How Many Watts Does a Crockpot Use?
Nothing beats a homemade, slow-cooked meal in the crockpot. From roasts to stews and soups, these meals are hearty and simplify feeding a crowd. These nifty cooking appliances have been used for decades, but how much electricity are they responsible for using?
Crockpots come in all shapes and sizes and require different amounts of electricity to power. These units are more energy-efficient than powering up the oven and can help you save on your monthly bills if used correctly.
Read on to learn more about the energy these devices consume and how using them may be impacting your electricity bill.
What Does Wattage Mean for a Crock Pot?
Wattage is a measurement of how much electricity is used when the crockpot is turned on and cooking. The expenditure of watts depends on how long you are using the cookware, as well as its temperature and size.
Crockpots are great for taking on the go and can even be powered by EcoFlow Portable Power Stations like the EcoFlow DELTA Series. These cooking appliances require little power, though they can help prepare exceptional meals.
What Factors Influence the Energy Consumption of a Crock Pot?
Like all electronic devices, some notable factors influence their energy consumption;
Time
Are you cooking a roast for hours or just trying to keep an appetizer warm? The length of time you intend to keep the crockpot heating will influence the overall energy consumption.
Cooking Temperature
In addition to time, cooking temperature is also a huge factor. For example, when cooking a roast at a low to medium temperature for hours, the crockpot will require a constant source of electricity to remain heated. Higher temperatures require more energy consumption, though they typically won’t need to cook for quite as long.
Pot Size
Pot size will also greatly influence energy consumption in crockpots. Larger pots will expend more watts than smaller units, as it takes more electricity to heat them and keep them at the desired temperature.
The nice thing about crockpots is that, even if they’re larger, they’re easy to travel with and allow you to prep meals on the go. Using the EcoFlow DELTA 2 or EcoFlow DELTA 2 Max, you can easily supply power for your next meal while camping or in an RV.
How Many Watts Does a Crockpot Typically Use?
With typical usage, a crockpot will not use more than 200 watts when being powered on high. Again, this number depends greatly on the factors described above, so it’s best to consider your device when making these estimations.
How To Calculate the Energy Consumption of a Crock Pot
A general calculation you can use when figuring out the energy consumption of a crockpot is as follows:
Watts Per Hour x Hours Used = Energy Consumption
This calculation will help you to get in the general ballpark of how much energy your crockpot is using in Wh.
What Is Standard Crockpot Wattage?
A typical 6-quart crockpot will use an average of 300 watts while in use. The wattage will depend on the size of the pot, the temperature it is set to, and the length of time it is turned on.
Do Crockpots Require Less Wattage Than Ovens?
If you want to save on energy bills, using your crockpot instead of your oven is a great option. Crockpots require a fraction of the wattage that ovens do and can help you cook and prepare the same meals.
Crockpots are excellent kitchen aids, helping you make amazing meals and, as a bonus, save a little extra on your monthly bills. While small and mighty, they thankfully don’t use too much energy and cost much less than conventional ovens.
If you’re planning a road trip soon and want to bring the comfort of a home-cooked meal along, try the EcoFlow Portable Power Station, a portable and easy-to-use supply of electricity. That way, you can power appliances like crockpots and keep your devices charged no matter where you are.
