Watts to Amps Conversion Calculator
Watts to Amps Calculator for DC Electricity
Watts to Amps Calculator for AC Electricity
Understanding Watts, Amps and Volts
Grasping the concepts behind watts, amps, and volts is vital to utilize electrical energy effectively. Whether you’re dealing with common household devices or advanced renewable systems, having a foundational understanding of these terms can be incredibly beneficial, if not necessary.
Watts
Watts represent the unit of power in the International System of Units (SI). Essentially, it quantifies the rate of energy transfer or conversion.
For instance, if a light bulb is rated at 60 watts, it means it uses 60 joules of energy per second when illuminated. In the context of electrical devices, watts measure how much electricity a device can deliver (output) or use (consume) per unit of time.
Amps
Amps, short for amperes, are the SI unit for electric current. They indicate the volume or flow rate of electrons passing through a circuit per second.
Think of it like water through a pipe: the larger the pipe (or higher the amp rating), the more water (or current) can flow through. In electrical systems, amps often give an idea of the capacity or limit of an electric device or circuit.
Volts
Volts measure electrical potential or voltage. In layman’s terms, you can view voltage as the “pressure” pushing the current through circuits.
A higher voltage often means more potential power, but it’s the combination of both volts and amps that determines the actual power output, quantified as watts. A common analogy is to think of volts as the water pressure in a hose, pushing water (current) through.
What Is AC/DC?
AC and DC refer to alternating current and direct current, respectively. AC is characterized by the continuous change in the direction of the current, typically in a sinusoidal manner, and is commonly used in residential power grids and most household outlets.
In contrast, DC maintains a constant direction, making it ideal for batteries and solar cells. Understanding the difference is crucial because the conversion of watts to amps may differ based on whether you’re working with AC or DC power.
How to Convert Watts to Amps for DC Power
The formula to convert watts to amps for DC electricity is straightforward.
Simply divide the power in watts by the voltage in volts, which gives you the current in amperes.
So, the formula for DC appliances can be expressed as:
Watts (W) / Volts (V) = Amps (A)
How to Convert Watts to Amps for AC Power
The vast majority of household appliances and consumer electronic devices run on AC electricity.
To convert watts to amps for AC power applications, you must consider the power factor (PF):
Watts (W) / (Power Factor (PF) x Volts (V)) = Amps (A)
What is the Power Factor in AC Electricity?
The power factor in AC electricity represents the difference between the actual power (watts) and the apparent power (volt-amperes).
When converting watts to amps with AC circuits, considering the power factor ensures a more accurate conversion.
Most consumer electrical appliances use purely inductive or capacitive circuits, which have a Power Factor of zero.
If a device’s primary function is to produce heat, it typically uses resistive circuitry.
For resistive circuits, the Power Factor is 1.
Keep in mind that heat is required for things you might not expect, like traditional lightbulbs.
Common examples of devices that typically (or always) use resistive circuitry include:
  • Incandescent lights
  • Toasters
  • Hair dryers
  • Space heater
Consult an electrician if you’re unsure whether your appliance uses inductive or resistive circuits.
Watts to Amps Table (120V)
Power (W)Voltage (V)Current (A)
10 watts120 volts0.0833 amps
20 watts120 volts0.167 amps
30 watts120 volts0.250 amps
40 watts120 volts0.333 amps
50 watts120 volts0.417 amps
60 watts120 volts0.500 amps
70 watts120 volts0.583 amps
80 watts120 volts0.667 amps
90 watts120 volts0.750 amps
100 watts120 volts0.833 amps
200 watts120 volts1.667 amps
300 watts120 volts2.500 amps
400 watts120 volts3.333 amps
500 watts120 volts4.167 amps
600 watts120 volts5.000 amps
700 watts120 volts5.833 amps
800 watts120 volts6.666 amps
900 watts120 volts7.500 amps
1000 watts120 volts8.333 amps
Disclaimer: Calculators provided for educational use only with no guarantee of completeness, accuracy, timeliness or of the results obtained from the use of this information, and without warranty of any kind, express or implied, including, but not limited to warranties of performance, merchantability and fitness for a particular purpose. EcoFlow will not be liable to you or anyone else for any decision made or action taken in reliance on the information given by the calculator or for any consequential, special or similar damages, even if advised of the possibility of such damages.
