Image 1
Image 1
How Do I Choose a Portable Power Pack?
A charged device is essential, so technology has evolved to create portable recharge options that ensure our phones and other small electronics never die, even on the go. Portable power packs and power banks are a go-to option for electricity you can take with you, so learn how to choose the right one that meets your needs.
What Can I Charge With a Portable Power Pack?
Portable power packs are versatile charging solutions that can charge myriad devices. They’re most commonly used to charge:
  • Smartphones and tablets
  • Portable gaming devices (like Nintendo Switch)
  • Digital cameras or action cameras (like GoPros)
  • GPS devices
  • Bluetooth headphones or speakers
  • Laptops (in emergencies)
If it’s a small device you can pack and take on a trip, it’s likely compatible with a portable power pack. However, note that you should only use one to charge a laptop in a worst-case scenario. Laptops usually require more output and capacity, which can quickly drain your energy source. But it can work in a pinch.
What To Consider Before Choosing a Portable Power Pack
Complete your due diligence to ensure you invest in a portable power pack that won’t disappoint you.
Size
Consider the device’s physical dimensions, especially if you plan to use it while travelling. Also, consider how much space is in your bag and whether you should look for an ultra-portable, streamlined model or something larger with more capacity.
Weight
Weight is also a factor, as luggage must meet certain limits when travelling by plane. These devices come in lightweight, pocket-sized units as well as heavier models. Consider your mobility needs and how long you’ll need to carry the device.
Capacity determines how many times you can charge your devices. A higher capacity (measured in Wh) means you’ll get more charges, but it also likely increases the device’s size and weight.
Output
You should also consider the output required to charge your devices. Today’s smartphones use anywhere from 5W to 20W of electricity when charging, a range that most models can generally handle.
For devices that require more output than a power bank can provide, you might need something more robust, like one of the EcoFlow RIVER 2 Series Portable Power Stations.
A model such as the EcoFlow RIVER 2 Max Portable Power Station has an output of 500W (1000W Surge), while the EcoFlow RIVER 2 Pro Portable Power Station upgrades that to an 800W output (1600W Surge). An additional benefit is all the extra devices and appliances you can run with your PPS.
Recharging
When the battery dies, most power banks can be plugged into a wall charger. This is usually reasonable, but if recharging is limited to AC charging and you find yourself off-grid, you may be out of luck.
However, suppose you choose EcoFlow Solar Generators as an alternative electricity source, like the EcoFlow RIVER 2 Max +160W Solar Panel. In that case, you can recharge your backup energy source anywhere, any time, as long as the sun is out.
Charging Speeds
Do you want to go from 0 to 100% battery life in a short time span? Look for a modern option with fast charging technology that’s compatible with your devices. While this may drain your backup battery faster, the trade-off for quick charging is worth it for some people and situations.
Pass-Through Support
Some models allow you to charge them while charging another device. This feature is called pass-through charging, and it’s especially helpful when there’s limited access to outlets or you forget to pack extra cords. Not all models include this feature, so check the manufacturer’s instructions before attempting pass-through support, as it could damage both devices if misused.
Travel Restrictions
Remember the rules and regulations for travelling with power packs. Most batteries must be packed in carry-on baggage, and certain wattages may require special approval. If you choose a large and heavy model that won’t fit or is too heavy to carry in your carry-on luggage, you may run into an issue while packing or checking your bag weight at the airport. Choose a model that’s easy to travel with if you plan on taking it on your adventures.
Built-In Leads
Built-in leads can minimise the mess of travelling with multiple cords. These leads come built into the power bank with various charging ports, so you’ll always be ready to charge your device with just one item.
How To Connect Your Device to a Power Pack
Most power banks include at least one of the following charging inputs, though some advanced options may feature more than one.
  • USB-A: This is a classic, rectangle-shaped port that nearly every TV or hard drive has included in the past two decades
  • USB-C: This is quickly becoming the default USB option, making USB-A a bit outdated. This option has become preferred because it allows you to plug into the port regardless of orientation. As Apple abandoned the Lightning connection for the USB-C format, it’s becoming the most common option. It should be at the top of your list of essential features when shopping for a power bank.
  • Micro USB: Also known as mini USB, this variant can be found in older smartphones. It’s much less common but may be found in some older power banks.
  • Wireless: A few power banks may also allow wireless charging using magnetic Qi technology. However, your phone must be Qi-certified for this to work.
Are Portable Power Packs Worth It?
Portable power packs are worth it to ensure your phone or other personal device stays charged throughout the day, especially while travelling or in an emergency. However, a portable power station may be better for greater electricity needs.
Choosing a portable power pack suitable for your needs depends on your travel plans, devices, and usage behaviour. Consider portability, capacity, and charging options to choose a model you’re pleased with.
If you need something with more capacity behind it, consider upgrading to an EcoFlow RIVER 2 Series Portable Power Station, like the EcoFlow RIVER 2 Max.
Image 1
Image 1
