EcoFlow Launches the EcoFlow River Series: Portable Power in Three Sizes
Power Stations Designed for Home or Outdoors
LOS ANGELES, Feb. 1st, 2021 – EcoFlow today announced the availability of the full line of River Series portable power stations. The lineup has three variations, EcoFlow River, River Max, and River Pro.
The commonality between them is that they’re all designed for outdoors and home backup use, and are all light, portable-first entries to the industry. All three options also come with EcoFlow’s proprietary X-Boost technology, allowing users to power devices that require up to 1800W.
EcoFlow RIVER
EcoFlow River is the most portable pick of the River series. You can take it camping or use it during blackouts to power appliances in your home. It has 288Wh of capacity and weighs in at only 11 pounds. River is designed for flexibility and can be expanded with an extra battery that screws onto the bottom, doubling the capacity, without adding too much weight. This transforms River into River Max.
EcoFlow River Max
River Max is, as aforementioned, a larger alternative with a 576Wh capacity. With double the capacity of River thanks to the extra battery, it’s great for those that need a little more power for longer trips, or for an extended home backup solution. The extra battery can also be removed at any time if you need to trim down on weight.
EcoFlow River Pro
EcoFlow River Pro is a larger alternative to both River and River Max. With a starting capacity of 720Wh, it’s ideal for long-haul adventures and home backup. Its capacity can be doubled too with an extra battery that plugs in via an expansion port on the side of the unit.
Availability
The River Series EcoFlow aims to deliver a size and price point for anyone looking to get started with portable power stations. All three options are available today from ecoflow.com, with prices starting at $349.
Share this article
Popular posts
RELATED POSTS
