Lithium vs. Alkaline Batteries: Which Is Better?
In today’s world, the choice between lithium and alkaline batteries is becoming more critical than ever as we strive to find sustainable and efficient ways to supply our energy needs for everything from everyday gadgets to larger energy solutions like home backup.
Each type of battery offers distinct advantages and is tailored for specific applications, making it essential to understand their differences. This article delves into each battery’s properties, longevity, and performance, providing insights to help you make informed decisions.
What Is a Lithium Battery?
These batteries utilize lithium compounds and can be recharged and reused hundreds or even thousands of times. They are widely used in electronic devices like smartphones, laptops, tablets, cameras, and electric vehicles.
They work when the compounds within release ions that move from the negative electrode (anode) to the positive electrode (cathode) while in use. When they’re being recharged, the ions simply flow in the opposite direction.
The main types on the market today utilize either lithium cobalt oxide, lithium manganate, lithium nickel oxide, or the newer lithium iron phosphate (LiFePO4). Most EcoFlow Portable Power Stations utilize LiFePO4 battery chemistry for its rechargeability, superior safety, and versatility.
How Long Do Lithium Batteries Last?
These are our longest-lasting batteries, typically outlasting alkaline at least six times, often many more times than that. Properly stored and even with repeated use, most can last for 10 to 20 years.
Advantages
The main advantage of lithium batteries is their ability to be recharged so many times before they start losing their ability to hold a charge. They also have a high energy density, meaning they can store a lot of energy relative to their size. This makes them ideal for smartphones, watches, and other small devices.
However, they’re also useful in large devices like EcoFlow DELTA Pro power stations that start at an impressive 3.5 kWh, making them a great home backup solution. The EcoFlow DELTA models can also be expanded and upgraded up to 25 kWh with additional batteries. That’s plenty of power to run even the most power-hungry home! Combine it with an EcoFlow Power Kit for your home or RV for the ultimate in easy off-grid integration.
This type of battery also has a low self-discharge rate. It means it retains its charge for extended periods when not in use, so it’s always ready for use when needed. Another advantage is that they perform much better in cold weather than other batteries.
What Is an Alkaline Battery?
An alkaline battery is a disposable battery mostly used in low-power electronic devices. It utilizes a non-reversible chemical reaction involving zinc and manganese dioxide. That chemical reaction generates electrical energy that we can use to power devices like remote controls, toys, smoke alarms, and flashlights.
How Long Do Alkaline Batteries Last?
Alkaline models can be stored for 5-10 years and will still be usable. However, once they’ve been used and drained just once, they can no longer be used. How long they last in use depends on the power being drawn. For instance, you could drain them in a single day using them in a camera or other higher-power device.
Advantages
Even though they cannot be reused, they’re still popular because they have been utilized much longer, so they’re widely available and affordable. They are known for their relatively long shelf life and stable voltage output. Alkaline batteries are also helpful when a very low amount of power is needed, as sometimes higher power models will be too much for specific devices.
However, their inability to be reused makes disposal an issue. Also, once you factor in how many times you need to buy new ones before you have to buy just one rechargeable battery, they are no longer as affordable as they first might seem.
What’s the Difference Between Lithium Batteries and Alkaline Batteries?
Rechargability
Alkaline models use a non-reversible chemical reaction, making them disposable. Once they lose their charge, they cannot be reused. Lithium, on the other hand, uses the flow of ions from one terminal to another. When recharged, the ions flow in the reverse direction to be reused repeatedly.
Charge Density and Capacity
Lithium models have a better charge density, meaning they can pack more power in a smaller area. This makes them lighter and more compact for portable applications. But it also makes them perfect for larger energy solutions like home backup. In fact, the EcoFlow DELTA Series Portable Power Stations using LiFePO4 battery chemistry come in a wide range of capacities, including enough to power an entire off-grid home.
Price
Since alkaline models have been around for a long time and their materials are usually cheaper, they tend to be cheaper. However, the newer LiFePO4 batteries no longer use rare metals and are coming down in price significantly; one day, they may be the most common battery we use.
Voltage and Performance
An alkaline battery has a voltage of 1.5V per cell, making it useful for low-powered devices. However, it performs poorly in high-power devices.
Lithium batteries perform better in high-power devices with 3.2V to 3.6V per cell. Since you can combine multiple cells, you can get much more powerful batteries in less space.
Lifespan
Both batteries will last long in storage, though alkaline will only last for a short time. However, the most important lifespan is how many times it can be used. Since alkaline models can only be used once until their charge is drained and must be disposed of, they have a much shorter lifespan when used.
So, Which Type of Battery Is Better?
It all depends on the application. An alkaline battery can be more suitable for very low-power devices. However, lithium is generally superior for its reusability, portability, higher output, and better performance in cold weather.
What Happens if I Use Lithium Batteries Instead of Alkaline?
Since they have a higher voltage, they could damage low-power devices only meant for alkaline batteries. However, alkaline will be drained much faster than lithium in high-power devices. Otherwise, the two types can be used interchangeably.
While alkaline batteries are well-suited for low-power devices that drain energy very slowly, lithium models outperform them in reusability, energy density, and overall efficiency, making them ideal in a broader range of applications.
For instance, LiFePO4 is perfect for high-energy needs like home backup solutions, which is why they are used in EcoFlow Portable Power Stations. Since they are reusable, they also help contribute to a more sustainable future for us all.
