Table of Contents
You’re not the only one shocked when reading your recent electric bills. Rising energy costs have been frustrating many people lately. Several factors drive up costs, from seasonal spikes to inefficiencies in your home. Pinpointing the reasons behind your high bills is the first step to saving money. This guide explores the most common causes of high bills and offers actionable solutions to help you take control of your energy usage. Now, let’s start looking at ways to save on your bill.
8 Possible Reasons Your Electric Bill Is So High
Seasons and Weather
We use more air conditioning during heat waves and more heating when cold snaps hit. If your bill looks higher, compare it to last year’s to see if it’s just a seasonal trend. However, as our climate changes, your local weather could also be affecting your bill.
Poor Insulation and Air Leaks
Poor insulation in walls, attics, doors, and windows causes air leaks that can cost significant money. Those losses are made even worse during extreme weather.
Poor HVAC Maintenance
Air conditioners and heaters work much more efficiently with proper maintenance. Dirty filters or worn-out parts cost dearly when your equipment must work harder to heat or cool the same amount as before.
Increase Cost of Power Generation
Much of our power generation still comes from expensive fossil fuels. Demand increases prices, and power plants pass the increases on to consumers. State electricity bills will also determine what you pay. Some states, like California, have experienced high increases due to repairs and upgrades caused by climate-related disasters.
Current Events
Current events worldwide also affect fuel demand, availability, and price. War, natural disasters, and regulation changes strongly affect the price of fossil-fuel-dependent electricity.
Using Too Much Peak Electricity
Variable electricity rates, where you pay more during the day and early evening when demand is higher and less late at night when demand is lower, can cost you money if you still run all your appliances during peak hours.
Leaving Lights, Fans, and Appliances Running
Leaving lights, fans, TVs, computers, game consoles, and other appliances on when not needed can cost you money. Leaving fans running can also cost money unless placed effectively to help circulate the air, which may reduce your HVAC costs.
Increased Usage
If you have more appliances or people in your home, your average household use will rise. Also, as more people start working remotely, they use more electricity at home during the day, increasing their power costs.
What Can I Do to Save On My Electric Bill?
- First, calculate your kWh usage, then examine how much each appliance uses, and see where you use the most power. With significant changes, you could reduce consumption by 75%.
- Switch to energy-efficient appliances with an ENERGY STAR® rating.
- Upgrading the insulation in your walls and attic could save you 10% on your bills. Replacing drafty windows and adding weather stripping to doors and windows can save 12% or more.
- Take advantage of off-peak hours if you’re on a variable rate system. Run washing machines, dryers, and dishwashers late at night instead of the early evening, when power is most expensive. You can also use the EcoFlow Portable Power Stations to store energy at night when power is cheaper and then use it to run appliances during peak hours.
- Invest in an EcoFlow DELTA Series Solar Generator. When you use solar panels to generate your electricity, you can reduce your dependence on the grid. For instance, the EcoFlow DELTA Pro 3 starts at 4kWh, which will run your essential appliances, saving significant money on electricity bills. You can expand it with additional panels and batteries up to 48kWh, which is plenty for almost any home to go off-grid and never pay a power bill again.
- Replace old incandescent light bulbs with LEDs. According to the Department of Energy, LED bulbs use up to 90% less energy and last 25 times longer than incandescent bulbs. They are also more efficient than compact fluorescent bulbs.
- Turn off lights during the day and use natural lighting. Also, turn off lights when you’re not in the room; consider using motion sensor lights so they do this automatically.
- Wash clothes with cold water since 90% of the electricity for washing is used to heat water.
- Only wash full laundry and dishwasher loads.
- Open the dishwasher when it’s done washing and let it air dry.
- Clean out your dryer vent so it works more efficiently. Better yet, install a clothesline—it’s free.
- Use a microwave or toaster oven for smaller items rather than a conventional oven.
- Use a window fan instead of air conditioning. Run one to draw air in at one end of the house and another to push air out at the other end, and you’ll quickly cool your home.
- Turn the thermostat down at night or when you aren’t home. Install a smart thermostat to make it easier.
- Lower your water heater setting so it doesn’t have to work so hard.
- Use window drapes to manage sunlight. Close the drapes during the summer days to keep the heat out, and open them in the winter to let the heat in.
- Unplug appliances when they aren’t in use to avoid phantom energy usage, which can add up over time when they draw power in standby mode. You can also use smart plugs that automatically turn them on and off.
- Take advantage of state and federal programs promoting energy efficiency to save money on taxes or get rebates.
- Shop for a different energy supplier with better rates.
Seasons and weather can spike bills, as can increases in your electricity rates or a switch to peak and off-peak rates if you still use your appliances during peak hours. Other factors include poor insulation, increased usage, and poor HVAC maintenance.
Your heating and cooling system accounts for 40-50% of household energy usage. Also, when the weather changes, especially if your home is poorly insulated, it can significantly drive up your bill.
High electric bills often result from seasonal changes, inefficient appliances, and habits that unknowingly waste energy. Simple fixes, like insulating your home, using energy-efficient appliances, and timing your electricity use outside peak hours, can significantly cut costs. For a longer-term solution, consider investing in solar generators like the EcoFlow DELTA Series Portable Power Stations to reduce your reliance on the grid. By taking these steps, you’ll save money while contributing to a more sustainable future.
