6 Ski Essentials for 2025: Must-Have Gear for the Slopes
Skiing is one of the most exhilarating winter sports, but the experience can vary dramatically depending on your gear. The right equipment ensures comfort, safety, and endless enjoyment, while the wrong choices can lead to a frustrating or disappointing day on the hill—or worse. Whether you’re hitting the slopes for the first time or a seasoned pro, this guide covers all the ski essentials for a successful and memorable time on the mountain.
What Ski Essentials Do You Need?
Clothing
  • A ski jacket and ski or snow pants are essential. Choose well-insulated, waterproof jackets and pants made of breathable fabrics.
  • Base layers of moisture-wicking, ultra-warm merino wool are best to keep you warm without the bulk. Never use cotton as it holds moisture in.
  • Mid-layers can be made of comfortable fleece or wool.
  • Balaclava or neck gaiters will help protect you from the cold, wind, and sun. A balaclava is best in frigid temperatures since it covers your head, while neck gaiters are excellent in milder conditions.
  • Gloves or mitts. Choose a quality pair with good insulation; opt for waterproof ones for wet conditions. Gloves vs. mitts is a personal preference. However, mitts keep you warmer on cold days, while gloves offer better dexterity.
  • Socks. Never underestimate how vital good socks are. Choose tall socks that go above your boots to prevent chaffing. Avoid cotton or overly thick socks.
Ski Equipment
  • Skis, bindings, and poles. If you’re a newbie, rent these for your first few times, then invest in your own once you start going more often. Bindings should be adjusted for your skill level.
  • Ski boots. Well-fitted ski boots are essential for performance and comfort. The rental shop tech or ski store should help you get a good fit. You could also consider heat-molded liners and form-fitting inserts for a precision fit.
  • Goggles. Choose ones with good UV protection to prevent snow blindness. They also protect your eyes from the wind and cold. Ensure they fit well.
  • Waxing kit for those who wax their skis at home. Your kit should include wax, an iron, and a scraper.
  • Edge Sharpener for those who tune their edges at home. Choose a simple one with a plastic grip and a preset angle.
  • A backpack. Choose a small, waterproof backpack for snacks, water, extra layers, and safety gear. Small and snug is key—you don’t want a bulky pack that will impact performance or get stuck on chairlifts or in trees.
  • Water bottles or hydration packs. They’re not essential, but they are helpful. Staying hydrated will keep you on the slopes rather than returning to the lodge. Choose a small water bottle that will fit in your jacket to keep it from freezing. Alternatively, choose hydration packs with insulation for the bladder and the hose.
Safety Gear
Ski hills can get cold, so understanding winter safety and being prepared is essential. If you just ski the main hills, you won’t need the additional safety gear for backcountry skiers.
  • Bring a helmet. This is essential for any skill level. Choose one from a reputable brand and try it on to ensure it fits well and is comfortable so you’ll actually wear it.
  • Sunscreen and lip balm. These are a must-have since you can burn quickly when the sun reflects off the snow. Cover your face, and don’t forget your ears if they’re exposed. Lips can also get dry and cracked from the cold and wind.
  • Emergency whistles. These cheap and lightweight gadgets can be attached to your outer jacket and used to signal for help.
  • A small first aid kit is always a good idea. Ensure it includes medical tape, gauze, a tensor and triangle bandage for sprains, antiseptic cream, and bandaids for blisters.
Additional Safety Gear for Backcountry Skiers
  • Avalanche transceivers are essential for backcountry skiers. Choose an up-to-date beacon with three antennas and a range of at least 40m; Bluetooth and software updates are also good options.
  • Avalanche airbags are another good choice; they might save your life.
  • Snow probes. These should be lightweight and made of aluminum. For coastal skiers, choose a longer pole, while those inland with thinner snow can carry a shorter one.
  • A snow saw for digging snow pits.
  • Avalanche rescue shovels. These should be compact and lightweight but have a strong blade and handle made of durable materials.
Comfort Gear
  • Electronic boot warmers are a great idea if your feet are prone to getting cold. They come with rechargeable batteries, so there’s no need for single-use disposable chemical products that’ll be uncomfortable inside your boots.
  • Glove liners are great for adding warmth. Look for touch-screen compatible ones so you can use your phone without removing them. Alternatively, look for rechargeable hand warmers that slide inside your gloves rather than single-use chemical warmers. If you’re out for days in the backcountry, recharge them with a portable power station.
  • Insoles for ski boots add comfort and boost performance. Look for quality insoles that support your foot arch without being too rigid. If your budget allows, you can also get custom ones from your boot fitter.
  • Foam rollers are a nice option if you plan to ski for multiple days. They can help you roll out the knots in your back and legs, which will make you less sore the next day.
Gadgets
  • A camera. This could be your smartphone or a camera. You can also bring a helmet camera to take videos of your adventures, but look for waterproof devices with batteries designed for the cold.
  • Smartwatches with GPS are also a good option, especially for backcountry skiers.  Alternatively, a GPS device with contour shading for slope angle is also ideal.
  • A tablet or computer to download your videos and pictures.
  • The EcoFlow Portable Power Stations are perfect for portable power anywhere. Their powerful LiFePO4 batteries will still work down to -4°F. Use them to power your electronic devices or recharge your camera, phone, or hand and foot warmers.
Travel Essentials
  • Four-season tents and sleeping bags are essential for those camping in winter. Winter conditions require extra camping essentials to stay safe and warm, so be prepared. If you sleep in the backcountry, also be prepared for winter storm safety
  • The EcoFlow Wave 2 Portable AC is an excellent choice for winter camping or if you plan to sit outdoors for a while after a day on the hill to help you stay warm. While it is an air conditioner, it’s also a heater, can be used indoors or outdoors, and lasts up to 8 hours wirelessly.
  • EcoFlow GLACIER Portable Refrigerator will keep your perishable foods safe and keep your water at drinkable temperatures. If the temperature outside drops, it will prevent your food and water from freezing since it keeps the contents at a consistent temperature.
  • The EcoFlow RIVER 3 Portable Power Station is essential for recharging your phone, helmet cam, rechargeable lights, hand and foot warmers, and other electronic devices.
  • Travel ski bags are essential for those flying as they will keep your gear safe and together. Make sure it’s well-padded for extra protection in checked luggage. A boot bag should be waterproof inside for easy cleaning.
  • A roof rack or car topper box is also a good idea for those driving to the hills. It keeps gear safe and makes more room for friends and family in the car.
Choosing the Right Ski Essentials: What To Consider
Dress For the Climate
Coastal skiers typically have warmer and wetter conditions, so they’ll want less insulation and more waterproofing than those who ski in the Rockies. Inland hills are drier and colder, so insulation is more important than waterproofing.
Layers are Essential
Regardless of the climate, dressing in layers is essential since you can remove them and put them in your backpack if you get warm, then put them back on when you get chilly again.
Avoid Cotton
Cotton might be comfortable and all-natural, but it also holds moisture, which should always be avoided on the ski hill. When you sweat a lot or your clothes get damp from melted snow, the risk of frostbite or hypothermia is increased. Choose merino wool for an all-natural material; it’s thinner than traditional wool but really holds in the warmth. For those on a budget, synthetic materials might be a cheaper option.
Budget
New skiers shouldn’t rush out and buy tons of gear until they know this is something they want to do often. You can use your current outdoor clothing if it’s well-insulated and rent some gear the first few times. If you’re going to keep skiing, start buying gear and better outerwear.
What Ski Gear Is Necessary?
At a minimum, you will need snow pants, a winter jacket, gloves or mitts, skis, poles, bindings, boots, a helmet, and goggles. Wearing good merino wool base layers and socks is also strongly recommended.
What Not To Wear on Ski Slopes?
Never wear cotton on the ski slopes. Cotton holds onto moisture and will make you colder instead of warmer if it gets damp from sweat or melted snow. Always opt for moisture-wicking materials like merino wool or synthetics.
Skiing is a gear-intensive sport, but the right equipment can make all the difference in your performance, safety, and overall enjoyment. This guide ensures you’re well-prepared for the slopes, from proper clothing and equipment to safety tools and comfort gadgets. Don’t forget to check out the EcoFlow RIVER 3 Portable Power Station for portable power to recharge all your devices and maximize your enjoyment. Now, go hit the slopes and have fun.
