Tips and Tricks for Showering in an RV: Stay Fresh on the Road
There’s nothing quite like traveling out on the open road. Long days of driving while taking in scenic views is an experience like no other, though there can be some shortfalls when choosing to stay in an RV for days at a time.
Finding creative ways to stay clean on the road can be challenging without the proper tools. To help ensure you are feeling fresh for the entirety of your trip, we’ve developed a list of some tips and tricks on the best ways to shower while staying in your RV.
Let’s get started.
What To Consider When Showering in an RV
Whether you’re living in your RV or just traveling for a few days, it’s important to plan ahead to know when and how you’ll have access to a shower.
Staying clean is certainly a matter of comfort, but it’s also a matter of health and safety, so take the following items into consideration before setting off on your next adventure.
Types of RV Showers
The good news is that there are a lot of RV showers to choose from, so you’re guaranteed to find something that suits your needs. Wet and dry baths are commonly installed indoors, though there are outdoor options for you to install yourself.
Do some research to see what would work best for you and your travel party and consider all options before making any concrete decisions.
Indoors or Outdoors
This consideration is up to your preference. The majority of RVs come with a showerhead mounted on the outside, so installing an outdoor shower is a much easier undertaking and can be done in no time at all.
Indoor showers are a bit more invasive of an addition if your RV doesn’t already have one. If you are planning to live in your RV, an indoor unit is likely the best option for you.
Water Usage
Showering out of your RV is a great convenience, but there’s a smaller water supply than you may be used to from showering in your home. While showering in your RV, you should plan to take shorter showers and conserve water as much as possible.
The good news is you’ll save money while limiting your water usage, though your showers may have to be a bit shorter than you’re used to.
Water Pressure Levels
Water Pressure will vary on most showerheads in RVs. You can install a higher-pressure showerhead if you don’t like the one you currently have set up. Just be careful as high-power showerheads can use a lot of water at a faster rate and may run you low on your water supply ahead of schedule.
Moisture
If you have an indoor shower, you need to be very mindful of the moisture buildup. Excessive moisture can lead to the development of mold and mildew, so make sure to use a squeegee or towel after showering and allow for proper ventilation in your unit to keep things fully dry.
5 Tips To Improve Your RV Shower Experience
Tankless Water Heater
Investing in a tankless water heater is an easy way to improve your showering experience. With EcoFlow Power Kits 5kVA, you can easily install this system to ensure you have hot water running for as long as you need it.
As an added bonus, using a portable power station will allow you to shower without draining your RV’s battery.
Install Shower Mats
It may seem like a simple tip, but it can make a world of difference when showering on the go. Installing shower mats will certainly take the RV showering experience to the next level by keeping your feet clean and separated from the ground. These mats will allow you to dry off and stay clean as you make your way back inside.
Shower mats can also help to keep you safe. RV shower surfaces are typically very slippery, especially when wet. Installing these mats ahead of time is a surefire way to avoid any unnecessary injuries while on your trip.
Prioritize Ventilation
When showering in a confined space, like the bathroom of an RV, you may notice that the moisture levels are far more difficult to control than in a normal bathroom. The good news is there are ways to avoid this from becoming a larger issue.
With the EcoFlow Smart Generator 4000 (Dual Fuel) installed, you can easily supply power to a portable fan or ventilation unit near your shower. These units are designed to reduce the amount of moisture in the air and help limit the dangers that excessive moisture can cause.
You can also install a dehumidifier if your space does not allow for a full-sized fan. The choice is yours, but this tip will heighten your RV experience as a whole.
Invest in an AC Unit
Once you have finished showering, there is nothing worse than going back to your RV only to get hot and sweaty again. To ensure you can actually enjoy that fresh and clean feeling, make sure to install a portable AC unit in your RV. The EcoFlow Wave 2 Portable AC is the perfect addition and can quickly cool down your space to a comfortable temperature.
Install Lighting
When showering at night, especially in an outdoor setting, you may not have any lighting. This can obviously complicate the process and certainly diminish its enjoyment.
To keep the RV showering experience pleasant, consider using EcoFlow Portable Power Stations to power up some LED lighting for your outdoor shower. This will allow you to see what you are doing and be aware of your surroundings while you are outside.
How Do People Shower in an RV?
People can shower in an RV by installing one inside or outside their vehicle. Both of these options work quite well while out on the open road and can help ensure they stay fresh and clean throughout their trip.
How Do I Get More Pressure Out of My RV Shower?
If you are looking to get more pressure out of your RV shower, it may be time to invest in a high-pressure shower head. This quick fix will have you feeling the difference in no time. There are tons of options on the market, so you are sure to find something that is perfect for you.
Spending time in an RV is always a great experience, especially if you have the proper tools installed to keep you feeling your best. These simple tips will help to ensure you have easy access to a shower and allow you to stay clean no matter where your journey may take you.
Looking for some other ways to heighten your RV experience? Check out the EcoFlow Glacier Portable Refrigerator, the perfect compact refrigerator for every RV space.
