4 Best Tailgating Generators
Tailgating isn’t just about the food and drinks; it’s about creating an unforgettable experience for you and your friends. And what better way to keep the party going than with a reliable tailgating generator? Whether at a sports event, a music festival, or a camping trip, having a dependable power source lets you enjoy all the comforts of home on the go.
Below, explore four of the best tailgating generators from EcoFlow.
EcoFlow’s Top Generators for Tailgating
  1. Best for Travel-Friendly Tailgating: EcoFlow RIVER 2
  2. Best for Extended Tailgating: EcoFlow RIVER 2 Max
  3. Best for Tailgating Camping: EcoFlow RIVER 2 Pro
  4. Best for RV Tailgating: EcoFlow DELTA 2
The EcoFlow RIVER 2 is a compact, lightweight generator for travel-friendly tailgating. Weighing just a few pounds, it’s easy to carry with one hand and perfect for those short tailgating sessions when you need a simple and efficient power source. Imagine lighting up your spot, charging your phone, and even powering a small fan from the comfort of your truck bed or parking spot.
Its compatibility with 110W solar panels means you can recharge it using renewable energy, making it an eco-friendly choice that doesn’t require refueling. The plug-and-play design ensures you can set up your power station in seconds, giving you more time to enjoy the event. Plus, with multiple power outlets and the ability to power 99% of consumer electronics, it’s incredibly versatile even when hosting a group.
Need more power while tailgating? Use it and charge it simultaneously for no time lost. Simply plug it into an AC outlet for a full recharge in just 60 minutes, or take your time with a three-hour solar recharge.
This generator is a safe bet, no matter the heat index or weather. Its built-in battery management system (BMS) monitors current, voltage, and temperature to prevent overloading, so nothing gets in the way of having a good time.
EcoFlow RIVER 2 Specifications
  • Storage Capacity: 256Wh
  • AC Output: 300W total (surge 600W)
  • Solar Charge Capacity (Maximum): 11-30V, 8A, 110W Max
  • Weight: 7.7 lbs (3.5 kg)
  • Dimensions: 9.6 x 8.5 x 5.7 in (245 x 214 x 142 mm)
  • Operating Noise Level: ~60 decibels
  • Charging Options: Solar/AC/Car/USB-C Charging
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Depth of Discharge: 100%
  • Warranty: 5 years
  • App Monitoring and Control?: Yes
Pros
  • Lightweight and compact
  • Fast charging in just 60 minutes with X-Boost or 3 hours with solar
  • Easy to carry and set up
  • Affordable power source for a lasting charge
Cons
  • Not suitable for all-day tailgating events
  • Smaller capacity and output that may not support certain appliances
For those who love tailgating through the whole weekend, the EcoFlow RIVER 2 Max is an ideal choice. This generator offers enhanced power while remaining compact, making it perfect for powering personal devices and 80% of essential small appliances like camping stoves and portable refrigerators to ensure safe tailgating food handling
With its multiple power outlets, ways to get power, including AC and USB ports, and quick recharging capabilities (one hour with AC, three hours with solar), you’ll never be left in the dark. The impressive power supply can charge a smartphone 50 times; you’re in good hands with the EcoFlow RIVER 2 Max.
Its long-lasting LFP battery will go the distance with you, providing power for long weekends tailgating at festivals and lasting up to a decade or more. The added convenience of a smartphone app allows you to monitor and control the generator from anywhere, making it a user-friendly option.
The EcoFlow RIVER 2 Max is ideal for groups and allows you to power multiple devices and recharge simultaneously. If your tailgate spot is the place to be, this addition will make it even more popular.
EcoFlow RIVER 2 Max Specifications
  • Storage Capacity: 512Wh
  • AC Output: 500W (Surge 1000W)
  • Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
  • Weight: 13.4 lbs (6.1 kg)
  • Dimensions: 10.6 x 10.2 x 7.7 in (270 x 260 x 196mm)
  • Warranty: 5 years
Pros
  • Enhances extended tailgating comfort
  • Smartphone app enables remote monitoring and control
  • Robust power at an affordable cost
  • Fast charging, up to 5x faster than competitors
Cons
  • Some appliances require an output beyond its capabilities
If you’re planning an extended trip or doing more than partying out of the back of your car, the EcoFlow RIVER 2 Pro is your best bet. This generator can easily handle up to 80% of high-wattage appliances and backup essential devices if you’re camping at your tailgating spot.
Its reliable charge can last for days, but if you need to top up the battery while camping, it’s compatible with 220W solar panels and below, so there’s no need for electricity hookups. The rapid recharging feature ensures you’re never out of power for long, whether using AC (70 minutes), solar (3 hours), or car adapters.
It’s the perfect addition to a weekend tailgating setup if you like cooking, watching movies on projectors, powering up string lights, or enjoying a cup of hot tea from your electric kettle. Don’t give up these little comforts of home just because you’re tailgating.
Its uses don’t stop there. While extremely helpful for tailgating camping, it can also be used at home as a backup option for things like outages. Despite its powerful capabilities, the RIVER 2 Pro remains highly portable, weighing just 17.2 lbs (7.8 kg). Its lightweight nature means you’ll never get tired of carrying it, which is good since the durable LFP battery retains 80% capacity even after 3000 cycles and years of use, making it a reliable long-term investment.
 EcoFlow RIVER 2 Pro Specifications
  • Storage Capacity: 768Wh
  • AC Output: 800W total (surge 1600W)
  • Weight: 17.2 lbs (7.8 kg )
  • Dimensions: 10.6 x 10.2 x 8.9 in (270 x 260 x 226 mm)
  • Warranty: 5 years
Pros
  • Four charging options with industry-best recharge times
  • Convenient off-grid power solution for tailgating or at home
  • Monitor and manage performance through the app
  • Large capacity for extended use and large groups
Cons
  • Bulkier than other options
  • Longer charge time compared to other RIVER models
The EcoFlow DELTA 2 is perfect for extended RV tailgating trips with a group or family, providing reliable backup power for home use as well. Its expandable capacity allows you to double the storage by pairing it with EcoFlow DELTA 2 Extra Battery, Ecoflow DELTA Max Extra Battery, or EcoFlow Smart Extra Battery. It’s a versatile choice for those who need flexible off-grid power that can grow with their needs.
With six AC outlets and high appliance compatibility, the EcoFlow DELTA 2 can power 90% of appliances, making it suitable for use as a home backup power source. With this in your RV, you can easily power things like refrigerators, toasters, AC units, food processors, microwaves, and more. Feed a whole group with the power of the EcoFlow DELTA 2.
Its fast charging capabilities ensure you can get up to 80% power in 50 minutes with AC power (or 100% in 80 minutes) or let the sun take the reins with just 3-6 hours of solar recharging. One of the best parts? You don’t have to choose between charging the generator or your devices. Do both with up to 13 devices simultaneously.
The battery is built to last – up to six times longer than competitors, to be exact. This is partly due to the built-in battery management system, which ensures safety and optimal performance, making it a reliable choice for any tailgating event.
EcoFlow DELTA 2 Specifications
  • Storage Capacity (Minimum): 1024Wh
  • Storage Capacity (Maximum): 3kWh
  • AC Output (Maximum): 1.8kW continuous output (2.7kW Surge)
  • Solar Charge Capacity (Maximum): 500W max (11-60V, 15A)
  • Weight: 27 lbs (12 kg)
  • Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options: Solar/AC/Car Charger
  • Multicharge Options?: Yes
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Warranty: Five years (no cycle life restrictions)
Pros
  • Expandable capacity can grow with your needs
  • Quick recharge times and multiple recharge options
  • Turn your RV into a functioning kitchen for tailgating food
Cons
  • Limited run time for extended RV tailgating trips
What Makes the Best Tailgate Generator?
Not every portable generator is built to serve you best when tailgating. You may not be near an outlet for hours or days, and you’re likely hosting a group of people with several devices and appliances that need power simultaneously. Here’s what to look for in a generator that will be a great addition to your tailgate party.
Generator Fuel Type
The type of fuel a tailgating generator uses is crucial. Battery or solar-powered generators, like those from EcoFlow, are ideal for tailgating because they’re quiet, eco-friendly, and can be recharged using various methods.
Portability/Size and Weight
Another critical factor is your generator’s portability. Compact and lightweight generators are more accessible to transport and set up, making them perfect for tailgating events. Look for generators with convenient carry handles, wheels, and compact designs.
Quiet Performance
No one wants a loud generator disrupting their tailgating experience. EcoFlow generators are known for their quiet performance since they don’t require any noisy fuel to run, making them ideal for social gatherings where noise levels need to be kept to a minimum so you can enjoy the fun.
Fuel Efficiency and Run Time
Fuel efficiency and a long run time are essential for long-lasting power during tailgating events. Battery-powered generators offer excellent fuel efficiency and hours of use before needing a recharge, ensuring that your devices stay powered throughout the event.
Safety
Safety features like built-in battery management systems and remote app monitoring ensure that your generator operates safely, preventing issues like overloading and overheating. EcoFlow generators have advanced safety features to give you peace of mind.
What Is the Best Power Source for Tailgating?
Battery or solar-powered generators are the best choice for tailgating due to their quiet operation, eco-friendliness, and versatility. They can be recharged using AC power, solar panels, or car adapters, making them a flexible and reliable power source that won’t get in the way of the good times.
What Size Generator Is Best for Tailgating?
The best generator size for tailgating depends on your power needs. Compact models like the EcoFlow RIVER 2 are perfect for short events and essential devices, while larger models like the EcoFlow DELTA 2 are ideal for long tailgating trips with a group. Consider the number of devices you need to power and the duration of your event.
Tailgating is about creating memorable experiences with friends and family; having a reliable generator can make all the difference. You can enjoy the comforts of home like portable AC, cooking appliances, music, and lights. Whether you need a compact and portable generator for short trips or a powerful and versatile option for extended tailgating adventures, EcoFlow has a generator that fits your needs. They’re quiet, have a long run time, do not require refueling, have multiple charging options, and can power up multiple devices simultaneously.
Ready to power up your next tailgating event? Check out EcoFlow’s Portable Power Stations today!
