How to Run an RV Fridge on Propane
Propane has been a reliable power source for decades when you’re off-grid. Whether you utilize a propane generator in a pinch during a power outage or use propane to fuel your camp appliances while exploring the great unknown, propane technology allows for autonomy and peace of mind no matter where you need power.
Keeping your food cold while on the road is essential for safety and enjoyment. Here’s everything you need to know about running an RV fridge on propane.
Can You Run Your RV Fridge on Propane Only?
Online forums constantly buzz with RV owners asking one essential question: Can you run an RV fridge on propane alone? The answer is a resounding “yes,” almost unanimously from seasoned RV experts. However, there is debate about a few of the details.
For example, manufacturers advise not to run your RV fridge with propane while driving. That said, running your fridge with propane, even while driving, is a tried and true way to power your essential appliance and keep your food cold while on the road. Always turn the propane off when stopping to refuel your gas tank for safety.
Some RV fridges can even run on propane or electricity, allowing you to switch between the two sources based on the energy available during your trip. While propane is a tried-and-true method of powering RV appliances, there are many better options on the market today that are less expensive and better for the environment, including EcoFlow Portable Power Stations.
The EcoFlow GLACIER Portable Fridge is the answer to your RV fridge conundrum. Compact, easy to transport, and fully electric, this appliance has the large capacity and easy charging mechanism you need for a life on the go. For ultimate convenience, you can even charge your fridge battery with an EcoFlow DELTA Series Power Station, like the EcoFlow DELTA Pro 3
How To Run an RV Fridge on Propane in 4 Easy Steps
Running an RV fridge with propane may seem daunting for first-timers, but the process is remarkably simple. Here’s what you need to know.
Make Sure the Propane Tank is Full
Start with a full propane tank to ensure you have enough fuel to keep your fridge cold throughout your trip. If you can’t top up a partially used tank, you can repurpose it at home by connecting it to an outdoor grill or firepit. You can purchase a full tank at many gas stations, hardware stores, and even supermarkets.
Connect the Propane Tank
Connect your full propane tank to the RV. If using an external tank, ensure it is securely fastened and all connections tight. Additionally, ensure the propane regulator works correctly to ensure the tank’s pressure is primed for use.
Turn on the Propane
Once securely attached, carefully open the valve on your RV’s propane tank by rotating the knob to the left. Then, locate the on/off switch or lever for the prone use in the RV to ensure the appliance is drawing power from the correct source. This is typically located near the RV’s tank or fridge.
Also, make sure that the thermostat is set at the correct level for food safety and enjoyment. Gas-powered appliances are more susceptible to interruption by temperature and elevation, so some manufacturers advise users to switch to electric at high altitudes.
Keep an Eye on Propane Levels
No one wants to run out of propane while camping. To be safe, watch fuel levels closely during your trip. Some folks opt to turn the fridge on and off throughout the trip to preserve fuel, monitoring the thermostat to maintain a safe temperature.
How Much Propane Does an RV Fridge Use Per Day?
The amount of propane required to power an RV fridge depends on its size and capacity. However, a small fridge will use roughly .6 pounds (.27 kg) of propane per day.
Is It Cheaper To Run an RV Fridge on Propane or Electric?
While the efficiency of your portable fridge greatly influences the cost of running an RV fridge, the type of energy powering the appliance also contributes to the overall expense. And generally speaking, running your RV fridge on electricity will be cheaper.
Propane is a user-friendly, reliable source of power for RV fridges, allowing you and your family to explore untethered. For the best of both worlds, EcoFlow’s Smart Generator 4000 lets you harness the power of propane to charge your appliances while reducing emissions and cutting costs.
Check out EcoFlow’s impressive product line today, and let the adventures begin.
