A Complete Guide to PC Power Supplies: ATX, SFX, TFX, & EPS Types
A power supply unit (PSU) is the backbone of any computer, but not all PSUs are the same. Choosing the wrong one can lead to inefficiency, instability, or even hardware failure. Whether you’re building a gaming rig, upgrading a workstation, or configuring a compact PC, understanding supply types, efficiency ratings, and wattage needs is essential.
This guide breaks down the different power supplies, helping you select the best fit for your system.
What Is a PC Power Supply?
A PC or PSU converts electrical power from an external source into a usable form for the computer’s internal components. It transforms alternating current (AC) from a wall outlet into direct current (DC), which is required for the motherboard, processor, graphics card, storage drives, and other peripherals.
Beyond conversion, the PSU plays a key role in voltage regulation and system protection. It ensures components receive the appropriate voltage while safeguarding against surges and fluctuations. Many modern PSUs also include overvoltage, undervoltage, and short-circuit protection to prevent failures.
Power supplies come in various form factors to accommodate different PC builds. They also vary in wattage, efficiency ratings (such as 80 PLUS certifications), and modularity, allowing users to select a PSU that best fits their system’s needs.
A high-quality PSU is essential for stability and longevity, helping to prevent random shutdowns, performance issues, and potential hardware failures.
How Do Computer Power Supplies Work?
A computer power supply unit (PSU) bridges an external power source and a computer’s internal components. It converts high-voltage alternating current (AC) from a wall outlet into low-voltage direct current (DC), which components such as the motherboard, CPU, graphics card, and storage drives require.
Without this conversion, the system would be unable to operate, as modern electronics require stable DC power to function correctly.
The Power Conversion Process
The PSU’s internal transformer steps down the incoming AC voltage, after which a rectifier circuit converts it into DC power. This process is followed by capacitors and voltage regulators that smooth out fluctuations and ensure a consistent supply.
The unit then distributes the power across different voltage rails—typically 12V, 5V, and 3.3V—which serve different hardware components:
  • 12V Rail – Powers the CPU, GPU, cooling fans, and other high-energy components.
  • 5V Rail – Supplies power to USB ports, storage drives, and some motherboard functions.
  • 3.3V Rail – Used primarily for RAM, chipset functions, and select motherboard components.
Many modern PSUs feature high-efficiency circuitry designed to reduce power loss during conversion. With an 80 PLUS certification, such units minimize heat output and maximize performance, ensuring stable and efficient energy delivery for both standard desktops and power-hungry gaming setups. For an extra boost of reliable power when you need it most, the EcoFlow RAPID Power Bank offers a versatile solution, providing fast and efficient charging for your devices.
Regulation and Protection Mechanisms
In addition to conversion, a PSU is responsible for voltage regulation and power protection to safeguard components from damage. Most high-quality power supplies include built-in protections such as:
  • Overvoltage Protection (OVP) – Prevents components from receiving excessive voltage.
  • Undervoltage Protection (UVP) – Ensures that insufficient voltage doesn’t cause instability.
  • Short Circuit Protection (SCP) – Automatically shuts down the PSU if a short circuit occurs.
  • Overcurrent Protection (OCP) – Stops excessive current from damaging delicate circuits.
By integrating these safety features, power supplies help prolong a computer’s lifespan while maintaining system stability under various load conditions.
Efficiency and Heat Management
Power supplies generate heat during the conversion process, so efficient cooling solutions are essential. Most modern PSUs use active cooling fans that adjust speed based on temperature, while some high-end models employ fanless operation at low loads to reduce noise.
Selecting a high-efficiency PSU reduces electricity costs and enhances overall system reliability. The EcoFlow RIVER 3 Portable Power Station, for example, is designed with high-efficiency power management, making it ideal for users who prioritize energy conservation without compromising on performance.
PC Power Supply Components
A PSU consists of several key components that work together to regulate, convert, and distribute power efficiently. Each component plays a specific role in ensuring stable delivery and system protection.
Transformer
The transformer is responsible for stepping down the high-voltage alternating current (AC) from the outlet to a lower voltage level suitable for computer components. This process is essential for ensuring the system receives the correct voltage before conversion to direct current (DC).
Rectifier
A rectifier converts the incoming AC power into DC. Since computers require a steady flow of DC electricity, the rectifier ensures that the power supply delivers consistent energy without fluctuations that could damage hardware.
Capacitors
Capacitors smooth out voltage fluctuations and store energy temporarily to help stabilize delivery. High-quality capacitors are essential for preventing sudden voltage drops or spikes, which can impact component performance or lead to system crashes.
Voltage Regulator
The voltage regulator ensures that each computer component receives the appropriate voltage level. Common voltage rails include 12V, 5V, and 3.3V, which serve different system parts like the CPU, GPU, motherboard, and storage drives.
Cooling System (Fan or Passive Cooling)
A power supply cooling system prevents overheating by dissipating excess heat generated during the conversion process. Most PSUs use active cooling fans, while high-efficiency models may feature fanless designs that rely on passive cooling for silent operation.
Protection Circuitry
Many modern power supplies feature built-in protection mechanisms to safeguard against surges, overvoltage, undervoltage, short circuits, and overheating. These protections help extend the lifespan of both the PSU and the connected components.
Opting for a reliable PSU with high-quality components, such as the EcoFlow RIVER 3 Plus, ensures stable delivery, better efficiency, and a longer system lifespan.
Types of Computer Power Supplies
Computer power supplies come in various form factors, each designed to fit specific PC case sizes and requirements:
ATX
The ATX (Advanced Technology eXtended) power supply is the standard PSU form factor for most desktop PCs. It typically measures 150mm wide, 86mm high, and 140mm to 180mm deep, following Intel’s ATX standard.
SFX
The SFX (Small Form Factor eXtended) supply is a compact alternative to ATX, designed for small form factor (SFF) PC cases. It usually measures 125mm wide, 63.5mm high, and 100mm deep.
TFX
The TFX (Thin Form Factor eXtended) power supply is a long, narrow PSU for slim desktop PCs and HTPC cases. It typically measures 85mm wide, 64mm high, and 175mm deep.
EPS
The EPS (Entry-Level Power Supply) standard is used in servers and high-performance workstations. It follows the EPS12V specification and offers extra CPU power connectors for dual-CPU and high-load systems.
Selecting the Ideal Power Supply
A properly sized PSU ensures stable performance, longevity, and energy efficiency, while an inadequate one can lead to system instability, power issues, or hardware damage. For those seeking a versatile and reliable backup solution, the EcoFlow RIVER 3 Solar Generator offers dependable energy delivery with impressive efficiency, making it ideal for both home and portable power needs.
What To Consider When Choosing a PC Power Supply
Picking the most suitable power supply is essential for system stability, performance, and longevity. A poorly chosen PSU can lead to system crashes, overheating, and potential hardware damage. Several key factors should be considered when selecting a new build or upgrading your power supply.
Wattage Requirements
The power supply must provide enough wattage to support all connected components. The CPU and GPU are typically the most intensive parts, and their combined requirements should be considered when selecting a PSU.
Efficiency Rating
Efficiency is measured by the 80 PLUS certification system, which indicates how much energy is wasted as heat during conversion. Higher efficiency ratings reduce energy consumption and heat output, improving system reliability.
The most common efficiency ratings include:
  • 80 PLUS Standard (80% efficiency)
  • 80 PLUS Bronze (82-85% efficiency)
  • 80 PLUS Silver (85-88% efficiency)
  • 80 PLUS Gold (87-90% efficiency)
  • 80 PLUS Platinum (89-94% efficiency)
  • 80 PLUS Titanium (90-96% efficiency)
A more efficient PSU generates less heat, reducing the need for aggressive cooling and leading to quieter operation.
Form Factor
The PSU’s physical size and mounting configuration must match the computer case. ATX is the most common, but compact builds may require an SFX or TFX unit. EPS power supplies are designed for high-performance workstations and servers, while ATX units are used in specialized applications.
Voltage Regulation and Protection Features
A reliable PSU should include built-in safety mechanisms to protect components from power fluctuations. Overvoltage, undervoltage, short circuit, and overcurrent protection help prevent damage due to unstable delivery. High-quality capacitors and voltage regulation circuits ensure consistent output, which is crucial for system stability.
Selecting the Right PSU for Your Needs
Whether building a gaming PC, workstation, or compact system, selecting a power supply with the right wattage, efficiency, and reliability balance is crucial. A high-quality PSU ensures smooth performance, reduces the risk of hardware failure, and supports future system upgrades.
What Is the Difference Between ATX and TFX?
ATX supplies are standard-sized units used in most desktop computers, offering higher wattage and expandability. TFX supplies are smaller and designed for compact and slim PC cases. TFX units typically have a lower output and use a different mounting orientation compared to ATX PSUs.
What Is the Difference Between ATX and EPS?
ATX supplies are designed for consumer desktops, typically providing a 24-pin motherboard connector. EPS supplies follow the EPS12V standard, featuring additional CPU connectors (8-pin or 8+8-pin) for high-performance workstations and servers. This ensures stable delivery to multi-core processors and demanding system configurations.
What Is the Power Supply Rule for a PC?
The general rule is to use a supply that meets or exceeds the total wattage required by all system components. A PSU should provide at least 20-30% more wattage than the estimated consumption to ensure stability, accommodate peak loads, and allow for future hardware upgrades.
How Do I Know What Power Supply I Need for My PC?
Determine your system’s requirements by adding up the wattage of all components, especially the CPU and GPU. Use an online PSU calculator for accuracy. Consider wattage, efficiency rating, form factor, and modularity when selecting a PSU to ensure compatibility and reliable performance for your build.
A reliable power supply ensures stability, efficiency, and longevity for any PC build. Choosing the right PSU means considering wattage, efficiency, form factor, and protection features to prevent instability and hardware failures. Understanding ATX, SFX, TFX, EPS, and Flex ATX helps in selecting the best fit.
For those needing backup power for critical devices, the EcoFlow RIVER 3 Portable Power Station offers a portable and efficient power solution, ensuring uninterrupted energy when it matters most.
