5 Best Quiet Generators for Camping in 2025 Reviewed
Stepping into the serenity of nature doesn’t mean you have to disconnect from modern conveniences.
With a quiet solar or inverter generator, you can enjoy the best of both worlds during camping trips.
Solar and inverter generators and portable power stations offer reliable off-grid power and virtually silent operation.
Ensure your comfort and enjoy all the peace of the great outdoors while keeping your phones, digital cameras, and camping appliances up and running — even on hiking trips!
No matter where you pitch your tent or park your RV, check out the best solar and inverter generators to keep you powered up quietly.
Ssssssh!
EcoFlow’s Top Quiet Camping Generators
  1. Best for Backpacking or Hiking: EcoFlow RIVER 2 + 110W Portable Solar Panel
  2. Best for Weekend Trips: EcoFlow RIVER 2 Max + 160W Portable Solar Panel
  3. Best for Small Camping Appliances: EcoFlow RIVER 2 Pro + 220W Bifacial Portable Solar Panel
  4. Best for Car and RV Camping: EcoFlow DELTA 2 Max + 400W Portable Solar Panel
  5. Best Hybrid Solar + Inverter Generator: EcoFlow DELTA Pro 3 + Smart Generator 4000 (Dual Fuel)
Weighing only 3.5 kg, EcoFlow RIVER 2 is the ideal companion for hiking in any terrain.
There are few things worse than missing out on the perfect photo of a sunrise or wildlife because your phone’s batteries are dead.
Not to mention being able to count on your map app when you stray too far off the trail.
Fortunately — or unfortunately, depending on how you look at it — there are still parts of  the US where you won’t get mobile internet…
But you’ll still want to capture the moment on your digital camera or smartphone.
The EcoFlow River 2 portable power station can run up to 99% of consumer electronics.
With 256Wh of off-grid electricity storage, EcoFlow RIVER 2 can keep you up and running wherever you go.
Device TypeCharges or Run Time
Phone (11Wh)19 charges
Laptop (16Wh)14 charges
Digital Camera (10Wh)22 charges
Portable WiFi (10W)20 hours
Camping Light (10W DC)20 hours
Electric Blanket (50W)3 – 6 hours
It’s powerful enough to keep you warm with an electric blanket during even the coldest hours of the night.
EcoFlow RIVER 2 provides true grab-n-go power.
You can charge it up before you head out from empty to full in just an hour when you plug it into the wall.
But EcoFlow RIVER 2 is also a virtually silent solar generator
Connect the EcoFlow 110W Portable Solar Panel and stay charged up indefinitely — wherever there’s sunshine.
EcoFlow RIVER 2 Specifications
  • Storage Capacity: 256Wh
  • AC Output: 300W total (surge 600W)
  • Solar Charge Capacity (Maximum): 11-30V, 8A, 110W Max
  • Weight: 7.7 lbs (3.5 kg)
  • Dimensions: 9.6 x 8.5 x 5.7 in (245 x 214 x 142 mm)
  • Operating Noise Level: ~50 decibels
  • Charging Options: Solar/AC/Car/USB-C Charging
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Depth of Discharge: 100%
  • Warranty: 5 years
  • App Monitoring and Control?: Yes
  • Rated Power: 110W
  • Efficiency: 22.8 %
  • Solar Cell Type: Monocrystalline
  • Weight: 8.8 lbs (4 KG)
  • Folded Dimensions: 16.5×18.9×1.0 in (42.0×48×2.5 cm)
  • Unfolded Dimensions: 16.5×70.3×1.0 in (42.0×178.5×2.5 cm)
  • Waterproof/Dustproof Rating: IP68
  • Open CircuitVoltage: 21.8V
  • Short Circuit Current: 6.5 A
  • Recommended Portable Power Station: EcoFlow RIVER 2
Pros
  • Over 30% lighter than comparable models
  • 100% Depth of Discharge. No more trickle charging at 80% capacity
  •  Four charging methods — including solar power
  • Safe to use indoors — or in your tent!
  • Whisper-quiet
Cons
  • Not enough AC output (500W continuous/1000W surge) to power large camping appliances
It may not be lightweight enough for a long-distance hike, but EcoFlow RIVER 2 Max provides more than enough power for a weekend away.
Phone (11Wh)38 charges
Laptop (16Wh)30 charges
Digital Camera (10Wh)44 charges
Portable WiFi (10W)40 hours
Camping Light (10W DC)40 hours
Mini Fridge (50W)3.1 – 6.2 hours
Blender (500W)0.8 hours
With double the output and solar battery storage of the RIVER 2, EcoFlow RIVER 2 Max can run up to 80% of essential appliances.
It also has double the solar charge input, so you can connect a 160W Portable Solar Panel or an EcoFlow 220W Bifacial Solar Panel.
Like all RIVER 2 series solar generators, you can control RIVER 2 Max from your phone using the EcoFlow app with Bluetooth or Wi-Fi for the ultimate in monitoring and control.
Even with double the power, you can still fully charge in an hour at home.
You can also recharge with solar panels, your car charger or USB-C.
Make your next weekend in the wilderness one to remember.
Enjoy the peace and quiet with the convenience of off-grid electricity.
EcoFlow RIVER 2 Max Specifications
  • Storage Capacity: 512Wh
  • AC Output: 500W (Surge 1000W)
  • Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
  • Weight: 13.4 lbs (6.1 kg)
  • Dimensions: 10.6 x 10.2 x 7.7 in (270 x 260 x 196mm)
  • Operating Noise Level: ~60 decibels
  • Warranty: 5 years
  • EcoFlow 160W Portable Solar Panel Specifications
  • Rated Power: 160W
  • Efficiency: 21 % – 22 %
  • Weight: 12.3 lbs (5.6 KG)
  • Folded Dimensions: 26.9×16.9×1.0 in (68.5×43.0×2.5cm)
  • Unfolded Dimensions: 26.9×62.6×1.0 in (68.5×159.0×2.5 cm)
  • Open Circuit Voltage: 21.4V
  • Short Circuit Current: 9.6A
  • Recommended Portable Power Station: EcoFlow RIVER 2 Max
Pros
  • More than enough battery storage to keep your family’s phones and tablets powered all weekend
  • LiFePO4 battery lasts for over 10 years of routine use — much longer than traditional lithium-ion or sealed lead acid deep cycle batteries
  • Suitable for emergency home backup of personal electronic devices and small appliances (<30ms auto-switch in a blackout)
Cons
  • May be too loud to run inside a tent or confined space at full load
  • Probably too bulky for hiking and backpacking
Ready to get serious about solar power but stay portable?
EcoFlow RIVER 2 Pro + 220W Bifacial Solar Panel ensures that you make the most of the available sunlight, even on cloudy days.
With its innovative design, the bifacial solar panel transforms sunshine into electricity — on the front and the back.
Most solar panels and other photovoltaic (PV) modules are one-sided.
The solar cells are only on the front of the panel, and the back offers protection from the elements and physical wear and tear.
EcoFlow’s 220W Bifacial Portable Solar Panel features highly efficient pure monocrystalline silicon PV cells on both the back and front of the unit.
You can generate a surprising amount of off-grid electricity from ambient sunlight — especially on reflective surfaces.
Like snow.
With 220W of rated power on the front and 155W on the back, you can capture 15% more solar energy on snow and 25% more on a mirrored surface.
Face the front of the panel into direct sunlight, and let the back maximize your electricity production potential — especially during the cold winter months.
Solar panels operate best in peak sunlight — and there’s less of it in winter.
Both sides offer industry-leading solar panel efficiency of 23% — meaning you can generate more power while taking up less space than cheaper polycrystalline and thin film PV modules
By capturing more ambient sunlight, bifacial solar panels can help provide enough power, even on cold, cloudy days.
Phone (11Wh)57 charges
Laptop (16Wh)45 charges
Digital Camera (10Wh)65 charges
Portable WiFi (10W)60 hours
Camping Light (10W DC)60 hours
Mini Fridge (50W)9.3 – 18.6 hours
Blender (500W)1.2 hours
EcoFlow RIVER 2 Pro provides the most AC output and storage of the RIVER solar generators while remaining light, quiet, and compact enough to power your off-grid adventures wherever you roam.
EcoFlow RIVER 2 Pro Specifications
  • Storage Capacity: 768Wh
  • AC Output: 800W total (surge 1600W)
  • Weight: 17.2 lbs (7.8 kg )
  • Dimensions: 10.6 x 10.2 x 8.9 in (270 x 260 x 226 mm)
  • Warranty: 5 years
EcoFlow 220W Bifacial Portable Solar Panel Specifications
  • Rated Power: 220W Front Side/155W Rear Side
  • Efficiency: 22 % – 23 %
  • Weight: 20.9 lbs (9.5 KG)
  • Folded Dimensions: 32.3×19.7×1.3 in (82.0×50.0×3.2 cm)
  • Unfolded Dimensions: 32.3×72.2×1.0 in (82.0×183.5×2.5 cm)
  • Open Circuit Voltage: 21.8V (Vmp 18.4V)
  • Short Circuit Current: 13A (lmp 12.0A) Front Side / 8.8 A (lmp 8.4A) Rear Side
  • Recommended Portable Power Station: EcoFlow RIVER 2 Pro/EcoFlow DELTA 2
Pros
  • Fully rechargeable (0-100%) in as little as 4.5 hours of direct sunlight
  • Bifacial solar panel maximizes available sunlight AND is just as durable as all of EcoFlow’s other portable solar panels. With an IP68 dust and waterproof rating, you can even drop it in a river or lake — just don’t leave it there too long!
  • With up to 1600W of AC output thanks to proprietary X-Boost tech, EcoFlow RIVER 2 Pro can power 80% of high-wattage home appliances. Plug in your fridge and other devices during an outage when you’re not on the road.
  • Plug it in before your trip and recharge from 0-100% in just 70 minutes
Cons
  • Suitable for essential home backup, but can’t run multiple high-wattage appliances at once
  • None of the RIVER 2 series portable power stations are expandable
One of the latest additions to EcoFlow’s award-winning DELTA series of solar generators, the DELTA 2 Max offers over 3 times the power and up to 8 times the storage capacity of the RIVER 2 Pro.
Of course, there’s a trade-off for specs like that.
At 23 kg, no one’s taking it on a hike — but it’s perfect for car and RV life on the road.
If silence and power are your top priorities, you can’t go wrong here.
Despite its expandability and enough output to power 99% of high-wattage appliances (3400W AC output with X-Boost), EcoFlow DELTA 2 Max is actually quieter than the RIVER 2 Pro.
Charging has never been so peaceful.
At only 30 decibels (dB), you won’t hear it above the rustling of leaves or even a whisper.*
What makes the DELTA 2 Max even more of a brainer for road trips is compatibility with EcoFlow’s 800W Alternator Charger.
Connect the charger to your car’s starter battery or your RV’s battery and top up with 1kWh of electricity in just 1.3 hours on the go.
By combining solar panels for camping and alternator charging, you can generate your own off-grid electricity any time of the day or night.
* More on decibels below
EcoFlow DELTA 2 Max Specifications
  • Storage Capacity (Minimum): 2048 Wh
  • Storage Capacity (Maximum): 6kWh
  • AC Output (Maximum): 2.4kW continuous output (3.4kW X-Boost)
  • Solar Charge Capacity (Maximum): 11-60V 15A, single port 500W; dual port 1kW
  • Weight: 50.7 lbs (23 kg)
  • Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
  • Charging Options: Solar/AC/Car Charger
  • Multicharge Options? Yes
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Warranty: Five years (no cycle life restrictions)
EcoFlow 400W Portable Solar Panel Specifications
  • Rated Power: 400W
  • Efficiency: 22.6 %
  • Weight: 35.3 lbs (16.0 KG)
  • Folded Dimensions: 41.7×24.4×1.0 in (105.8×62.0×2.5 cm)
  • Unfolded Dimensions: 41.7×93,1×1.0 in (105.8×236.5×2.5 cm)
  • Open Circuit Voltage: 48V (Vmp 41V)
  • Short Circuit Current: 11A (lmp 9.8 A)
  • Recommended Portable Power Station: EcoFlow DELTA Series
Want all the benefits of a solar generator with the added convenience of refueling with gasoline and propane?
EcoFlow Smart Generator 4000 (Dual Fuel) is one of the quietest inverter generators available, and it runs on unleaded gas or LPG.
It integrates seamlessly with EcoFlow DELTA Pro 3, providing you with additional charging options and greater off-grid energy security.
You can still generate power with solar panels and have a fossil fuel option for nighttime or cloudy days.
With a built-in muffler, the EcoFlow Smart Generator 4000 operates at only 70dB under full load, offering industry-leading noise reduction and performance.
With multiple multi-charging options, you can achieve up to 7000W of input capacity and recharge with record-breaking speed.
If you’re car or RV camping, add the EcoFlow 800W Alternator Generator and recharge while you drive with energy that would otherwise go to waste.
If you’re considering full-time RV or van life, EcoFlow Power Kits are also worth a look.
EcoFlow DELTA Pro 3 Specifications
  • Storage Capacity (Minimum): 4kWh per Battery. Up to 3 Batteries per DP3 (12kWh)
  • Storage Capacity (Maximum): 36kWh (Battery Storage) + 12kWh with a full Smart Generator 4000 (Dual Fuel) = 48kWh
  • AC Output (Maximum): 4kW (6kW X-Boost/8kW Surge) (120/240V)
  • AC Output (Maximum):  Expandable to 8kW or 12kW by chaining 2 or 3 x DELTA Pro 3
  • Solar Charge Capacity (Maximum):  2600W Dual-PV Charging (150V) per DP3
  • Weight:  115 lbs (52kg)
  • Dimensions:  27.5 × 13.5 × 16 in (69.5 × 34 × 41 cm)
  • Operating Noise Level:  35 decibels
  • Charging Options:  Smart Home Panel 2 (7200W) / AC (3600W) / Dual Solar Input (2600W) / EV Charging (4000W) / Gas Generator (3200W) / Alternator Charging / Car Adapter Charging
  • Multicharge Options? Yes – 18 Options
  • Cycle Life:  4000 Cycles (11+ years of regular use)
  • App Monitoring and Control? Yes
EcoFlow Smart Generator 4000 (Dual Fuel) Specifications
Generator Specs
  • Type: Inverter Generator
  • Rated Power: 3200W with Gasoline, 2900W with LPG (4000W Peak Output with X-Boost Tech)
  • Rated Voltage: 120V
  • Frequency: 60Hz
  • DC Output Voltage: 40~60V
  • DC Current: 56A max
  • Weight: 83 lbs (38 kg)
  • Dimensions: 24.9 x 15 x 20.8 in (633 x 381 x 529 mm)
  • Recommended Portable Power Station: DELTA Pro 3
Engine Specs
  • Fuel Type: Unleaded Gasoline/Propane (LPG)
  • Engine Size: 196cc
  • Engine Type: 4-Stroke
  • Fuel Tank Capacity (Gas): 1.58gal (6L)
  • Engine Oil Capacity: 0.145L (0.55L)
  • Continuous Working Time (Gas): 2.8hr (Full Load), 8hr(1/4 Load)
  • Noise Level (at 7m Distance): 70dB (Full Load)
  • Warranty: 3 Years
Pros
  • Multiple charging options include solar, gas, propane, and Level 1 or 2 EV docking stations
  • Last line of defence is sunlight doesn’t meet your electricity demands
  • One of the quietest inverter generators available
  • Highly expandable
  • Suitable for whole home backup
  • Integrates with your home wiring using a Smart Home Panel or transfer switch
Cons
  • Like all gas and inverter generators, EcoFlow Smart Generator 4000 (Dual Fuel) can’t be operated indoors. Recharge DELTA Pro 3 with the Smart Generator and bring the portable power station inside your tent, RV, or home
  • Inverter generators have ongoing fuel costs
How To Choose the Best Quiet Generator for Camping
The first thing most people look at when shopping for a generator is how much power it will output and how long it will run.
Both are essential considerations, but since you’re looking for peace and quiet to go with your off-grid power solutions, let’s start with noise.
What Are Decibels (dB) and How Do You Measure Noise?
If you’re making a purchase decision based on how quiet (or LOUD!) a machine is, having a basic understanding of decibels (dB) is essential.
Sound is far less tangible than dimensions or weight, but we can still measure the volume of noise anything creates.
As you likely know, sound travels in waves.
There are two ways to measure sound.
  • Frequency is measured in Hertz (Hz). The definition is simple, but what it measures is extraordinary.
1 Hz = 1 Event per Second
In the real world, the equation for Hertz is used to measure the frequency of cycles or vibrations in a soundwave.
That’s why we typically refer to sound as being low (bass), middle (midrange), or high frequency (treble).
Most people can hear (or feel) sound with a frequency of 20 Hz to 20,000 Hz, with 20 being the lowest rumble and 20,000 being the highest “tweet.”
If you’re familiar with audio speakers, you’ll know that the very lowest frequencies come from the subwoofer, and the keenest pitch comes from the tweeters.
People speaking falls into the range of 100 and 8,000 Hz.
The frequency of an internal combustion engine — like those found in conventional vehicles and gas generators — falls is concentrated in the 100 ~ 400 Hz range. You will hear — and feel — it as a deep, low-frequency rumble.
  • Amplitude is the more crucial metric to consider when shopping for a quiet generator.
    Amplitude measures the pressure of sound — more commonly known as the “volume” — or how loud a noise is.
    As shown above, the sound level is recorded on the decibel (dB) scale.
    It’s essential to understand that decibel levels increase or decrease exponentially.
    Most common measurements like weight and dimensions are measured in increments — e.g., 110 kg is 10% heavier than 100kg.
Decibels increase by factors of 10. For example, an increase from 50 to 60 dB means the sound is 10x louder. Bump that up to 70dB, and it’s 100x louder!
Keep in mind that anything over 70dB is considered harmful to human hearing over time.
Now that you have a fundamental understanding of how noise levels are measured consider that traditional gas generators operate at 80db ~ 100db — well over the safety threshold.
Not only is a noise level of 100dB detrimental to your health, it means that conventional fossil fuel generators are frequently banned from campgrounds and RV parks.
Even if you’re permitted to operate one, it’s likely to be during restricted hours.
Inverter generators — particularly closed frame models — are less noisy, especially when not running at full throttle.
In fact, one of the primary benefits of inverter generators is that they can operate more efficiently under less than maximum loads.
Conventional gas, propane, and diesel generators only run at one speed – full.
Inverters throttle up and down based on your electricity consumption and produce less noise under light to medium loads.
High-quality gas and propane inverter generators can operate at about ~75dB – roughly equivalent to the sound of a lawnmower or leafblower outside your home.
EcoFlow’s solar generators charge as quietly as 30dB and can operate at under 50dB under maximum load.
That’s as quiet as a whisper and as loud as average room noise.
With an EcoFlow portable power station, you’ll never have to worry if your generator is too noisy ever again.
What is the Electricity Output in Watts?
Even the quietest generator won’t do you any good if it doesn’t charge or operate the devices and appliances you want it to run.
Take a detailed inventory of everything you want to off-grid simultaneously and add up the starting and running watts.
The AC output of your generator should exceed the combined wattage by at least 15%.
Because it’s rarely an issue with on-grid electricity, many people aren’t familiar with the difference between starting and running watts.
Many high-wattage appliances — particularly anything with a motor, like fridges, washers, and HVAC units — require much more power to start than to run.
You may have had a circuit breaker trip due to this, but if a generator doesn’t have enough surge power to turn on an appliance, you won’t be able to use it.
Gas and inverter generators can typically only provide an additional ~100W above their maximum AC output — or, at best, 10% more than the total.
Consequently, a 2000W gas generator typically has a maximum starting wattage of less than 2200W.
Alternatively, the EcoFlow DELTA Max 2 offers 2400W AC output and 4800W surge power.
That means you have double the continuous output of your solar generator available to get your gear up and running.
Not only that, thanks to X-Boost technology, EcoFlow DELTA 2 Max can run appliances of up to 3400W total rated wattage simultaneously.
No gas or inverter generator can offer that kind of performance.
What is the Storage Capacity (Watt-Hours/KiloWatt-hours)?
Electricity storage capacity is of particular significance for any off-grid power source or generator that uses clean, renewable energy.
All sustainable sources of electricity — like solar, wind, and hydropower — are intermittent.
Solar panels don’t work at night.
Wind turbines don’t generate electricity unless the rotors are moving.
All off-grid and hybrid photovoltaic systems that generate electricity rely on solar batteries to store and output power when your consumption exceeds production.
Grid-tied solar panel systems don’t require batteries, but they won’t do you any good camping — and they shut down automatically during a blackout.
For off-grid and home backup applications, battery storage is essential.
Estimate your total electricity consumption in kilowatt-hours between charges to ensure you have enough power to keep you up and running as long as you need.
Remember, EcoFlow’s portable power stations all have multiple recharging options, not just solar panels.
Another crucial factor is solar battery chemistry
The LFP batteries used in EcoFlow’s products last much longer and outperform traditional lithium-ion and (especially) lead-acid and VRLA deep-cycle batteries.
Fossil fuel generators don’t rely on batteries — except perhaps to start.
Instead, assess storage capacity by the size of the fuel tank, your total electricity consumption, and your access to fuel.
Gas generators are far more prone to mechanical failure than solar, but they should keep running as long as you have enough fuel — and you don’t mind paying for it.
Portability
What type of camping do you do most frequently?
If you do a lot of hiking or wild camping, you don’t want your generator to weigh you down…
If you mostly camp close to your car or in an RV, weight won’t be as much of a concern, but the dimensions might be.
Unless you’re driving a Class-A motorhome, both size and weight are likely to be important considerations.
Balance portability with your off-grid electricity needs.
Is It Safe for Indoor Use?
No gasoline, propane, diesel, inverter — or any generator that burns fossil fuels — can be safely used indoors.
Inverter generators often claim to provide “cleaner” power — but that’s a reference to fuel efficiency and total harmonic distortion (THD).
When people say that conventional gas portable generators output “dirty power,” they’re usually referring to the variations and surges in the electrical waveform due to how an internal combustion engine and alternator genset produce AC electricity.
Because the THD level is so high, portable gas generators are not suitable for sensitive electronics.
Usually, that refers to computers and hard drives, but virtually all modern devices include microprocessors and other sensitive electronics.
Even the “cleanest” gas or inverter generator produces poisonous carbon monoxide and other deadly emissions — under no circumstances can they be used indoors or in any confined space, such as a tent or RV.
Gas generators kill or poison thousands of people every year.
EcoFlow’s portable power stations and solar generators are 100% safe for quiet indoor use.
No toxic fumes, poisonous chemicals, or greenhouse gases are produced.
If you want the flexibility of generating off-grid electricity with gas and propane, consider a hybrid inverter generator solution.
EcoFlow’s DELTA Pro 3 + Smart Generator 4000 hybrid inverter gives you all of the convenience of refueling with gas and LPG with none of the downsides.
Recharge the Smart Generator outdoors and use EcoFlow DELTA Pro 3 in your RV, tent, or home safely and quietly — any time, day or night.
How Many dB Is Considered a Quiet Generator?
Inverters are the quietest gas, propane, or diesel generators and typically produce about 70dB of operating noise. All conventional internal combustion engine and alternator gensets that burn fossil fuel make up to 100dB of noise or more. Solar generators don’t rely on an engine and can be as quiet as 30dB, the sound level of a whisper or a rustling leaf.
What Is the Quietest Generator for Camping?
Inverters are the quietest generators that use gas, propane, or diesel, but they’re at least 100 times louder than solar generators. Unlike any generator that burns fossil fuels, solar generators don’t require an internal combustion engine and have very few moving parts. Not only that, you can use them indoors safely and quietly.
A quiet generator can make all the difference in creating a peaceful and enjoyable experience for you and your fellow campers.
In addition to carefully considering the decibel level of your camping generator options, consider all the factors mentioned above to find the ideal solution for your off-grid adventures.
EcoFlow’s hybrid inverter and solar generators can provide all the quiet off-grid electricity you need.
