How to Choose the Best iPhone Power Bank in 2025
Charging your phone is meant to be easy. As technology advances, there are more convenient and efficient ways to keep your devices charged, even when you’re on the go. If you’re in the market for a new power bank for your iPhone, you’ve come to the right spot.
The good news is that there are some great options on the market for you to choose from. The not-so-good news is that it can be hard to sort through the noise and find something that is perfectly suited to your needs.
We’re here to help make the process easy, so we’ve created a simple guide to what you should look for when purchasing your next power bank.
Factors to Consider When Choosing a Good Quality Power Bank
Power banks are great investments. They’re designed to help you stay connected even while you’re out and about. These portable devices are great when you’re in a pinch and can supply you with a reliable power supply even in emergency situations.
Whether you’re looking for a convenient solution for your travel expeditions or something you can use every day, there are some important factors to consider to ensure you are buying the right device for your needs.
Battery Type
When purchasing a power bank, battery type is one of the more influential factors you should take into consideration before making a purchase. The battery type of your selected portable phone charger can greatly influence performance, durability, and user enjoyment, so don’t make a quick decision or brush over this important detail.
There are many types of batteries used in portable phone chargers, though we are going to focus on the two main types you will likely find in your searches: lithium-ion and lithium-polymer. While lithium-ion batteries are typically a bit more affordable, they are prone to more problems and may not be exactly what you are looking for. Lithium-polymer is a more expensive investment but typically performs better over a longer period of time.
Both battery types serve an important purpose and will work best in certain types of power banks.
Another important feature to consider is the overall capacity of your chosen power bank. Not all devices are built equal, and some may last a lot longer on a single charge than others, so take this into account when deciding what to use it for.
Charging smaller devices such as phones or small cameras will not consume much of the stored power. If you, on the other hand, are charging a laptop or supplying power to another large appliance, you may find that your power bank’s capacity dissipates much faster.
If you’re planning on taking your power bank out on a camping trip, it may be worth buying one with a higher capacity. If you don’t have a way to charge your device for a few days at a time, you’ll benefit from a device that offers a larger starting capacity.
Power banks with more capacity typically cost more than those with lower capacity, so be aware that this is an influential factor when it comes to the price.
Charging Speed
Are you planning to use your power bank in a pinch to quickly charge your device? Or, is the charging speed not really relevant to your needs? Depending on how you answer these questions will help you to better understand if charging speed is actually an important feature to you.
All power banks charge at different speeds. Some offer fast charging, which we will discuss below, though this isn’t something that everyone needs. Take the time to really think through how you plan to use your power bank and decide if a fast charging speed would benefit you.
Why You Should Avoid Cheaper Power Banks
Cheaper devices are prone to more problems and may end up costing you more in the long run. While they offer a less expensive up-front investment, these power banks are not intended for long-term use and may even damage the devices you plan to charge. If durability and longevity are important factors to you, it’s worth finding a quality power bank, even if the starting cost is a bit higher.
Options like the EcoFlow RAPID Power Bank and EcoFlow RIVER 3 Series are built to last and are worth the investment. These devices will stand the test of time and safely provide power to your devices without the worry of swelling, overheating, or retaining physical damage—all of which can frequently happen on cheaper power banks.
Make an informed purchase and find a power bank that will serve you best, but don’t be afraid to invest in quality over convenience.
What Is Fast Charging?
Fast charging is a unique feature offered by certain power banks that can quickly charge up a device even if the battery percentage is all the way at zero. Power banks with fast charging capabilities typically work with a higher output or current to charge your device much faster than with typical portable chargers.
These items are great if you are in a time-constrained situation and can also serve you well in an emergency. Not all power banks offer this specialized feature, so be sure to do your research and select a device with fast charging if it’s something you wish to have.
How Does Wireless Charging Work?
As the name suggests, wireless charging allows you to charge your devices without a cable or cord. This advanced technology, called inductive charging, has greatly advanced our ability to reduce the production of unnecessary cords and cables while keeping the act of charging on the go convenient.
Wireless power banks are typically stand-alone items that you can set your phone or device on to charge. This occurs as energy transfers from the power bank to the device you are charging through a magnetic field. Whether you’re looking to declutter your space or just want a simplified charging option, this may be a feature that you prioritize when going to purchase a portable phone charger.
If this is something you are interested in trying for yourself, the EcoFlow RIVER 2 Series Solar Generators and EcoFlow RIVER 2 + 110W Solar Panel offer great solutions to store energy that can be used to charge and power wireless power banks.
At the end of the day, your power bank should be a convenient and helpful device that can be used in a variety of ways. These technologically advanced devices have come a long way in recent years and are great investments for those who need them.
This guide is a great starting point to help you better understand your needs so that you can find the perfect power bank in 2025.
Want to learn more about how fast charging capabilities can work for you? EcoFlow’s Rapid Power Bank is a great solution for energy on the go and may be just the device you’re looking for.
