Best USB-C Cables for Speed and Durability
In a society where we do our best to stay connected, the need for fast charging and quality USB-C cables has become increasingly clear. Over the past few years, these charging cables have continued to transform into a more efficient and practical version of what we all once knew.
With so many different styles and classifications of charging cables, it can be hard to sort through the noise to find exactly what you are looking for. If charging speed and durability are your primary features, you have come to the right place.
Below, we will discuss the key factors to consider when buying your next USB-C cable.
Understanding USB-C Technology
Let’s dive into the basics of how USB-C technology works for your everyday needs. USB-C, or Universal Serial Bus Type-C, connects to portable and mobile devices to charge or facilitate data transfer.
The cable is dual-sided and plugs into either two portable or mobile devices or one device and a power source. This universal technology is paving the way for the future as it allows one single cord to serve multiple purposes at once, making it more efficient and cost-effective than other, more outdated technologies.
The Benefits of USB Type C Cables
There are many benefits to using a universal cable within the USB type C classification. These cords typically work much faster than their older counterparts and take up much less space to store, as they serve numerous purposes.
Here are some of the primary benefits you will notice from making the switch to the style of cable:
  • Universal Compatibility—This is one of the most celebrated benefits of these fascinating chargers. By purchasing one simple charger, you can supply power to multiple devices.
  • One Cable for Everything—Universal compatibility has its benefits. You can reduce clutter and enjoy the benefits of using this one cable.
  • Faster Charging & Higher Power Delivery—USB-C chargers are powerful and can help fully charge your battery at a faster rate. They can also help ensure your battery lasts longer than it would have if it had been charged with other, lesser cables.
Factors to Consider When Selecting the Best USB-C Cables
Cable speed
Charging speed is an essential factor to consider, though it may not be a deciding factor for everyone. Take the time to think about what you will be using this cable for. Do you need your devices to charge at record time? Or do you just need a reliable connector for data transfer? How you answer these questions should help to guide your purchasing decision.
Durability
Many cords and cables can fall apart if they are not made from quality materials. When doing your research, be sure to find cables with a protective shell that guards the wire against any exterior damage.
Focus your search on cables with a braided exterior, or opt for something with a thick rubber coating. Both of these designs are durable and should last you for years to come, even if you plan to take them with you on your travels.
Compatibility
An important feature to consider with your USB-C cable is whether it is compatible with what you plan to use it with. As long as your device has a USB port, you should be good to go. That being said, pay attention to the description and specifications of the product you choose to purchase so there are no unnecessary surprises when it comes time to use it.
USB-C cables are compatible with many portable power devices, such as the EcoFlow RAPID Power Bank and other EcoFlow RIVER 3 Series models, making them a great charging option for people who are regularly on the go.
How Durable Are USB-C Cables?
A quality USB-C cable will be durable and will stand the test of time. To be considered durable, the product needs to have a thick, braided exterior as well as reinforced charging outputs and connectors. Cheap products that are not compatible with your device will likely break or lose charging capabilities in no time, so it is worth buying a quality piece.
Buying a high-quality USB-C cable is sure to improve your life. This technological advancement can help you quickly charge your devices or even serve as a data transfer tool.
Make sure to do your research and find what type of USB-C is best for you! Planning to take your USB-C on your next adventure? The EcoFlow RIVER 3 Series is the best way to provide power to your charging cables for off-the-grid explorations.
