3 Best Generators for Load Shedding in 2025
Looking for the best generator for load shedding?
At EcoFlow, we have power solutions for just about every need. With our solar generators, you can keep your home powered during planned or unplanned outages while using eco-friendly, sustainable energy!
Below, we’ll cover our top 3 options for different scenarios to help you make the ideal choice for your household and budget.
EcoFlow’s Top Generators for Load Shedding in 2025
  1. Best for Energy Independence: DELTA 2 Max Portable Power Station
  2. Best for Reliable Power During an Outage: RIVER Pro Portable Power Station
  3. Best for Short-Term Use: RIVER Pro Solar Generator (110W Solar Panel)
If you’re looking for a powerful and expandable solution to keep your home running during extended outages, the DELTA 2 Max Portable Power Station is the ideal choice. With a massive 2048Wh capacity, expandable up to 4096Wh with extra batteries, this power station can handle the energy demands of most households. It offers a 2400W AC output, allowing you to power heavy-duty appliances like refrigerators, air conditioners, and even home entertainment systems.
The DELTA 2 Max supports fast charging through solar, AC, and car charging, ensuring you can quickly recharge between outages. With its advanced battery management system and pure sine wave output, it provides clean and stable power, making it perfect for sensitive electronics like TVs, computers, and medical devices.
Specifications
Storage Capacity: 2048Wh (Expandable to 4096Wh)
AC Output: 2400W (Surge 4600W)
Weight: Approx. 23.6 kg
Dimensions: 49.7 x 24.2 x 30.5 cm
Charging Time: 1.6 Hours (AC), 5.6-11.2 Hours (Solar)
Solar Input/Charging: 500W Max
App Compatibility: Yes, compatible with the EcoFlow app
Pros
Massive expandable capacity for long-term outages
Fast charging with multiple input options
Can power heavy-duty appliances and sensitive electronics
Cons
Higher price point compared to smaller units
For those who need a reliable power source during shorter outages, the RIVER Pro Portable Power Station is an excellent choice. With a 720Wh capacity, it can power essential devices like lights, fans, and small appliances for several hours. The RIVER Pro features a 600W AC output, which is sufficient for most household devices, and it can power up to 10 devices simultaneously. Its compact design and portability make it easy to move around the house or take with you on the go.
The RIVER Pro also supports fast charging through solar, AC, and car charging, ensuring you can quickly recharge the unit even during extended outages. Its lightweight design and durable build make it a reliable companion for both indoor and outdoor use.
Specifications
Storage Capacity: 720Wh
AC Output: 600W (Surge 1200W)
Weight: Approx. 7.8 kg
Dimensions: 28.8 x 18.5 x 19.4 cm
Charging Time: 1.6 Hours (AC), 9-18 Hours (Solar)
Solar Input/Charging: 200W Max
Pros
Compact and portable design
Fast charging with solar and AC options
Can power multiple devices simultaneously
Cons
Limited capacity for long-term outages
If you’re looking for a budget-friendly option to get you through brief outages, the RIVER Pro Solar Generator with a 110W solar panel is a great choice. With a 720Wh capacity, it can power small devices like phones, laptops, and LED lights for several hours. The included 110W solar panel ensures you can recharge the unit even during extended outages, making it a sustainable and eco-friendly option.
The RIVER Pro Solar Generator features a 600W AC output, which is sufficient for small appliances and devices. It also supports fast charging, reaching 80% capacity in just one hour, ensuring you can quickly recharge between outages. Its lightweight design and compact size make it easy to store and transport, perfect for short-term use during early stages of load shedding.
Specifications
Pros
Lightweight and portable
Fast charging capabilities
Affordable price point with solar panel included
Cons
Limited capacity for larger appliances
What to Look for When Buying a Generator for Load-Shedding
If you’re looking for the right generator to help with load shedding, there are several factors to consider. Let’s break them down a few things to consider below.
Power Output
When preparing for blackouts or planned power outages, like the different stages of load shedding, choosing a solar generator with the AC power output you need is essential.
Consider what appliances and devices you plan to keep running during the outage to help you determine the appropriate power output you need your solar generator to be able to accommodate.
Battery Capacity
Battery capacity is another essential consideration when selecting your ideal solar generator for load shedding.
How long do you need it to supply you with power?
And what appliances are you looking to operate simultaneously?
Suppose you’re just looking to power the essentials for short periods. In that case, you’ll be able to get a smaller generator than you would if you are trying to carry on with life as usual when the grid is down or if you want to keep things up and running for longer stretches of time.
Size and Durability
The size and durability of your solar generator are also considerations to factor in.
When it comes to the solar panels themselves, it’s essential to make sure that they can stand up to the elements and that you’ll have the space for the size of your solar panels and the number of solar panels you need to achieve your electricity goals.
If you’re installing solar panels on your roof, ensure that your roof is up to the task and that you have the necessary space.
What Generator Is Best for Load Shedding?
The best generator for load shedding depends on what you’re looking to power and for how long. You’ll be able to use a smaller generator if you’re just looking to power the essentials for a short period of time. But if you want to withstand more extended outages and use electricity in your house as usual, you might need to opt for something more powerful.
As you can see, there are many things to consider when choosing the right solar generator for load shedding, but there’s an option out there for every power need.
By considering the power output, battery capacity, size and durability, and more that you’re looking for from your solar generator, you can pinpoint the ideal solar generator for your needs.
Consider what you want to power and for how long, as well as what space you have available, to help make your decision.
Once you know what you’re looking for, browse EcoFlow’s selection to find the ideal solar generator to keep your house powered during load shedding and unscheduled blackouts.
