South Africans have been coping with Eskom’s load shedding for years. If you’re tired of two-hour blackouts occurring almost daily with no end in sight, you can use a load shedding kit to provide...
Living in South Africa is more affordable than in many other countries, with living costs and rent typically 50% or more cheaper than in most countries. Of course, it depends on where you live,...
It doesn’t matter whether you install an on-grid, off-grid, or hybrid residential solar power system.
You need at least one solar inverter.
Depending on the size and type of solar panel array you choose, you may...
Sump pumps protect your basement from flooding, so understanding how much power a sump pump uses can make the difference between a dry foundation and a homeowner's worst nightmare. Learn about the power needs...
