Table of Contents
There’s nothing quite like an escape into the great outdoors. The peaceful sounds of nature and the ability to decompress from everyday life are things that more and more people are chasing. Whether you’re an avid camper or looking to get started in the hobby, you’ve come to the right place.
To make the most of your camping experience, there are so many unique tools and gadgets you can bring along that will help elevate the overall experience. Comfort and convenience don’t have to be sacrificed in order to spend time in nature.
Learn more about how a portable generator may be the perfect investment for you and see how it can completely transform your camping trips for many years to come.
EcoFlow’s Best Quiet Generators for Camping
One of the best aspects of camping is enjoying the peace and quiet. You can listen to birds or hone in on the running water of a nearby creek. Missing out on these elements may lessen your camping experience and ability to reconnect with nature, which is why we’re focusing on the best, quiet generators that can be brought along for your upcoming expeditions.
The following generators won’t impede your ability to connect with your surroundings. Instead, they’ll help elevate your experience by providing a consistent power source at your campsite. Ready to see which portable generator may be best for your needs? Let’s dive in.
- Best for Backpacking or Hiking: EcoFlow RIVER 2
- Best for Weekend Trips: EcoFlow RIVER 2 Max
- Best for Essential Device Backup: EcoFlow RIVER 2 Pro
- Best for Longer Trips: EcoFlow RIVER 3
For the more adventurous campers, the EcoFlow River 2 is the best portable generator. If you are an avid backpacker or hiker, you know better than anyone that you have to be very careful about what you choose to bring with you. Traversing long, rugged trails with heavy items stowed to your back can be taxing and ruin the overall experience.
The EcoFlow River 2 is designed to be taken on the go. Weighing less than 10 pounds, you’ll have no issue bringing this powerful generator, which is easy to carry even on the most challenging hiking trails.
This generator can stay charged for days on end, allowing you to explore your destination on your own terms while still having access to a reliable power source. You can have peace of mind knowing you can keep your devices charged and stay connected even when traversing the most remote trails.
EcoFlow RIVER 2 Specifications
- Storage Capacity: 256Wh
- AC Output: 300W total (surge 600W)
- Solar Charge Capacity (Maximum): 11-30V, 8A, 110W Max
- Weight: 7.7 lbs (3.5 kg)
- Dimensions: 9.6 x 8.5 x 5.7 in (245 x 214 x 142 mm)
- Operating Noise Level: ~60 decibels
- Charging Options: Solar/AC/Car/USB-C Charging
- Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
- Depth of Discharge: 100%
- Warranty: 5 years
- App Monitoring and Control?: Yes
Pros
- Charges very quickly
- Easy to travel with
- Durable and designed for outdoor use
Cons
- Fewer power capabilities than other, larger models
- Designed to charge smaller devices, not larger appliances
If you frequently spend your weekends at a campground, you should strongly consider adding the EcoFlow RIVER 2 Max to your arsenal of camping equipment. This powerful portable generator can quickly transform your camping trips into glamping trips.
With a larger charging capacity, this generator is great for supplying power to larger appliances you may wish to set up at your campsite. No matter the time of year, you can keep the temperature at your campsite comfortable by supplying power to a fan or space heater by using the power capabilities of this helpful device.
You can also rest easy knowing this device is designed to hold its charge for days, making it a great addition to your weekend getaways.
In addition to this generator, consider bringing along the EcoFlow Glacier Portable Refrigerator for an added level of luxury. This portable refrigerator lets you bring along perishable items and safely store them in this durable, functional cooler.
EcoFlow RIVER 2 Max Specifications
- Storage Capacity: 512Wh
- AC Output: 500W (Surge 1000W)
- Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
- Weight: 13.4 lbs (6.1 kg)
- Dimensions: 10.6 x 10.2 x 7.7 in (270 x 260 x 196mm)
- Warranty: 5 years
Pros
- Durable and offers a long life-span even with daily use
- Lightweight and easy to carry with you to your campsite
- You can control its features right from the app on your phone
Cons
- Fewer output options than larger generators
- No expandable battery options are offered on other EcoFlow models
Best for Essential Device Back-Up: EcoFlow RIVER 2 Pro
The EcoFlow River 2 Pro is the perfect addition for camping trips of all types. This powerful portable generator is designed to back up devices of all sizes and power requirements, making it a great addition to supply power to your RV or tent site.
If you plan on bringing along numerous appliances to use throughout your trip (e.g., portable heater, electric grill or stove, electric cooler, etc.), then this is the best option for you. With a higher storage capacity than other models, you’ll quickly see how beneficial this device can be in supplying power to a variety of devices at the same time.
This portable generator can quickly charge up your cell phones, supply power to lighting fixtures around your campsite, and even allow you to run small projectors or TV sets for some nightly entertainment.
If comfort and convenience are a primary concern throughout your trip, this portable generator is a great investment to help you make the most of your trip and enjoy any gadgets you wish to bring to your adventure. You can use this device in tandem with the EcoFlow RAPID Power Bank for an added charging capability.
EcoFlow RIVER 2 Pro Specifications
- Storage Capacity: 768Wh
- AC Output: 800W total (surge 1600W)
- Weight: 17.2 lbs (7.8 kg )
- Dimensions: 10.6 x 10.2 x 8.9 in (270 x 260 x 226 mm)
- Warranty: 5 years
Pros
- Multiple output options for charging
- Solar charging capabilities for long-term use
- Very quiet when in use
Cons
- A bit heavier of a model that may be hard for some to transport
- A more expensive upfront investment than other models
For dedicated campers, most trips last more than a few days. If you’re preparing for a lengthy expedition, then the EcoFlow RIVER 3 is just the device you need. Whether you’re planning on setting up at one site for an extended period of time or wish to relocate numerous times throughout your trip, you’ll find that the EcoFlow River 3 can truly do it all.
Weighing in at less than 10 pounds, this generator is easy to transport and offers an extended battery life to last your entire adventure. You can travel as far off the grid as you please while still having access to power.
While this device can be used on any type of camping trip, it’s best used to power up any appliances in your RV or camper van. Off-the-grid camping can be made easy just by bringing along the EcoFlow River 3.
EcoFlow RIVER 3 Specifications
- Storage Capacity: 245Wh
- Expandability EB300 (286Wh), EB600Wh (572Wh)
- AC Output: 2 outlets, 300W total (Surge 600W, X-Boost 600W)
- Solar Charge Capacity (Maximum): 110W
- Weight: 7.8 lb
- Dimensions: 10×8.3×4.4 in
- UPS Auto-Switchover Time: ~20ms
- Operating Noise Level: <30 dB
- Warranty: 5 years
Pros
- Fast solar and AC charging capabilities
- Multiple output ports to supply power to a variety of devices at the same time
- Great for long-term use
Cons
- More expensive than other, smaller models
- Doesn’t offer wireless charging capabilities
What To Look for in a Portable Generator for Camping
When going to make your decision, here are the main factors you should take into consideration before making a purchase.
Portability
If you plan on being mobile throughout your camping trip, it’s a good idea to invest in a portable generator that’s designed with this in mind. Some generators can be heavy and difficult to transport, so find something that is suited to your specific plans.
Noise Level
Enjoying the sounds of the great outdoors can be challenging if an obnoxiously loud generator is set up nearby. Do your research and find a generator that runs at a low volume so you can enjoy all of the best parts of your camping experience.
Are you planning to use your generator to power up an entire RV? Or do you just need one to supply power to small devices and appliances around your campsite? Your answers to these questions will help guide you in the right direction in purchasing a portable generator with the capacity you need.
Fuel Type
Portable generators run on various fuel types, so educate yourself on the needs of the generators you’re interested in purchasing. Not wanting to get your hands dirty with typical fuels? The EcoFlow RIVER 2 Pro runs solely off solar energy and can continue to stay charged right from the comfort of your campsite.
The size requirement of a portable generator will depend on a variety of factors. To ascertain the perfect size for your needs, consider what you plan on using it for and determine how much power you’ll need access to throughout your stay. Portability is also an important feature on camping trips, as it’s easier to travel with a generator designed with this in mind.
As you can see, your options are endless when finding the perfect portable generator for your needs. Camping is about to take on a whole new level when you add one of these useful devices into the mix.
Ready to invest in your very own portable generator? The EcoFlow RIVER 3 Series is an excellent collection of devices and is a great starter kit for outdoor use.
