 2 is a great place to start your search! The EcoFlow DELTA 2 is an excellent option for home backup or everyday appliances, and it’s versatile too – with the option to add the EcoFlow DELTA 2 extra battery or the EcoFlow DELTA Max Extra Battery for even more capacity.
The EcoFlow 220W Bifacial Portable Solar Panel this generator features an innovative design with a 220W primary side paired with a 155W back side for ambient light. This unique design allows you to capture as much as 25% more solar energy. This results in even faster charging times for your EcoFlow portable power station.
The large AC output allows you to power over 90% of home appliances, including your fridge, coffee maker, and microwave. Or, you can plug in up to 13 devices simultaneously!
If you want something to keep you going during a blackout and ensure you’ve got the basics covered without going for some of the more extensive options, then the EcoFlow DELTA 2 + 220W Solar Panel is an excellent way to get started. You can even expand later by adding on an extra battery if you decide you’d like a larger capacity.
The EcoFlow App also lets you control your EcoFlow DELTA 2 to customize settings, check charging data, and adjust charging speed.
Specifications
EcoFlow DELTA 2
- Storage Capacity (Minimum): 1024Wh
- Storage Capacity (Maximum): 3kWh
- AC Output: 1.8kW continuous output (2.7kW Surge)
- Solar Charge Capacity (Maximum): 11-60V, 15A, 500W max
- Weight: 27 lbs (12 kg)
- Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
- Operating Noise Level: ~50 decibels
- Charging Options: Solar/AC/Car Charger
- Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
- Cycle Life: 3000 Cycles to +/-80% Capacity
- Depth of Discharge: 100%
- Warranty: Five years (no cycle life restrictions)
- App Monitoring and Control?: Yes
- Federal Solar Tax Credit Eligibility?: No
- Rated Power: 220W Front Side/155W Rear Side
- Efficiency: 22 % – 23 %
- Solar Cell Type: Monocrystalline
- Weight: 20.9 lbs (9.5 KG)
- Folded Dimensions: 32.3×19.7×1.3 in (82.0×50.0×3.2 cm)
- Unfolded Dimensions: 32.3×72.2×1.0 in (82.0×183.5×2.5 cm)
- Waterproof/Dustproof Rating: IP68
- Open Circuit Voltage: 21.8 V (Vmp 18.4 V)
- Short Circuit Current: 13 A (lmp 12.0 A) Front Side / 8.8 A (lmp 8.4 A) Rear Side
- Recommended Portable Power Station: EcoFlow RIVER 2 Pro/EcoFlow DELTA 2
Pros
- Bifacial design captures up to 25% more solar power
- Powers over 90% of home appliances
- Expandable with extra batteries
Cons
- Limited capacity compared to other options
- When expanded, additional batteries make it less portable
Want to be able to keep your essential appliances running in the short term if a blackout occurs? The EcoFlow DELTA Max + 400W Rigid Solar Panel could be the solution you’re looking for.
Boasting an impressive 2-6kWh expandable capacity, you can choose the size that’s right for your household and even power heavy-duty devices. Be prepared for blackouts with a fast charging time of 0-80% in just 65 minutes, and charge your EcoFlow DELTA Max using solar power in as little as 2.5 hours.
Don’t let a blackout result in a fridge full of spoiled food. With the EcoFlow DELTA Max, you can power important home devices, including your refrigerator and lights, for hours.
Capable of powering 99% of home devices, you’ll be set with a short-term solution for your appliances during a blackout. Your dryer, fridge, and more will be covered.
Keep things powered by harnessing the power of the sun with an EcoFlow 400W Rigid Solar Panel. With the EcoFlow DELTA Max, you could even connect two.
Be prepared for an outage and have the power to control your energy solution at your fingertips, thanks to the EcoFlow app.
Specifications
EcoFlow DELTA Max (2000)
- Storage Capacity (Minimum): 2016 Wh
- Storage Capacity (Maximum): 3.4 kWh
- AC Output: 2.4kW total (5kW Surge)
- Solar Charge Capacity (Maximum): 11-100V 13A, 800W Max
- Weight: 48 lbs (22 kg)
- Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
- Charging Options: Solar/AC/Car/USB-C/USB-A Charging
- Battery Chemistry: NCM
- Cycle Life: 800 Cycles to 80%+ Capacity
- Warranty: 24+12 (Registration for warranty extension)
EcoFlow DELTA Max
- Storage Capacity (Minimum): 1612 Wh
- Storage Capacity (Maximum): 2.8 kWh
- AC Output: 2kW total (5kW Surge)
- Cycle Life: 500 Cycles to 80%+ Capacity
- Rated Power: 400W
- Efficiency: 23%
- Weight: 48.1 lbs (21.8 KG)
- Dimensions: 67.8 x 44.6 x 1.38 in (1722 x 1134 x 35 mm )
- Open Circuit Voltage: 37.10 V (±3%)
- Short Circuit Current: 13.79 A (±5%)
- Recommended Portable Power Station: EcoFlow DELTA Series
Pros
- Expandable capacity
- Power heavy-duty appliances
- Fast and convenient dual charging
Cons
- Lower cycle life compared to other options
Best Expandable Whole-Home Generator: EcoFlow DELTA Pro + 400W Solar Panel
If you’re looking for the ultimate generator, look no further than the EcoFlow DELTA Pro + 400W Solar Panel. This generator can power just about anything, so you’ll never be left in the dark during a blackout. Also, with the right setup, you can even power your home off-grid.
With fast solar panel recharging and a solar panel that’s self-supporting with a protective case that easily transforms into a stand, this EcoFlow generator is a great way to keep your appliances powered in an eco-friendly and reliable way.
The EcoFlow DELTA Pro boasts six ways to charge and has a 3.6kWh capacity that can expand up to an astounding 25kWh. This makes it an ideal option for a range of power needs, and it is an excellent whole-home generator for homes with various power requirements.
Specifications
EcoFlow DELTA Pro
- Storage Capacity (Minimum): 3.6kWh
- Storage Capacity (Maximum): 25kWh
- AC Output: 3.6kW continuous output (7.2kW Surge)
- Solar Charge Capacity (Maximum): 3.2kW with 2 x EcoFlow DELTA Pro (16 x 400W EcoFlow Rigid Solar Panels)
- Weight: 99 lbs (45kg)
- Dimensions: 25 x 11.2” x 16.4” inches (63.5 x 28.4x 42cm)
- Charging Options: Solar/AC/Car Charger/Smart Home Panel/EV Charge Station
- Federal Solar Tax Credit Eligibility?: Yes, with Solar Panels*
- Rated Power: 400W
- Efficiency: 22.6 %
- Weight: 35.3 lbs (16.0 KG)
- Folded Dimensions: 41.7×24.4×1.0 in (105.8×62.0×2.5 cm)
- Unfolded Dimensions: 41.7×93,1×1.0 in (105.8×236.5×2.5 cm)
- Open Circuit Voltage: 48 V (Vmp 41 V)
- Short Circuit Current: 11 A (lmp 9.8 A)
Pros
- Expandable up to an incredible 25kWh
- Powers just about anything
- Fast solar panel charging
Cons
- More expensive than other options
Understanding the Safety Concerns of Home Generators
Different safety concerns may apply depending on your generator, such as the risk of carbon monoxide poisoning with some generators.
Whatever generator you use, it’s essential to familiarize yourself with the safety requirements and review the guidelines and safety information provided by the manufacturer.
In the case of EcoFlow’s solar generators, these generators don’t use fossil fuels and are odorless, making them convenient and safe options for providing electricity.
What To Consider When Buying a Generator for Your Home
You want to keep a number of things in mind when selecting the right generator for your home. We’ll cover a few of them below:
Types
There are different types of generators, such as gasoline, propane, and more. At EcoFlow, we sell solar generators that include an EcoFlow portable power station and an EcoFlow solar panel. This is an eco-friendly and reliable way to generate electricity and power your home even when the grid is down.
Power Requirements
When searching for the right generator, ask yourself what your power requirements are. What is the AC output required to power the electronics you want to run? What capacity will your generator need in order to run them as long as you plan to?
The answers to these questions and more will help guide you in choosing a generator with the specs you need to achieve your power goals.
Fuel Source
Keep in mind the fuel source your generator uses. If you choose a gasoline or propane generator, for example, you need to make sure you have an adequate supply of those fuels. Also, consider how easy they are to obtain, particularly during an emergency.
EcoFlow’s generators run on solar power, so you can charge them anywhere you can access sunshine.
Efficiency
How efficient is the electricity source you’re using? This is something to keep in mind when choosing a generator.
When it comes to solar panels, efficiency refers to the percentage of solar energy that shines on a PV panel that gets converted into electricity. The higher the efficiency rating, the more effectively you’re utilizing your space to generate electricity.
Budget
Budget is also an important consideration. While the initial price tag certainly matters, price over time is important to consider, too. Remember, EcoFlow’s solar generators are low-maintenance and don’t require many ongoing costs, such as fuel.
The price of a home generator can vary dramatically depending on what type of generator you’re purchasing, its capacity and other specs, and more. Consider things like the type, capacity, and AC output you’d like from your generator and try to find something within your budget.
With power outages being all too common, it’s understandable to want to ensure you have a reliable backup power source in your house, whether it’s just something short-term in case of emergencies or a whole-home generator.
Considering the specs you require from your generator to meet your goals, the type of generator you want, and more, you should be able to find the ideal home generator for your needs.
Want a reliable solar generator that’s both eco-friendly and convenient? Check out EcoFlow solar generators today to find your perfect fit!
