Table of Contents
Starlink’s satellite internet service provides high-speed, reliable internet to areas without access to fiber or cable. Switching to this internet provider is simple. Our guide covers everything you need to know, including the hardware included in the starter kit, available accessories, and which ones you may need. Additionally, it provides easy-to-follow steps to help you install your Starlink system, ensuring a smooth transition to faster, more reliable internet wherever you are.
What’s Included in the Starlink Standard Kit?
- Dish (Antenna): This is the main component of the system. It connects the system to Starlink satellites to provide internet service.
- Wi-Fi Router: The router distributes the internet connection wirelessly throughout your home or vehicle. It works like a home Wi-Fi router system.
- Starlink Cable: This cable connects the antenna to the router for data transmission. It’s 15.2 m (50 ft) long and supplies the dish with power from the router.
- AC Cable: This cable supplies power to the router. Starlink systems require AC power to work, so if you’re off-grid, you may need an inverter or a DC-AC converter for proper operation. An EcoFlow DELTA 3 Pro provides AC current, 1800W total, across six outlets, so an inverter or converter is not needed to power Starlink with the portable power station. You can also run essential home appliances with that kind of power.
- Mounting Base: A standard mounting base is included for placing the dish on a flat surface. It’s tripod-style and not ideal for permanent installation or areas with obstructions.
What Accessories Are Available for Starlink?
- Pipe Adapter: Allows the dish to be mounted on an existing pole or mast
- Volcano Mount: Provides a stable and weather-resistant installation on peaked roofs
- Pivot Mount: Designed for mounting on angled surfaces
- Mast Mount: Extends the dish’s height for improved satellite visibility, thus creating a stronger connection
- Flashing Mount: This mount minimizes the risk of leaks when mounted to a roof. The base is a waterproof metal sheet flashing that helps create a seal around the mount.
- Mesh Wi-Fi Router: This extends the Wi-Fi signal’s coverage. It connects to the main router, and additional mesh routers are placed around the home or building where stronger coverage is needed.
- Longer Starlink Cable: The cable is also available in lengths of 75 ft (22.9 m) and 150 ft (45.7 m). A longer cord allows for more flexible placement.
- Carrying Case: A protective case for storing and transporting equipment
- DC Power Supply: This is useful for RVs and off-grid setups. It allows specific models to run off 12V or 24V DC power.
- Ethernet Adapter: A physical, wired connection alternative instead of wireless connections.
- Flat High-Performance Mount: A mount that keeps the dish stable on RVs and vehicles
- Portable Power Supply: Not sold by Starlink, but this portable battery allows for off-grid use of it. The EcoFlow RIVER 3 Portable Power Station provides enough power to run Starlink for several hours off-grid.
How To Connect to Starlink: Step-By-Step
Step 1: Unbox and Inspect the Kit
Carefully unbox the Standard Kit. Check that all parts are present: dish, router, cables, and mount. Then, ensure that the pieces are not damaged.
Step 2: Choose a Suitable Location for the Dish
If you haven’t done so already, find a good post to place the antenna. The site should be free of obstructions like trees and tall buildings, and the antenna should have a clear view of the sky. You can check for obstructions in the Starlink app.
Step 3: Mount the Dish
Install the mount and the dish in your desired location. Use the correct mount to place it on a roof or moving vehicle. The mount in the standard kit is ideal for flat, unmoving terrains. It’s not suitable for cars, RVs, poles, or slanted roofs.
Step 4: Connect the Dish to the Router
Connect the dish to the router using the Starlink cable. If the standard one compromises the dish’s location, you may need to order a longer cord.
Step 5: Connect the Router to Power
Connect the AC cable to a power source, like an outlet inside your home. The outlet can connect to your home’s electrical grid or a portable power station like the EcoFlow DELTA 3 Plus. With a 1024Wh capacity, you can power Starlink and other electronic devices like TVs, laptops, and gaming systems. Be sure to calculate how much power you need before heading off-grid.
Step 6: Power Up the System
Then, press the power button to turn on the router. The system will require an initial boot-up process. Wait for the router’s indication light to turn green.
Step 7: Set Up Wi-Fi Network
If you haven’t already done so, download the Starlink app. The app will prompt you to set up the network name and password and connect your phone to the Starlink Wi-Fi network.
Step 8: Test the Connection and Adjust for Optimal Performance
Once the network is set up, test the speed and signal strength. If needed, adjust the dish’s position for better signal reception. The Starlink app setting can also be fine-tuned for optimal performance. Now, you’re ready to enjoy your Starlink Internet.
The standard kit has all the necessary hardware to run your Starlink model. It comes with a standard mount and tripod style and is best suited for flat terrain. You may need to upgrade the mount to securely place the antenna where needed, such as a roof, moving RV, or pole.
The standard cable allows you to place the router up to 50 feet away. For more distance, upgrade to a longer Starlink cable. They come in 75-ft and 150-ft lengths. If you need a longer cord, you can purchase a third-party 300-ft cord, but performance can degrade.
Starlink comes with its own Wi-Fi router in the Standard Kit. You won’t need a third-party Wi-Fi router, and it wouldn’t be compatible with it anyway. The Starlink router connects to the antenna and distributes power to it through the Starlink cable.
The standard kit includes everything needed to run Starlink Internet: an antenna, Wi-Fi router, Starlink cable, AC cable, and mount. Accessories like pivot mounts for angled surfaces and mast mounts for increased height can help optimize the signal. To set up, unbox the kit, place the mount, antenna, and router, and connect the dish using the Starlink cable. Power up the system, and you’re ready to access Starlink Internet. For portable use, consider EcoFlow Portable Power Stations, providing dependable electrical solutions at home or on the go.
