EcoFlow River 2 Series Comparison: Features, Specs, Applications.
The EcoFlow River 2 series offers industry-leading portable power stations designed for emergency, off-grid, and portable power on the go. This portable power station comparison takes a look at each EcoFlow River 2 product, comparing portability, capacity, output, solar capability, battery chemistry, and more.
6 Tips for Choosing a Portable Power Station
EcoFlow River 2 series portable power stations offer the best portable power for off-grid adventures. Just like the EcoFlow DELTA 2 series, the River 2 series come in various shapes and sizes, with different features tailored toward different users. Take a quick look below at everything you need to know before buying a River 2 series portable power station.
Portability
The best portable power station is the one that you can take around and use anywhere. Because, let’s face it – lugging around a huge battery is not fun. EcoFlow River 2 series portable power stations start at 3.5 kg and go up to around 6.1 kg. So if you’re looking for something super light and small, the new EcoFlow River 2 is a great choice. Or, if you’re looking for something light with a larger capacity, the EcoFlow River 2 Max has a detachable battery that you can take off whenever you like.
The capacity of your portable power station determines how long you can stay powered on, with larger capacities suited towards heavier applications like emergency or off-grid power. The RIVER 2 series features smaller capacities to power smaller electronics and devices without adding much bulk or weight.
Output
This one is pretty simple — higher outputs allow you to power more demanding appliances like hairdryers, small fridges, or even vacuums (camping can get messy). The good news is that all EcoFlow portable power stations feature X-Boost technology, extending your output whenever you need extra power.
Fast Charging
Nobody wants to wait half a day to charge up. All EcoFlow portable power stations feature extremely fastest charging in as little as 60 minutes.
Whether you’re camping or out in the wild, solar charging gives you another effortless charging option to stay powered on. For those of you in sunny locations, you can harness the sun’s power to generate reliable solar energy. What if you’re not blessed with all-year-round sunshine? Not to worry. EcoFlow portable power stations have an advanced MPPT algorithm that automatically detects voltage and current in real-time to increase solar generation, even in cold and cloudy conditions.
You’ll often hear a portable power station called a solar generator, battery generator, or even a portable generator. At the end of the day, they’re all portable battery-powered devices. One important thing to look out for is the battery chemistry. The EcoFlow River 2 series utilizes LFP batteries, which reduce the unit’s weight and increase the output performance in colder environments. That gives you a lightweight battery you can use all year round.
Now that we have all that covered, let’s start by looking at the EcoFlow River2  series.
EcoFlow River 2 Max
Hit the outdoors and keep everything charged up with the EcoFlow River 2 Max.
Portability: 6.1 kg Design
The EcoFlow River 2 Max comes in at around 6 kg, featuring the same comfortable grip, design, and frame as the EcoFlow River 2.
Capacity: 512Wh Capacity
From outdoor adventure to home backup, having an extra power source makes all the difference. The EcoFlow River 2 Max comes with a powerful battery that gives you more runtime and an extra layer of security when the going gets tough.
Output: 500W AC Output
The EcoFlow River 2 Max features 3 pure sine wave AC outlets that deliver up to 500W. That’s enough to power a 50″ TV, toaster, and many of your other favourite devices. If you do find yourself in a situation where you need to power more demanding devices, turn on X-Boost to power devices up to 1000W.
Fast Charging: 0-100% in 1 hour
Charge your EcoFlow River 2 Max from 0-100% in 1 hour with our unique charging technology that offers you the fastest portable power station charging on the market.
Solar Charging: 200W Solar Charging
Whether you’re preparing for a power outage, going off-grid, or simply want a cleaner way to stay powered on, River 2 Max connects with up to two 160W solar panels to give you clean, green power.
Battery Chemistry: LFP Battery
The River 2 Max features an LFP battery, which keeps the unit lightweight, portable, and safe while providing quality output performance even in cold environments.
EcoFlow River 2 Max: The Final Verdict
If you’re looking for a portable power station that gives you flexible power in a variety of different situations, the EcoFlow River 2 Max is a great option. It’s that simple.
EcoFlow River 2
Keep all of your devices charged up from one convenient location. The EcoFlow River 2 has a 256Wh capacity that charges up fully in 60 minutes flat. That’s power that keeps you going.
Portability: 3.5 kg Lightweight Design
At approximately 3.5 kg, the EcoFlow River 2  is the lightest portable power station in the River 2 series. It features a comfortable handle for easy transportation and a convenient lunch box design that makes it easy to store.
Capacity: 256Wh Capacity
Just like the EcoFlow River 2 Max, River 2 has an impressive capacity of up to 256Wh. From power outages to extended camping trips, you get peace of mind knowing you’ve got hours of power.
Output: 300W AC Output
The EcoFlow River 2 has 3 pure sine wave AC outlets that deliver up to 300W or 600W on X-Boost mode. That means you can power your lights, fan, and several of your favourite devices wherever you go.
EcoFlow portable power stations are the fastest charging on the market. The EcoFlow River 2 charges up rapidly from 0-100% in just 60 minutes.
You can connect up to 2x 110W solar panels to River 2 to charge up with the sun. You’ll be fully charged up and ready to go in just 3 hours. So whether you’re camping, in your RV, or relaxing in your off-grid cabin, you can carry on doing the things you love while River 2 harnesses energy from the sun.
Just like the other portable power station in the River 2 series, the EcoFlow River 2 sports a reliable LFP battery. This keeps the unit environmentally sustainable and non-toxic as well as safe and lightweight with improved discharge and charge efficiency.
EcoFlow River 2: The Final Verdict
If you’re looking for something simple and reliable to keep your devices charged up, the EcoFlow River 2 is an excellent choice. Hit the outdoors and take power with you wherever you go.
EcoFlow River 2 Series: Compare Specs
River 2River 2 Max
Capacity256 Wh512 Wh
Output300W500W
Weight3.5 kg6.1 kg
Charging Speed360W660W
Solar Input110W220W
Battery ChemistryLFPLFP
The EcoFlow River 2series offers industry-leading portable power stations for pretty much any type of application. From emergency backup to off-grid power, pick up an EcoFlow River 2 series portable power station and enjoy clean, green energy all year round.
Share this article
Thanks for joining us!
Please check your email.
Popular posts
RELATED POSTS
