How Many Solar Batteries Do I Need to Power My Home?
Determining how many solar batteries for home you need depends on multiple factors, such as its size, energy usage, and the type of system you want.
Whether you’re planning for backup power during outages or aiming for the energy independence that complete off-grid systems provide, finding the right balance of storage capacity is essential.
We will explore your specific power needs and available options to help you build a system that provides reliable, sustainable energy for years to come.
How Many Solar Batteries for Home Do I Actually Need?
How many batteries you actually need depends entirely on the size of your home, how many and what types of appliances you run, how many people live in your home, and whether you are looking for a home backup system or want an off-grid solution for complete energy independence.
The larger the home, the more people and appliances, the greater your power needs, and the more batteries you need. It also depends on the type of battery and its capacity.
While there is no simple answer to that question, here are some general numbers based on average homes and average battery capacities.
  • For those looking to supplement their grid power to save money, 2-3 batteries are usually enough to provide enough power to produce significant savings.
  • One decent-sized battery should be enough for those looking for a simple home backup solution to run a few essential appliances during an outage.
  • Finally, depending on the size of the home and the battery, those looking for complete energy independence through an off-grid system may need 3 to 12 batteries.
Reasons To Install a Solar Battery
Save Money
Solar battery, also called photovoltaic batteries like those in EcoFlow Solar Generators, can save you tons of money by going off-grid.
Since they use photovoltaic panels like the EcoFlow 400W Rigid Solar Panel to generate electricity using nothing but sunshine, after the solar payback period, your energy will be free for at least 20 years! With savings like that, how can anyone not afford to get them?
Even if you just want to avoid paying for power during peak electricity pricing hours, you can save a lot of money with just one or a few batteries. You might still need to rely on grid power during cloudy days, but most of the time, depending on your climate, you can avoid those peak electricity hours.
Whole-home Backup
You can use them to provide whole-home backup power during electricity outages from storms or other events. They protect your family by keeping the lights on and helping you stay warm or cool regardless of the season or weather. They also protect your home, sensitive electronics, and food in your refrigerator, keeping everything safe and functional.
The EcoFlow DELTA 3 Series Solar Generator (PV220W) comes with 1kWh of capacity, is expandable to 5kWh, and is rechargeable with your super-efficient photovoltaic panels so you can keep your lights on even during extended outages.
Clean Energy Solution
Photovoltaic batteries offer a renewable energy solution that can significantly reduce your environmental impact, whether you use them to supplement your current system or want to go completely off-grid.
Solar generators work using energy from the sun, which is converted into electrical energy on photovoltaic panels like the super efficient and durable EcoFlow Rigid Solar Panels. Solar generators like EcoFlow DELTA Pro 3 Solar Generator (PV400W) come with a photovoltaic battery that stores that energy to be used anytime, whether or not the sun is shining.
Factors That Affect Solar Battery System Size
Size of Your Home
Bigger homes require more power. Households with more people also require more power because more lights are on and more appliances are running more often.
Energy Needs
This is the most critical factor, as how large a system you need depends entirely on your energy needs. The size of your house and the number of people in your household are significant factors. However, it also depends on what types of appliances you run and how often they run. If you use air conditioners in summer and electric heat in winter, your power needs will be much larger than those of those who don’t need air conditioning and use alternative heat sources.
How You Use Your System
The capacity you need also depends on how you use your system. If you supplement your grid power to reduce your costs or avoid peak electrical usage fees, you won’t need as much storage as a completely off-grid home.
Size of Solar Arrays
The size of your photovoltaic array will determine how much it can charge your battery system during the day. In other words, there is no point in installing lots of batteries if you don’t have enough photovoltaic panels to charge them to full capacity.
If you’re unsure how much your panels produce, most reputable brands offer smartphone apps that you can use to monitor your solar output. Buy enough batteries to match your array, or install more panels to meet your energy needs.
Battery Type
Different battery chemistries have different charge densities and depths of discharge, and therefore, they come in various capacities to suit different needs. LiFePO4 can be discharged to nearly 100%, but it is best to recharge them around 80%, which still gives you a lot of usable capacity.
Traditional deep-cycle lead-acid models can only be discharged to 50%, so half their capacity is unusable, requiring more batteries to meet your needs.
How To Calculate the Number of Solar Batteries You Need
Step 1: Decide What Kind of System You Want
Whole-home off-grid energy solutions will be larger than simpler home backup solutions. Whole home generators will need to power everything you might want to run, while emergency backup will only need to run essential appliances like your refrigerator, medical equipment, alarms, and other items. Decide what you want to run with it.
Step 2: Determine Your Energy Needs
Next, make a list of all the appliances that you need to run. Find their energy usage in watts. If they’re not given in watts, you can convert them using the following equation:
Watts(W) = Volts(V) x Amps(A).
Be sure to factor in starting watts for appliances like refrigerators, which have electric motors that require an extra surge to get started above their normal running watts.
Step 3: Determine How Long
Next, you need to multiply your watts by how many hours. For an off-grid solution for a freezer, this means it will run 24 hours a day. However, your washing machine will probably only run for an hour daily.
Multiply those watts from the previous step by the hours to get your usage in watt-hours (Wh). You can also divide that number by 1000 to get the value in kilowatt-hours (kWh)
Step 4: Determine How Many Batteries You Need
Next, add up all those watts-hours to determine your power needs. Then, look at the capacity of your batteries and their depth of discharge. For instance, if you need 13kWh and the LiFePO4 battery you are considering has a 4kWh capacity, you should get four batteries since that will give you plenty of power without draining them to 100%.
Can One Solar Battery Power a House?
The short answer is yes, sometimes. However, it depends on your home, power needs, battery capacity, and whether you want to use the system for essential appliances during a blackout or a complete off-grid solution. Decide how you want to use it, add up your devices, and consider the battery’s capacity.
How Many Batteries Do You Need To Run a House on Solar?
It depends on the size of your home, how many appliances you need to run, and the battery’s capacity. Generally speaking, 2-3 quality batteries may run a smaller home, while a larger home often needs twice that many or more.
Determining how many solar batteries you need involves understanding your energy needs, the type of battery, and its capacity. From simple backup solutions to complete off-grid independence, the right system offers long-term savings, reliability, and sustainability.
EcoFlow DELTA Solar Generators provide cutting-edge, customizable, and expandable options to meet those needs, no matter how great or small. Prepare to power your home with clean, renewable energy and take the first step toward energy independence today.
