spot_img
Blackout vs. Brownout: How Can You Prepare for Both?
Blackouts and brownouts are on the rise. There it’s crucial to learn the difference and know what to do in a blackout vs brownout. Year on year our dependence on electricity has been on the rise. We rely on electricity from dawn until dusk to keep our homes, businesses, and favorite devices connected and powered. According to the EIA, U.S electricity customers experienced eight hours of power interruptions in 2022 with this number set to increase. Your utility company does everything it can to prevent power outages. But there are unexpected and uncontrollable events like weather and demand spikes that cause power outages.
Check out the average duration of total annual power interruptions in the United States between 2013 and 2022.
Source: U.S. Energy Information Administration, Annual Electric Power Industry Report
What Is the Difference Between a Blackout and a Brownout?
A blackout is a planned or unplanned power outage resulting in a temporary but total loss of electricity transmitted to end users through the utility grid.
A brownout is a more frequent but often unnoticed occurrence where the voltage level supplied through the grid temporarily dips. Depending on the duration of a brownout and the decrease in volts delivered to homes and businesses, you may not notice it occurring. However, even minor fluctuations in voltage can cause significant damage to sensitive electronics — such as desktop computers and data servers.
Unplanned blackouts typically only last a few hours but can last for days or even weeks. Even short blackouts lead to widespread disruption. Extended blackouts can be considered a disaster. The Texas power crisis of 2021 lasted over two weeks and was responsible for hundreds of deaths.
Unplanned blackouts — like the one in Texas — are often caused by extreme weather events, such as a severe winter storm or heat wave. Other potential causes include aging utility infrastructure and electricity demand exceeding supply.
Planned blackouts — often called rotating outages, rolling blackouts or load-shedding — occur when a utility intentionally shuts down power in specific areas of the grid to protect the integrity of the overall infrastructure. Utility customers are typically warned in advance of a rolling blackout and they occur for a scheduled period — often two to eight hours. Rotating outages usually take place when demand for electricity exceeds supply or system capacity and are designed to prevent more widespread blackouts or catastrophic failure of the grid.
What is a Blackout?
By definition, a blackout occurs when there is an unexpected interruption of power. There’s no way of predicting how long a blackout will last. It could be a matter of minutes, hours, or even days depending on the cause. A blackout can occur for a variety of reasons, here’s a list of what can cause a blackout:
  • Unpredictable weather patterns like lightning strikes, storms, or natural disasters
  • A spike in power demand, pushing the grid past its limit
  • Power lines or transformers being damaged
  • Fallen tree branches on power lines
  • Ice build-up on power lines
In recent times, one of the worst blackouts was the ‘Texas deep freeze’ in 2021. But you can learn more about that here.
Be prepared for a blackout or a brownout. Read this article to find out how.
What is a Brownout?
Perhaps less commonly known is a ‘brownout’. But what causes a brownout? In a nutshell, a brownout is caused by partial disruption of mains power. The biggest difference between a blackout and a brownout is that a blackout is an unexpected, complete shutdown of electricity.
Brownouts are a temporary interlude planned by your utility provider. Throughout a brownout, electricity is still provided to your home, but at reduced voltage levels. Typically, your utility provider will reduce voltage by 10-25%.
So why do utility providers plan a brownout? Your utility provider will plan a brownout to prevent a blackout. Utility companies do this when they know a demand spike is coming. They’ll migrate electricity, to avoid putting too much pressure on the grid.
Another difference between brownouts and blackouts is that brownouts are short-term. Your utility company will know when it will start and when it will finish.
While you can still use your appliances and devices during a brownout, it’s not advisable. Due to fluctuating voltage, your appliances could get fried. It’s best to unplug them or have an alternative power supply, like an EcoFlow DELTA series portable generator, for the duration of the brownout.
What is a rolling Blackout?
Another situation you could experience is a ‘rolling blackout’. Like a brownout, this is a controlled blackout planned by your utility provider. This helps to prevent the grid from being overloaded due to a demand spike. The distinct difference is that during a rolling blackout the power is completely switched off. However, the power is usually only shut off for an hour or two.
Most states are affected by rolling blackouts. However, California tops the list. During wildfire season, rolling blackouts are a regular occurrence. They are used to help manage peak demand and reduce the risk of wildfires.
But for a digestible guide on how to prepare for a rolling blackout, you can find out here
How can an EcoFlow DELTA portable power station help with a blackout or brownout?
One way to safeguard against a blackout or a brownout is to create a home backup system to reduce your reliance on the grid. This is where the EcoFlow DELTA series solar generators come in handy.
EcoFlow DELTA mini power station 28388738334793 1024x1024@2x
EcoFlow DELTA mini
882Wh
Phone (11W)
62 Charges
Laptop 60W
12 Charges
Mini Fridge
12 Hours
Blender (500W)
1.5 Hours
Coffee Machine (1000W)
0.7 Hours
Air Fryer (1500W)
0.5 Hours
ecoflow tech EcoFlow DELTA power station portable power 28357408161865 1024x1024@2x
EcoFlow DELTA
Capacity 1260Wh
Phone (11W)
104 Charges
Laptop 60W
19 Charges
Mini Fridge
19 Hours
Blender (500W)
2.1 Hours
1.1 Hours
Air Fryer (1500W)
0.7 Hours
EcoFlow DELTA max power station 28357579931721 1024x1024@2x
EcoFlow DELTA Max
Capacity 2016Wh
Phone (11W)
175 Charges
Laptop 60W
32 Charges
Mini Fridge
33 Hours
Blender (500W)
3.5 Hours
1.9 Hours
Air Fryer (1500W)
1.2 Hours
EcoFlow DELTA pro power station 28354597027913 1024x1024@2x
EcoFlow DELTA Pro
Capacity 3600Wh
Phone (11W)
313 Charges
Laptop 60W
57 Charges
Mini Fridge
57 Hours
Blender (500W)
6.5 Hours
3.3 Hours
Air Fryer (1500W)
2.2 Hours
What AC output is best for a blackout or a brownout? Find out here.
You’ll need a portable power station with a high AC output to help you start up the essentials. All the EcoFlow DELTA series models come with more than enough power. They stretch from 1400W with EcoFlow DELTA mini to 3600W with the EcoFlow DELTA Pro. To give you context, heavy-duty appliances like fridges need anywhere between 840W – 1200W to start up. This makes any EcoFlow DELTA series model a great option for blackouts or brownouts. What’s more, EcoFlow DELTA series units are all fitted with X-Boost technology, which extends the output if you need a bit more power.
Secondly, you’ll need something that has enough capacity to cover the run time of your home appliances. All EcoFlow DELTA models have a relatively large capacity for their size and can run the majority of essential household appliances. However, with EcoFlow DELTA Max and EcoFlow DELTA Pro having expandable capacities, they are perfect for running the bigger stuff. You’ll be able to run AC units, electric dryers, or freezers in the event of a blackout or brownout. But you can find out more about which EcoFlow DELTA portable power station has the right capacity for you here
Charging
Finally, you’ll want to make sure you have a portable power station with a plethora of charging options at your disposal. With any EcoFlow DELTA Series model, this is exactly what you’ll have. If you’re an avid planner, EcoFlow’s EcoFlow DELTA series portable power stations are great as they can charge and store the grid’s power extremely quickly. In a matter of 65 minutes, any EcoFlow DELTA model can receive an 80% charge. Particularly useful if you know a brownout has been issued by your utility provider.
Renewable Energy Sources
I guess you’re wondering what charging options you have in the event of a blackout? Well thanks to each EcoFlow DELTA model’s solar compatibility, you can easily attach solar panels. This gives you more charging convenience, particularly if you don’t know how long a blackout will last. Each EcoFlow DELTA model has a different solar input depending on its size, stretching from 300W to 1600W solar input. You can check out an EcoFlow DELTA Series comparison to see which solar input suits you here
With EcoFlow portable power stations you can easily hook up solar panels to allow you to harness the sun's energy and stay powered.
However, if you’re on a budget and you don’t want to go down the solar panel route, it’s always possible to charge an EcoFlow DELTA model elsewhere. As blackouts are localized, take your unit and charge it at a friend’s place a few blocks away. Alternatively, if you have an EcoFlow DELTA Pro, take it to an EV charging station and add juice that way. In around 90 minutes, you’ll be at 100%, a great tool in the event of a rolling blackout.
Final thoughts
With our dependence on electricity growing and the pressure on the grid being pushed to its limits, blackouts and brownouts aren’t going away anytime soon. This coupled with the growth of unpredictable weather patterns, there’s never been a better time to prepare. The question is, which portable power station do you choose? Well, it completely depends on your household needs. If it’s power and capacity you’re after for the ultimate home backup, EcoFlow DELTA Max and EcoFlow DELTA Pro are great options. But if you’re in a state where blackouts and brownouts are less common, EcoFlow DELTA or EcoFlow DELTA Mini could be more for you.
EcoFlow DELTA SERIES
Christiana Eaton
Christiana Eaton
Hailing from the UK and currently traveling the world, Christiana is a seasoned freelance copywriter for EcoFlow with a keen interest in renewable energy and solar power.
spot_img
