How to Choose the Right UPS Battery Backup
Power disruptions can wreak havoc on your devices, data, and way of life. Whether you’re running a business, managing your home office, or simply trying to use your appliances for house chores, an uninterruptible power supply (UPS) is essential. It can ensure steady electricity even when common issues arise, safeguarding your equipment and essential tasks.
Learn more about the importance of a UPS, common power issues, and how to select the proper battery backup for your needs.
What is an Uninterruptible Power Supply?
An uninterruptible power supply, or UPS, provides emergency power to your electrical equipment when the primary power source fails. Think of it as a safety net for your technology, offering a short-term power supply that lets you safely shut down your devices or keep them running during minor interruptions.
UPS systems protect your hardware from power surges, outages, and other electrical anomalies. Abnormal voltages or surges in electricity levels can damage your equipment, shorten its lifespan, or reduce performance, but these systems act as surge protectors to prevent any harm from reaching your delicate devices.
Some portable power stations and solar inverter generators can be used as UPSs, such as certain models of the EcoFlow DELTA Series Portable Power Stations, including the EcoFlow DELTA 2 Max and EcoFlow DELTA Pro 3. The newly launched EcoFlow DELTA Pro 3 can transfer power in just ten milliseconds.
When paired with the EcoFlow Smart Generator 4000 (Dual Fuel), it provides the enhanced reliability of a hybrid solar system with additional options of LPG or gasoline as fuel.
Why Do You Need a UPS?
Imagine you’re working on an important work project in your home office, and suddenly, a power outage strikes. With a UPS, you can avoid losing unsaved work, damaging equipment, or even experiencing data corruption. It ensures a continuous electricity supply, allowing you time to save your work and shut down devices properly or continue working.
It eliminates any disruption and turns on immediately when a power issue occurs, so you may not even notice a change. It also stabilizes voltage, protects against surges, and filters out electrical noise, safeguarding your valuable equipment.
Common Power Problems
Power issues can arise anytime, and understanding them is the first step toward effective prevention. When you know what’s possible and what’s at risk, you’ll be more likely to protect your equipment with the right UPS system.
Here are some typical electricity problems that an instant battery backup can address:
  • Surge: A sudden and drastic increase in voltage that can damage electronic components.
  • Blackouts or Brownouts: A blackout is a complete loss of power, often caused by severe weather or grid failures, while a brownout refers to a drop in voltage levels, typically due to high demand or electrical faults.
  • Overvoltage or Voltage Sags: Sags are short-term dips in voltage that can disrupt sensitive equipment. Overvoltage is the opposite – periods of high voltage that can overheat and damage devices.
  • Frequency Noise and Variation: Electrical interference can corrupt data and cause malfunctions called frequency noise. When the frequency fluctuates, this is called frequency variation, which can harm electronics.
What Are the Different Types of UPS Topologies?
Not all UPS systems are created equal. Here’s a breakdown of the main types of UPS topologies or categories. Where each kind falls depends on the type of protection you seek.
Standby
Standby UPS or offline systems are the most basic and cost-effective option. They provide backup power during outages and switch to battery mode when a power problem is detected. The UPS inverter remains “offline” until the electricity input fails.
At this point, the UPS turns on automatically and connects the equipment load to the inverter’s output, requiring about ten milliseconds. Ideal for home offices and small businesses, standby UPS systems offer reliable protection against minor power disruptions.
They only have basic surge suppression and noise filtering capabilities, and equipment connected to this type of backup is still subjected to certain grid power disturbances.
Line-Interactive
Line-interactive UPS systems offer more advanced protection by regulating voltage fluctuations. They use a built-in automatic voltage regulator (AVR) to adjust high and low voltage levels without switching to battery power. When the input power source is no longer working, the UPS will open its transfer switch to allow the inverter to reverse so the battery becomes the power source.
The load transfer time for this type of UPS can be less than four milliseconds. This makes them suitable for environments with frequent electricity issues, such as small to medium-sized businesses.
Double-Conversion
Double-conversion UPS systems offer the most safeguarding by continuously converting the AC power coming into DC and then back to AC. The UPS inverter stays engaged, so if the main power source fails, the UPS can automatically switch to battery power, creating an instantaneous transfer and a consistent and clean electricity supply, free from voltage fluctuations and electrical noise.
Double-conversion systems are ideal for critical applications like data centers and large enterprises. These systems provide the maximum protection for equipment that is sensitive or holds vital information.
How to Calculate the Required UPS Power Output
To ensure your UPS can support your equipment, you’ll need to calculate the total load—the combined power each device uses in watts. Here’s how:
  1. Make an Equipment List: Note all the devices you must protect, including computers, monitors, servers, and networking equipment.
  2. Determine Power Requirements: Find the wattage for each device, usually listed on the device or in the user manual. If you can’t find the information listed quickly, you can research the average power requirements for that type of device online. Always estimate on the higher side to be safe.
  3. Add Up Total Watts: Add the wattage of all devices to get the total load.
Ensure the UPS battery backup can support this total load, ideally with extra capacity for future expansion.
What Size UPS Will You Need?
Choosing the right size UPS is crucial for optimal performance and protection. Wattage is the first and most important thing to consider when shopping for different sizes, but you should also consider things like surge power or peak loads, which can be 20% higher than running wattage.
Also, consider whether you plan to add future devices and upgrades to your equipment. You must ensure your UPS can support surge power and any new device additions.
Determining UPS Runtime
The runtime of a UPS refers to how long it can power your devices during an outage. To make the distinction, output refers to how much power it can provide at one time, while runtime refers to how long it can give that power. Here’s how to determine the suitable runtime for your needs:
  1. Minimum Runtime: Calculate the time needed to shut down your equipment correctly. Depending on how many devices you have and how quickly they can shut down, this may be a few minutes or longer.
  2. Assess Power Outage Duration: Consider typical outage durations in your area and choose a UPS that can cover these periods if you want to continue using your equipment and not just shut it down.
  3. Range of Runtimes: Look for UPS systems that offer a range of runtimes that match your requirements. The broader the range, the more options you’ll have. Longer runtimes allow you to either shut down for safety or continue working, while shorter runtimes will only allow you the time to shut everything down.
Remember that the wattage load affects runtime—the smaller the load, the longer the batteries will last. If your load is large, your UPS won’t be able to sustain the output required for very long. On the other hand, a smaller load may be sustained for much longer.
Choosing the correct UPS battery backup will protect your equipment and ensure uninterrupted productivity. You can choose a UPS battery backup that suits your needs by understanding the types of UPS systems, calculating your energy requirements, and determining the appropriate runtime.
Ready to safeguard your devices? Explore our EcoFlow Portable Power Stations range that can serve as UPS battery backups and find the perfect match for your setup.
