Table of Contents
Don’t be left in the dark when a power outage occurs. With the right backup power supply, you can be prepared for grid failures and keep certain appliances – or even your whole home – running.
Below, we’ve covered our top backup power supply options for your home to help you pinpoint the right energy solution for your needs.
EcoFlow’s Top Backup Power Supply Options for Homes
- Best Backup Power Supply for Short Use: EcoFlow DELTA 2
- Best for Overnight Backup Power: EcoFlow DELTA Max
- Best Whole-Home Backup Solution: EcoFlow DELTA Pro
If you want something to bridge the gap when a short blackout occurs, the EcoFlow DELTA 2 is a great option. It features an expandable capacity so it can grow with you to suit your needs, offering between 1-3kWh.
With a huge AC output, you can power various appliances and stay green simultaneously. In fact, the EcoFlow DELTA 2 supports solar charging, so you can pair it with the right gear to recharge without waiting for the grid to come back up.
Ensure you’re prepared for power outages by equipping your home with the EcoFlow DELTA 2, which can power 90% of appliances and recharge with solar in 3-6 hours. It also boasts the fastest charging on the market, achieving an 80% charge in just 50 minutes with AC input.
Don’t go without the convenience of power during a blackout. The EcoFlow DELTA 2 can power everything from your coffee maker to your television to your refrigerator!
Specifications
- Storage Capacity (Minimum): 1024Wh
- Storage Capacity (Maximum): 3kWh
- AC Output: 1.8kW continuous output (2.7kW Surge)
- Solar Charge Capacity (Maximum): 11-60V, 15A, 500W max
- Weight: 27 lbs (12 kg)
- Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
- Operating Noise Level: ~50 decibels
- Charging Options: Solar/AC/Car Charger
- Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
- Cycle Life: 3000 Cycles to +/-80% Capacity
- Depth of Discharge: 100%
- Warranty: Five years (no cycle life restrictions)
- App Monitoring and Control?: Yes
Pros
- Expandable capacity
- Great entry-level backup option
- Powers over 90% of home appliances
- Can plug in up to 13 devices simultaneously
Cons
- Not ideal for longer-term use
Need something that will support your household overnight? The EcoFlow DELTA Max might be just what you’re looking for, as it’s an ideal option for those needing overnight backup power. If you want to keep your household comfortable overnight during an outage, this is a great bet.
With an impressive 2-6kWh expandable capacity and noteworthy AC output, you can power heavy-duty appliances and keep your favourite appliances running, even during an outage.
Want to keep things green by utilising solar charging? No problem. The EcoFlow DELTA Max supports solar charging, and you can charge in as little as 2.5 hours using solar power. With smart app control, you can control your power solution at your fingertips.
This powerful backup power solution can power 99% of your home devices, meaning you can keep your dryer, fridge, and more powered even during a grid failure.
Specifications
- Storage Capacity (Minimum): 1612 Wh
- Storage Capacity (Maximum): 2.8 kWh
- AC Output:2kW continuous output (5kW Surge)
- Solar Charge Capacity (Maximum): 11-100V 13A, 800W Max
- Weight: 48 lbs (22 kg)
- Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
- Charging Options: Solar/AC/Car/USB-C/USB-A Charging
- Battery Chemistry: NCM (Nickel Cadmium)
- Cycle Life: 500 Cycles to 80%+ Capacity
- Depth of Discharge: 80%
- Warranty: 24+12 (Registration for warranty extension)
Pros
- Powers 99% of home devices
- Solar compatibility
- Fast and convenient dual charging
Cons
- Has a decreased cycle life compared to other options
If you’re looking for the ultimate backup solution technology, check out the EcoFlow DELTA Pro. It offers a staggering 3.6-25kWh expandable battery capacity, making it an ideal solution for homes with a wide range of power needs.
You can use it for not only whole home backup but even take things a step further to achieve energy independence, making blackouts a thing of the past in your household.
Power an astounding 99.99% of heavy-duty appliances with this powerful EcoFlow portable power station. When grid failure occurs, you can breathe easily with the EcoFlow DELTA Pro in your corner to keep your household running as usual when the unexpected strikes.
If you’re looking for whole-home backup. energy independence, or both, the EcoFlow DELTA Pro is definitely worth a closer look.
Specifications
- Storage Capacity (Minimum): 3.6kWh
- Storage Capacity (Maximum): 25kWh
- AC Output: 3.6kW continuous output (7.2kW Surge)
- Solar Charge Capacity (Maximum): 3.2kW with 2 x EcoFlow DELTA Pro (16 x 400W EcoFlow Rigid Solar Panels)
- Weight: 99 lbs (45kg)
- Dimensions: 25 x 11.2” x 16.4” inches (63.5 x 28.4x 42cm)
- Charging Options: Solar/AC/Car Charger/Smart Home Panel/EV Charge Station
- Battery Chemistry” Lithium Iron Phosphate (LFP/LiFePO4)
Pros
- Expandable to a staggering 25kWh
- Massive AC output
- Powers 99.99% of heavy-duty appliances
- Multiple charging options, including solar
Cons
- More expensive than other solutions
What To Consider When Buying a Backup Power Supply for Your Home
There are a lot of things that go into choosing the right backup power supply for your needs.
Below, we’ve compiled a list of some things to remember while selecting your ideal backup power supply for your home.
The capacity of your power supply refers to how much power storage it has. If you’re trying to run more power-hungry appliances or get through a longer outage (or both), you’ll likely want a backup option with a higher capacity. However, if you’re just looking to keep some personal devices charged, you’ll probably be able to get away with an option with a lower capacity.
Max Load
Regardless of what capacity your backup power supply has, you need to make sure that it’s capable of running the devices you hope to power. Not all backup power solutions will be equipped to handle heavy-duty appliances such as your dryer or refrigerator. Look at the AC output your backup power supply can handle and compare it to the devices you want to power with it. Depending on the power solution you choose, you may not be able to power all of your devices simultaneously (or at all).
Expected Length of Outages
How long do you need your power supply to last? Are you trying to have a backup power supply for outages that last a few hours, or are you preparing for something that could last days or even longer? When investing in a home backup power supply, it’s essential to consider how long you’ll likely need to power your home and budget accordingly.
The cycle life of a battery refers to how many charge and discharge cycles you can expect before a decrease in performance. Consider this when comparing options, especially if you’re looking for a solution that will last years.
Charging Options
How are you going to charge your backup power solution? Different charging options are available depending on what you choose. Consider what charging options you’ll have available to you. Power solutions that support solar charging allow you to recharge with the proper gear even during a grid failure – and be eco-friendly simultaneously!
Budget
After weighing the factors above, it’s crucial to tailor your budget to ensure your investment into a backup power supply for your home is worthwhile. More powerful and robust backup solutions typically come with a higher cost, but there are often tax credits and incentives you should consider. A backup power supply for the home is a substantial investment, so doing your homework to understand where your budget needs to be is a must.
The right backup supply depends on your home’s electricity requirements and finding the best power supply option to meet those energy requirements. Consider factors like capacity, AC output, charging options, and more when deciding on the right option for you.
Different homes benefit from different power backup solutions depending on their goals, power needs, and budget. The EcoFlow DELTA Pro Portable Power Station offers an expandable capacity of 3.6-25kWh, but some homes won’t require such a robust solution.
A reliable backup power source is important if you want to keep the lights on and your appliances running as usual in your household. To find the right option, you need to consider factors like capacity, AC output, cycle life, length of outages you want to be prepared for, and more.
At EcoFlow, we offer a wide range of power solutions, so there’s something for everybody. Browse our selection of high-quality EcoFlow portable power stations today to find your perfect fit.
