110W & 160W Models To Accompany Portable Power Stations
LOS ANGELES, Feb. 7th, 2021 – EcoFlow today announced the availability of two portable solar panels, a 110W model and a 160W model. These come in the wake of the success of their previous solar generator launches, EcoFlow DELTA, and EcoFlow River 2.
The solar panels are designed from the ground up to be suitable for outdoor use. They’re foldable, water and dust resistant and come with a kickstand carry bag for easy transport.
Widely compatible, highly efficient
While EcoFlow’s foldable solar panels are designed with their power stations in mind, they work with other models too. Sporting an Solar to XT60 Charging Cable, they can plug directly into most portable power stations, and can even be chained together for extra solar power.
Portable and foldable
Both the 160W solar panel and the 110W solar panel come with a kickstand carry bag, making them easy to carry. Once you arrive at your destination, you can open up the bag and use it as a kickstand so that you can place your panel at an optimal angle relative to the sun.
The panels fold out by design, maximizing coverage to ensure you get the most out of the sunlight. When folded in, they compact into a handy size that will fit neatly into the trunk of a car.
Water, dust and dirt resistant
EcoFlow’s solar panels are built for the outdoors. For that reason, they made both models IP-67 water and dust resistant. They can handle fine dust particles and even water. And, they’re made from a material that’s easy to wipe down after a trip.
Availability
The panels are both available today from ecoflow.com, and can be purchased individually, or in a bundle with one of EcoFlow’s industry-leading portable power stations.
