Table of Contents
With blackouts and electrical surges common in parts of South Africa, many people are turning to backup energy solutions to keep their essential devices running. But what’s the difference between an uninterruptible power supply (UPS) and a battery backup? While both protect against energy loss, they serve unique roles.
We will explore what each of these terms means, the key differences between the two, the advantages of having one, and the best solutions to meet your power needs.
Understanding UPS Systems and Battery Backups
While an uninterruptible power supply (UPS) is a type of battery backup, and the two terms are sometimes used interchangeably, they have different meanings since not all battery backups are UPSs.
The confusion between the terms deepens when some manufacturers incorrectly label their batteries as UPS, even if they don’t have those additional components that make them more advanced.
Uninterruptible Power Supply
So, what is the UPS, and what does it do? It has more advanced technology than traditional batteries and is used to protect sensitive electronics. The electronics are plugged into them so that when the electricity goes out, drops in voltage, or surges, it instantly switches from utility to stored electricity. It prevents damage to their hardware or work on your computer from being corrupted or lost due to electrical fluctuations or outages.
They use a rectifier that converts AC to DC to charge its battery, which is then connected to a built-in inverter that converts the DC back into AC when the electricity goes out. One significant drawback is that most models only have a small capacity, lasting about 10 – 15 minutes.
They’re designed to give you time to shut down those electronics manually so they don’t get damaged. But they won’t help you run your devices during extended blackouts.
Battery Backup
A battery backup is an energy supply you can use when the main electricity goes out. Some models can turn on instantly and function as a UPS, but many do not.
They come in a wide range of capacities, like the EcoFlow Portable Power Stations, which range from a few hundred watts to 3.6kWh, with expansion batteries providing up to 25kWh. This is important when dealing with extended blackouts when a UPS alone won’t help keep you powered up.
You can also use the EcoFlow Smart Home Panel to integrate your portable power station with your home, linking up to 10 household circuits and simultaneously providing an uninterrupted power supply for numerous devices.
The EcoFlow PowerStream Microinverter is another excellent option for a balcony solar system. Its inverter component seamlessly integrates with your home’s electrical system using a wall outlet connection and synchronises with your grid power to ensure safe and reliable power delivery.
When dealing with extended outages or when you don’t have enough space for solar panels, the EcoFlow Smart Generator (Dual Fuel) is a convenient alternative that takes petrol and propane for versatile energy options.
What Are the Key Differences Between a UPS and Battery Backup?
Voltage Regulation
Many UPSs are designed to protect against brownouts, voltage drops, surges, and outages. So, they not only provide temporary backup energy but also filter the power and make it safe for sensitive electronics.
Most battery backups don’t specifically offer this feature; however, if you run your sensitive electronics through them all the time, you don’t have to worry about fluctuations since they draw their energy from the battery instead.
For instance, you can get a power station like the EcoFlow DELTA 2, a powerful UPS backup system for outages that offers uninterruptible power to protect your sensitive electronic equipment. This design provides the best of both systems.
Power Capacity
The primary difference is that a UPS generally only has a small capacity battery, which is not enough energy to keep using your devices during extended outages. Instead, they are intended to buy you time to manually shut down your sensitive electronics so they don’t get damaged when the electricity shuts off or surges unexpectedly.
On the other hand, a backup battery comes in a wide range of capacities and can be used for extended blackouts lasting hours or even days at a time. A UPS battery backup is the best option for this since it provides protection from energy surges and outages and longer-term energy so you can keep your essential devices running even during extended electrical outages.
Advanced Features
UPS systems often have advanced features, such as LCD displays, to monitor their status and the ability to monitor and control them remotely.
Simple battery backups do not have that. However, not all models are created equal. In fact, all EcoFlow Portable Power Stations of any size also have these advanced features.
What Are the Advantages of a UPS Battery Backup?
A battery backup alone provides the capacity to run devices for extended periods of time, while a UPS protects sensitive electronics during short-term outages or electrical fluctuations. Having a backup energy supply with those advanced features built-in gives you the best of both worlds.
- You can protect against electrical outages by switching automatically to backup for UPS functionality but with the capacity to keep your devices powered for extended periods of time.
- They provide automatic voltage regulation to protect against surges and fluctuations.
- It helps prevent potentially serious damage to the hardware on sensitive electronics.
- They protect against lost time and productivity when work can be corrupted or lost completely when the electricity goes out. It gives you the time to save your work and the capacity to keep working even during extended blackouts.
- It saves money by preventing damage to sensitive electronics and avoiding repairs or replacement.
- They can extend the life of the batteries in your electronics by avoiding frequent charging cycles.
- Remote monitoring is usually available to control your energy supply when you are not home.
- Most are very easy to install and won’t require technical expertise.
- They are highly portable, so you can bring them anywhere you need them.
- Some advanced UPS systems will save energy by reducing energy consumption when your computer isn’t being used.
You should have a backup system if you experience blackouts, and nearly everyone does. It can help keep essential devices charged, run critical medical devices, and keep your fridge or freezer running during extended blackouts so your food doesn’t spoil.
A UPS and a battery backup each serve valuable roles in keeping your devices running and protected. While a UPS protects sensitive electronics by delivering uninterruptible power, backup systems offer extended, high-capacity solutions for extended electrical outages. Combining both can be a smart choice for complete protection and long-lasting energy.
Explore EcoFlow Portable Power Stations for reliable backup energy solutions. You can even fully integrate them into your home with an EcoFlow Smart Home Panel for the best solution, offering a UPS solution with powerful batteries to safeguard your home or workspace against unexpected electrical interruptions.
