Best EcoFlow Black Friday Deals
If you’re shopping for the best deals on power solutions, don’t miss the savings available through EcoFlow’s Black Friday deals. Save on solar panels, portable power stations, solar generators, and camping solar solutions from EcoFlow.
Best Black Friday Deals for Solar Panels
EcoFlow has a variety of solar panels to meet every need. Whether you’re looking for a small, portable panel for camping or a large, powerful panel for your home, EcoFlow has you covered. And right now, you can save big on EcoFlow solar panels during our Black Friday sale.
The EcoFlow 400W Portable Solar Panel is the most powerful and largest portable solar panel we offer, and you won’t want to miss our Black Friday deals. This powerful panel offers a 23% conversion and impressive output.
Pros
  • Among the highest-rated power output available to consumers
  • Extremely portable with a protective case doubling as a supporting stand
Cons
  • More expensive than options with a lower rated power
If you need a lightweight, portable option for hiking or backpacking trips, act quickly to get the EcoFlow 110W Portable Solar Panel at a great bargain. This small, compact option is a great pairing for the EcoFlow RIVER 2.
Pros
  • 10% smaller than similar portable solar panels, making this an ideal option when space is limited
  • Durable and waterproof design
Cons
  • Limited power output
EcoFlow 160W Portable Solar Panel
Need some on-the-go power but looking to keep your solar equipment light and compact? Consider the EcoFlow 160W Portable Solar Panel for longer camping trips or car camping adventures.
Pros
  • 22% conversion efficiency
  • Lightweight
Cons
  • Limited to what appliances you can power
EcoFlow 220W Bifacial Portable Solar Panel
When efficiency is key, combine ample power in a small package with the EcoFlow 220W Bifacial Portable Solar Panel, a unique design that optimizes energy production. This powerful device collects up to 25% more solar energy with a 220W primary side paired with a 155W back side for ambient light.
Pros
  • Made to last with durable tempered glass
  • Capture 25% more solar energy
Cons
  • A more expensive option than some other portable solar panels
Best Black Friday Deals for Portable Power Stations
Looking for a portable power solution or a source of home backup power? Shop these great Black Friday Deals on our portable power stations.
EcoFlow DELTA Pro
The EcoFlow DELTA Pro is an excellent option if you’re looking for a portable power station that packs a lot of power. It’s extremely expandable, has versatile charging methods, and can power 99.9% of heavy-duty devices at home, at work, or outdoors.
Pros
  • Expandable
  • Multiple charging options
  • Impressive AC output
Cons
  • Larger and heavier than other portable power station options
EcoFlow DELTA Pro + Extra Battery
Love the power capabilities of the EcoFlow DELTA Pro, but want more storage? Bundle and combine the EcoFlow DELTA Pro with an extra battery for additional storage capacity. This is a great option for those who want all the benefits that come with the EcoFlow DELTA Pro but with an even larger capacity.
Pros
  • Doubles total storage capacity to 7200Wh
  • Massive AC output
Cons
  • Both batteries together are heavy
  • The higher capacity comes at a greater cost
EcoFlow DELTA Pro Extra Battery
If you already have the EcoFlow DELTA Pro and are looking to upgrade your storage and take advantage of our incredible Black Friday Deals savings, now is the time to get an additional EcoFlow DELTA Pro Extra Battery to double your storage capacity.
Pros
  • Increases the capacity of your EcoFlow DELTA Pro
  • 10-year LFP battery lifespan
  • Easy to use
Cons
  • Requires that you already have an EcoFlow DELTA Pro
EcoFlow DELTA 2
If you love taking long road trips with the family, look no further than the EcoFlow DELTA 2, the perfect portable power station for your extended travels. It can also function as a great entry-level home backup option. The EcoFlow DELTA 2 offers expandable storage capacity, so you can even upgrade your power capacity at a later time.
Pros
  • Affordable home backup option
  • Its capacity and weight make it great for road trips
  • Fast recharge
Cons
  • Not a robust home backup solution
EcoFlow DELTA 2 + Extra Battery
Want an EcoFlow DELTA 2 with a greater capacity? This bundle comes with an extra battery to double your storage capacity to 2048Wh. You’ll get the same excellent 1800W AC output to power over 90% of home appliances – or up to 15 devices simultaneously.
Pros
  • Has 7x faster AC charging than the competition
  • Lasts ten years before hitting 80% of the original capacity
Cons
  • Comes at a higher cost for the greater capacity
EcoFlow DELTA Max 2000 + Extra Battery
Get home emergency power when you get our EcoFlow DELTA Max + EcoFlow Delta Max Smart Extra Battery Bundle. Enjoy a great deal on this rapid dual-charging portable power station bundle with excellent storage capacity that can power 99% of home devices, including heavy-duty devices up to 3400W with X-Boost.
Pros
  • Power multiple devices at once with ease
  • Fast dual charging
Cons
  • The portable power station paired with the additional battery can limit portability
The EcoFlow DELTA 2 Max Smart Extra Battery is the ideal companion for your EcoFlow DELTA 2 Max to add an additional 2048Wh capacity. You can add up to two EcoFlow DELTA 2 Max Smart Extra Batteries, giving you a capacity of 6144Wh – ideal for outdoor adventures, RVing, home backup, and daily use.
Pros
  • Safe, durable construction
  • Easy to use
  • Long lifespan with LFP battery
Cons
  •  Adding additional batteries may make things less portable
Best Black Friday Deals for Solar Generators
Pair our solar panels together with our industry-leading portable power stations and get a solar generator at a great price for all your energy needs.
EcoFlow DELTA 2 + Extra Battery + EcoFlow 110W Solar Panel
Perfect for extended road trips with the family or as an entry-level home backup solution, this bundle gives you additional storage capacity with the extra battery, and the solar panel is compact and lightweight enough to take with you on all your adventures.
Pros
  • Lightweight, portable solar panel
  • Offers expandable storage capacity
Cons
  • Two batteries may make things bulky
EcoFlow DELTA 2 + EcoFlow 220W Solar Panel
Enjoy excellent savings on this EcoFlow DELTA 2 + EcoFlow 220W Solar Panel bundle, perfect for entry-level home backup for essential appliances or extended road trips. With a bifacial solar panel design, you’ll enjoy faster charging speeds.
Pros
  • Expandable storage capacity
  • Up to 23% conversion with the bifacial panel
  • Power 99% of appliances thanks to X-Boost
Cons
  •  Not enough power for a whole-home backup
EcoFlow DELTA Pro + EcoFlow 400W Solar Panel
Maximize your power with the EcoFlow DELTA Pro + EcoFlow 400W Solar Panel bundle at a great deal. The EcoFlow DELTA Pro is expandable up to 25kWh, allowing you to add extra capacity later if you need it. Paired with the 400W solar panel – the highest rated power EcoFlow offers – for reliable power generation.
Pros
  • Excellent capacity
  • Expandable
  • Fast solar charging speed
Cons
  •  More expensive than other solar generator options
EcoFlow DELTA 2 Max + EcoFlow 400W Solar Panel
Enjoy a great deal on the EcoFlow DELTA 2 Max + EcoFlow 400W Solar Panel this Black Friday. Featuring a huge AC output of up to 3400W with X-Boost, this is a great option for anyone looking to go solar.
Pros
  • Fast recharging
  • High conversion efficiency
  • Manage your energy in the EcoFlow app
Cons
  •  Large and heavy
Best Black Friday Deals for Camping
Sometimes, you just need enough power to get you through the camping trip. For these cases, shop our Black Friday deals for camping power solutions.
EcoFlow RIVER 2 Pro
Car camping and need some on-the-go power? Use the EcoFlow RIVER 2 Pro, made for moments just like this.
Power up to 80% of home appliances and use it to back up a few of your most essential devices. Just be sure to pair it with a solar panel of 220W or lower.
Pros
  • Power 80% of home appliances
  • Four charging options
Cons
  •  Must add panels to take advantage of solar charging
EcoFlow RIVER 2 Pro + EcoFlow 220W Solar Panel
Take advantage of Black Friday savings when you purchase our EcoFlow RIVER 2 Pro + EcoFlow 220W Solar Panel. Use it while camping to turn sunlight into enough power for some of your favorite devices.
Pros
  • Lightweight and compact, easy to carry and store
  • 23% conversion rate
  • IP68 dust and water resistance
Cons
  •  May be too bulky for a backpacking trip
EcoFlow RIVER 2 Max + EcoFlow 160W Solar Panel
When you need enough power for an off-grid or weekend-long camping trip, bring the EcoFlow RIVER 2 Max + EcoFlow 160W Solar Panel bundle for some of your small, essential appliances like a cooktop.
Pros
  • Great for lower power needs
  • Fast charge times
Cons
  •  Not best for backpacking or traveling while camping
Best Black Friday Deals for Off-Grid Power Solutions
Looking for entirely off-grid solutions? These options enable you to realize your energy independence without any grid support.
EcoFlow DELTA Pro + EcoFlow Smart Home Panel
Take our most powerful portable power station and integrate it with your existing home wiring with the EcoFlow Smart Home Panel. This expandable solution is ideal for a wide range of uses.
Pros
  • Can power heavy-duty appliances
  • Expandable
  • Manage usage in the EcoFlow app
Cons
  • Professional installation by an electrician is required
2 EcoFlow DELTA Pros + Double Voltage Hub
With two EcoFlow DELTA Pros, you can double your AC output. Enjoy massive 7200W AC output, allowing you to run 99% of all home appliances – even high-wattage appliances like an electric heater or a clothes dryer.
Pros
  • Long-lasting power solution
  • Fast recharge between outages
  • A quiet, clean alternative to noisy fuel generators
Cons
  •  Two batteries together are extremely heavy, not portable
Shop the Best EcoFlow Black Friday Deals Today!
Don’t miss out on the best Black Friday deals on EcoFlow solar panels, portable power stations, solar generators, and more!
These deals are only available for a limited time, so get yours today and be prepared for anything. With EcoFlow, you can power your home, office, or campsite and enjoy the comforts of home from anywhere. Check out our Black Friday deals and find your perfect power solution today!
