How Does Wireless Charging Work?
Gone are the days of tripping over cords and trying to untangle chargers for all your devices—wireless charging has redefined how we keep our devices powered up. Its innovative technology offers a convenient way to charge smartphones, smartwatches, earbuds, and other gadgets without a traditional plug.
This article will explain how the technology works, explore the different types of wireless chargers, and examine the benefits of cutting the cord. Whether you’re new to wireless charge methods or considering an upgrade, read on to learn everything you need to know!
So, How Does Wireless Charging Work?
Old wired chargers rely on conductive charging to move electricity from the power source into your device. On the other hand, wireless methods use electromagnetic induction to transfer electricity into your device without needing a physical connection.
It uses a tightly coiled copper wire in the charger’s pad, called the transmitter coil or magnetic loop antenna. When the pad has a battery bank or is plugged into a wall outlet or portable power station, its coil generates an oscillating electromagnetic field.
When a compatible device with its own receiving copper coil with loops that resonate at the same frequency sits on the pad, that electromagnetic field induces the electrons in the receiver coil to flow around it, creating an electrical current. It’s called magnetic resonance. Those electrons, the electricity, then flow into the battery and charge it.
To work, the charger pad and the device must be in close proximity since the strength of that electromagnetic field depends on the distance between the coils in each device; the closer the coils, the faster the charge. Coil size also affects the distance that power can be transferred; larger coils mean the charge can travel a greater distance.
Since smartphones are small and we don’t want to make them bigger, the charger and the device must be close together to work.
Wireless chargers like the EcoFlow RAPID Magnetic Power Bank are unique in that they have a built-in power bank, so you can charge wirelessly from anywhere. Its patented X-Stream technology allows you to charge wirelessly faster than ever before. It’s Qi2-certified, which is twice as fast as the Qi technology, and its built-in power bank has superfast recharging abilities.
Still, most models do not have that option, so if you want to use them as portable chargers, that’s super easy to do with a compact, lightweight, portable power station like the EcoFlow RIVER 2
It’s rugged enough for outdoor use and light enough to carry anywhere; it will even fit in your backpack for hiking, so you can keep all your essential devices running. You might be surprised at just what the EcoFlow RIVER 2 can do.
What Are the Different Types of Wireless Charging?
Qi Wireless Charging
The Qi, pronounced “Chee,” is the most common type used. It supports most modern smartphones, earbuds, smartwatches, and other accessories, with the exception of the Apple Watch.
It uses a charge pad or mat that generates an electromagnetic field to induce a current in the matching coil inside the compatible device. The Qi standard uses a 110 to 205kHz frequency range and requires a maximum distance of 1.57 inches (4cm).
One of the benefits of Qi is that it works with wired and wireless methods and comes in a range of wattages to get even faster charging if needed. Some devices, like the EcoFlow RAPID Magnetic Power Bank, offer a built-in fast-charging USB-C cable offering up to 65W of super-fast charging, so you can choose to use it wirelessly or opt for super-fast charge speeds utilizing both methods simultaneously.
PMA (Powermat) Wireless Charging
Powermat has been widely adopted at public charge stations, Starbucks, and McDonalds. It also uses inductive charging and works similarly to the Qi method but uses a higher frequency range of 277 to 357kHz with a maximum distance of 5cm. One major issue with it is that since it uses a different frequency than Qi, the two were incompatible, so devices that used PMA could not be charged on a Qi pad or vice versa. Since Qi quickly became more popular, the AirFuel alliance merged both methods for the ultimate consumer convenience.
AirFuel Alliance
In 2015, Qi and PMA technology were merged into a single standard called the AirFuel Alliance. With all the major smartphone manufacturers using Qi, the merging of the two made it so that many new charge pads support both Qi and PMA for backward compatibility, making it easier for consumers to charge their devices without having to go back to the days of having a different charger for every device.
Magnetic Fast Charging
Magnetic fast charging also uses electromagnetic fields to send power between the coils. However, it uses a higher charging voltage and/or amperage to increase the charge speed since electromagnetic induction, even when fast, is still a little slower than corded methods.
The one drawback is that only newer devices support fast charging, and not all do. Your charge pad may or may not support it, and they may use different standards that may or may not be compatible with your device.
What Are the Benefits of Wireless Charging?
Convenience
Cords can be messy and dangerous when you have too many of them lying around and end up tripping on them. These do away with at least one cord, making them convenient since you can set your device on your charger without the messy cords and without fumbling around trying to connect it to your device.
Still, most models don’t have a built-in power bank, so the charger still has a wire. Therefore, if you want to charge without electricity, you will need a portable power station to plug it into. The EcoFlow RIVER 3 Series Portable Power Stations are the perfect solution to charge while camping or doing other outdoor or off-grid activities.
What about going off-grid for longer periods? You can use your EcoFlow RIVER 2 + 110W Solar Panel. With your convenient portable solar panel, you can easily recharge your portable power station anytime the sun is shining, so you will never run out of power.
Portability
When you use a model like the truly wireless EcoFlow RAPID Magnetic Power Bank, you have the ultimate portable wireless charger you can bring anywhere. It’s compact and lightweight, about the size of your phone, so you can pack it and power up your devices while camping in the woods, sitting on a bus, or waiting in a lineup. You literally can use it anywhere.
Versatility
Wired methods mean constantly having to pack around multiple cords to ensure you can recharge all your devices. Wireless models, on the other hand, are often one-size-fits-all, so there’s no need to have multiple cords lying around.
However, some popular devices, like the Apple Watch, don’t support the Qi standard, so be sure you understand your device and its compatibility with your wireless charger.
Safer Connections
Since you no longer have to plug a USB-C cord into your device, this means no more electrical mishaps, no more worrying about dirt, debris, or moisture getting in the charge port while outdoors, no more cords getting tangled and creating tripping hazards, and no more cords getting bent or broken in use and needing to be replaced.
All in all, it makes for a much safer user experience.
Is Wireless Charging Better for My Battery?
It can be better for your battery since it prevents overcharging and reduces wear and tear on your device, especially your charge port. However, sometimes magnetic induction can create more heat, and if your phone is already prone to overheating, this could be problematic. To avoid heat issues, simply remove your device as soon as it is charged.
Can All Phones Be Charged Wirelessly?
No, only newer phones with a copper coil built inside to accommodate the new technology can be charged wirelessly. However, some older phones can be made compatible by using a special case with a coil built into it that plugs into your phone’s charger port.
Is There a Downside to Wireless Charging?
One downside is that it is still slightly slower than wired methods since it uses induction rather than conduction. Another downside is that, in some cases, phones may overheat from the magnetic induction. If your phone is prone to overheating, remove it from the pad as soon as it is charged.
Wireless charging offers a modern, convenient alternative to traditional wired methods, allowing us to keep our devices charged without tripping over cords. The popular Qi standard has been widely adopted by most major manufacturers, offering compatibility and versatility for consumers.
With evolving technology and innovative solutions like the EcoFlow RAPID Magnetic Power Bank, these methods continue to improve, providing faster charge speeds, greater portability, and increased versatility. So, whether you’re looking for a more streamlined way to charge or need a reliable power solution on the go, wireless charge technology has you covered.
