Best Camping Fridge of 2024
A camping fridge promises to enhance every wilderness adventure, making it possible to keep food and beverages fresh and cold even in remote locations. Whether planning a weekend getaway or an extended expedition, a camping fridge will undoubtedly become a go-to companion.
Finding the best camping fridge of 2024 for all of your outdoor adventures can be challenging, as there are so many brands and options available. Learn more about the EcoFlow GLACIER Portable Refrigerator and discover why it stands out as the best on the market.
When you’re on the go but unwilling to sacrifice the comforts of a cold drink and fresh ingredients that’ll last, the EcoFlow GLACIER Portable Refrigerator has you covered. With the industry’s fastest cooling for up to 40 hours with no wires needed, enjoy refrigeration and an ice maker from anywhere. With a huge 38L capacity, there’s enough space for all your food and drink needs (up to 60 330ml cans) for your whole camping trip.
While other portable refrigerators require hours to cool, the EcoFlow GLACIER Portable Refrigerator rapidly refrigerated when empty, going from 86ºF (30ºC) to 32ºF (0ºC) in just fifteen minutes. This means you can pack up and go without worrying whether your items will be chilled enough; you can be sure they will.
A weekend camping trip requires days of food and drinks, which is why the 40-hour wire-free cooling capacity of the EcoFlow GLACIER Portable Refrigerator makes it the perfect solution for multiple days and nights.
The EcoFlow GLACIER Portable Refrigerator does so much more than just cool – it also provides benefits like ample power for your other on-the-go devices, such as smartphones and laptops, so you can always stay connected.
Accessories
You can add to your EcoFlow GLACIER Portable Refrigerator to expand its uses and enhance your camping experience.
Detachable Wheels and Lever
On the move? Bring the EcoFlow GLACIER Portable Refrigerator with you by adding the EcoFlow GLACIER Detachable Wheels and Lever. Effortlessly drag it along pathways, dirt, or gravel, and bring refrigeration as close to you as possible. Then, once it’s landed at its resting place, simply remove and fit the EcoFlow GLACIER Portable Refrigerator on your countertop, passenger’s seat, or a range of other compact spaces.
Plug-in Battery
Add the EcoFlow GLACIER Plug-in Battery, with a capacity of 298Wh, so you can enjoy up to 40 hours of wire-free access to your favourite frozen meals, fresh fruits and vegetables, and ice-cold drinks.
Storage Bag
Avoid scuffs and scraps with the EcoFlow GLACIER Bag, made in a chic and durable black material that zips and secures in all the right places. With pockets to store your cables, it’s truly an all-in-one carrying case for the EcoFlow GLACIER Portable Refrigerator and all its accessories.
Specifications
  • Dimensions (no wheels or handles): 776 × 385 × 445 mm
  • Weight: 23 kg
  • Operational Volume: Single zone: 38L (40 qt.); Dual zone: 36L (38 qt.)
  • Refrigeration Temperature Range: –25°C to 10°C (–13°F-50°F) (ambient temperature at 25°C)
  • Refrigeration Power Rating: 120W
  • AC Input: 100-240V, 50/60Hz, 180W
  • Car Charging Input: 96W/192W (12/24V, 8A Max)
  • Solar Charging Input: 240W (11-60V, 13A Max)
  • Battery Pack Power: 100W (USB-C)
  • Quick Freezing Mode (30ºC -0ºC): 15 min
Pros
  • Built-in icemaker
  • Long-lasting maintained temperature
  • 40 hr wire-free battery life
  • Dual climate zones for freezing and chilling
Cons
  • Heavy
  • Battery and wheels are separate add-ons
What to Consider Before Choosing a Camping Fridge
When considering a camping fridge, there are a few critical factors to remember.
Types of Camping Fridges
There are three main types of camping fridges: thermoelectric, compressor, and absorption.
Absorption
Absorption fridges are versatile but less energy efficient and are limited by certain operating restrictions, relying on heat, such as through forms like propane, to keep things cool.
Thermoelectric
Thermoelectric fridges rely on electricity to cool the items within them, requiring a much higher energy consumption and making them unsuitable for extended use off-grid.
Compressor
Compressor fridges, like the EcoFlow GLACIER Portable Refrigerator, use a 120W compressor to make ice as fast as 12 minutes. They are ideal when a compact but powerful solution is what you want – and keeping food and drinks fresh for an extended time is a requirement.
Interior and Exterior Dimensions
Camping fridges come in various sizes and shapes, so it’s essential to consider both the interior and exterior dimensions. Make sure to measure the space available in your vehicle or camping setup and the amount of food and drinks you need to store, ensuring your camping fridge is suitable for both. A fridge with large exterior dimensions but small interior dimensions will demand more space yet only allow limited cooling, but a fridge like the EcoFlow GLACIER Portable Refrigerator requires only 845 mm x 385 mm x 445 mm / 33.3 in x 15.2 in x 17.5 in (including wheels and handle) on the outside while giving you a whopping 38L of interior capacity.
Cooling Speed
Another essential factor is the cooling speed of the fridge. Speed is especially crucial if you need to rapidly cool drinks or perishable items before heading out on your trip. Look for fridges with fast cooling times, such as the EcoFlow GLACIER Portable Refrigerator, which can cool things down in just 15 minutes when empty for either single- or dual-zone. That takes you from a warm 86°F (30°C) to a chilly and fridge-appropriate 32°F (0°C) while you get the car packed up.
Power Options
Consider the power and charging options available for your camping fridge. Some may require external power sources, while others have built-in batteries or the capability to plug into your car’s cigarette lighter. The EcoFlow GLACIER Portable Refrigerator offers multiple charging methods, such as solar charging with panels (full charge in as little as 2.1 hours), AC charging (full charge in 2.2 hours), DC charging (full charge with 12V in 4 hours or with 24V in 2.1 hours), and even a plug-in battery that gives you up to 40 hours of wire-free cooling.
Features
Think about the additional features you may need in a camping fridge. Some fridges have built-in ice makers or dual climate zones for freezing and chilling. The EcoFlow GLACIER Portable Refrigerator offers both features: a sturdy design and the option of detachable wheels and handles for easy mobility.
Other features that improve the experience and use of a camping refrigerator include app control and WiFi or Bluetooth connection. The EcoFlow app gives you the power to intelligently control your EcoFlow GLACIER Portable Refrigerator from the comfort of your smartphone, letting you set the temperature of your fridge, freezer, or dual-zone use.
Which Camping Fridge Is Best?
The best camping fridge for you depends on your camping and refrigeration needs. However, among the many options available, the EcoFlow GLACIER Portable Refrigerator stands out as the best due to its rapid cooling in just 15 minutes, 40-hour wire-free power, dual-zone capabilities, and integrated ice machine, among other features.
When choosing a camping fridge, the EcoFlow GLACIER Portable Refrigerator is unparalleled. Its unique features, like rapid cooling, wire-free power for up to 40 hours, dual-zone capabilities, and an integrated ice machine, make it incredibly versatile and user-friendly. No matter your refrigeration needs during camping trips, the EcoFlow GLACIER Portable Refrigerator has you covered with intelligent controls and superior performance for an entire weekend at the campsite.
