3 Best Portable Generators for Homes in 2025
No one likes to go through a power outage in the dark. Thanks to portable generators, it’s possible to have a reliable supply of electricity to keep your home powered even when the unexpected strikes.
Whether you’re just looking for a source of backup power for small devices or a robust whole-home backup solution, we have something for you.
Check out our guide below to help you find the perfect portable generator for your needs!
EcoFlow’s Top Portable Generators for Homes
  1. Best for Entry-Level Users: EcoFlow DELTA 2 + 220W Solar Panel
  2. Best for Backup Power for Appliances: EcoFlow DELTA 2 Max + 400W Solar Panel
  3. Best for Whole Home Backup: DELTA Pro + 400W Solar Panel
The EcoFlow DELTA 2 + 220W Solar Panel is often a perfect fit for those who want an entry-level backup power solution. Users who are new to the solar world but want a portable solar-powered generator will benefit from having something more robust and versatile.
Generating up to 3kWh of electricity daily, this excellent EcoFlow solar generator is ideal for those prioritizing power security and comfort. It’s a green way to power 90% of home appliances during an outage, keeping everything from your laptop to your television and even your refrigerator powered.
The unique bifacial design of the EcoFlow 220W Portable Solar Panel allows you to capture even more solar energy and provides faster charging times to your EcoFlow portable power station.
Specifications of EcoFlow DELTA 2
  • Storage Capacity (Minimum): 1024Wh
  • Storage Capacity (Maximum): 3kWh
  • AC Output (Minimum): 1.8kW continuous output (2.7kW Surge)
  • Solar Charge Capacity (Maximum): 11-60V, 15A, 500W max
  • Weight: 27 lbs (12 kg)
  • Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options: Solar/AC/Car Charger
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Depth of Discharge: 100%
  • Warranty: Five years (no cycle life restrictions)
  • App Monitoring and Control?: Yes
  • Federal Solar Tax Credit Eligibility?: No
Specifications of EcoFlow 220W Portable Solar Panel
  • Rated Power: 220W Front Side/155W Rear Side
  • Efficiency: 22 % – 23 %
  • Solar Cell Type: Monocrystalline
  • Weight: 20.9 lbs (9.5 KG)
  • Folded Dimensions: 32.3×19.7×1.3 in (82.0×50.0×3.2 cm)
  • Unfolded Dimensions: 32.3×72.2×1.0 in (82.0×183.5×2.5 cm)
  • Waterproof/Dustproof Rating: IP68
  • Open Circuit Voltage: 21.8 V (Vmp 18.4 V)
  • Short Circuit Current: 13 A (lmp 12.0 A) Front Side / 8.8 A (lmp 8.4 A) Rear Side
  • Recommended Portable Power Station: EcoFlow RIVER 2 Pro/EcoFlow DELTA 2
Pros
  • Generates up to 3kWh of electricity daily
  • High conversion rate and unique bifacial design for fast solar charging
  • Smart remote control via the EcoFlow app
Cons
  • Limited battery capacity
Best for Home Backup Power for Appliances: EcoFlow DELTA 2 Max + 400W Solar Panel
If you’re looking for more oomph to back up your home appliances, the EcoFlow DELTA 2 Max + 400W Solar Panel is a great option.
The expandable capacity of this solar generator means it offers 2-6kWh of battery storage, so you can tailor this option to suit your home’s power needs. It’s also an excellent choice for outdoors or RVing, meaning you can really make your investment work for your use case.
It boasts a significant AC output to power 99% of home appliances, and it can power an impressive 15 devices at once, featuring 6 AC outlets.
With the ability to power pretty much anything, you can weather blackouts in comfort, running your essentials for hours, including your refrigerator, microwave, and washing machine.
Specifications of EcoFlow DELTA 2 Max
  • Storage Capacity (Minimum): 2048 Wh
  • Storage Capacity (Maximum): 6kWh
  • AC Output (Minimum): 2.4kW continuous output (4.8kW Surge)
  • Solar Charge Capacity (Maximum): 11-60V 15A, single port 500W; dual port 1kW
  • Weight: 50.7 lbs  (23 kg)
  • Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
  • Federal Solar Tax Credit Eligibility?: Yes w/Solar Panels & Smart Extra Batteries*
Specifications of EcoFlow 400W Solar Panel
  • Rated Power: 400W
  • Efficiency: 22.6 %
  • Weight: 35.3 lbs (16.0 KG)
  • Folded Dimensions: 41.7×24.4×1.0 in (105.8×62.0×2.5 cm)
  • Unfolded Dimensions: 41.7×93,1×1.0 in (105.8×236.5×2.5 cm)
  • Open Circuit Voltage: 48 V (Vmp 41 V)
  • Short Circuit Current: 11 A (lmp 9.8 A)
  • Recommended Portable Power Station: EcoFlow DELTA Series
Pros
  • Ideal for entry-level home backup
  • Fast recharging
  • Customize energy management with EcoFlow App
  • Expandable up to 6kWh
Cons
  • Requires additional batteries to expand power capacity
  • Not suitable for more robust power needs
Best for Whole Home Backup: EcoFlow DELTA Pro + 400W Solar Panel
If you want to power your entire home, the EcoFlow DELTA Pro + 400W Solar Panel is an excellent choice. It’s an incredible home backup solution that can protect your home from power outages around the clock but also has the potential to provide you with power independence.
With three of EcoFlow’s 400W Portable Solar Panels, this solar generator produces as much as an astounding 9.3kWh of electricity daily. Featuring a fast charging speed and a large AC output, you and your household can get through blackouts comfortably.
The battery storage capacity of the EcoFlow DELTA Pro varies widely, with an impressive expandable capacity of 3.6-25kWh. It can grow with you as your household’s power needs grow and help you keep your entire home powered even when the unexpected strikes.
Powering 99.99% of heavy-duty appliances, you can trust the EcoFlow DELTA Pro + 400W Solar Panel to help you weather the storm.
Specifications of EcoFlow DELTA Pro
  • Storage Capacity (Minimum): 3.6kWh
  • Storage Capacity (Maximum): 25kWh
  • AC Output (Minimum): 3.6kW continuous output (7.2kW Surge) –
  • AC Output (Maximum): Expandable to 7.2kW continuous output (14.4 kW surge) with 2 x EcoFlow DELTA Pro + Double Voltage Hub
  • Solar Charge Capacity (Maximum): 1600W (11-150V⎓15A Max) per unit or 3600W with Double Voltage Hub + 2 × DELTA Pro (Max)
  • Weight: 99 lbs (45kg)
  • Dimensions: 25 x 11.2” x 16.4” inches (63.5 x 28.4x 42cm)
  • Charging Options: Solar/AC/Car Charger/Smart Home Panel/EV Charge Station
  • Federal Solar Tax Credit Eligibility?: Yes, with Solar Panels*
Specifications of EcoFlow 400W Portable Solar Panel
  • Rated Power: 400W
Pros
  • Incredible expandable capacity up to 25kWh
  • Fast solar charging
  • Smart remote control via EcoFlow App
  • Powers 99.99% of heavy-duty appliances
Cons
  • More expensive option
What To Consider When Shopping for a Home Portable Generator
Trying to choose the ideal portable generator to meet your needs? Below, we cover some things to remember to help guide your decision.
Power Output
The power output your generator is capable of accommodating is an essential consideration. Make sure your generator is capable of providing the power output required for the devices you intend to run.
Remember, if you’re going to be powering multiple things at once, you need to make sure the generator can accommodate their combined output. And don’t forget to factor in starting watts – some devices require more power to start up than they do while running.
Storage Capacity
Your storage capacity refers to the amount of energy your generator can store. Make sure the generator you opt for has the storage capabilities necessary to keep your home comfortable when you need it.
Fuel Type
Different generators use different fuel types, and it’s essential to make sure you have access to the fuel type used by your generator. For example, some generators use gasoline or propane, so it’s critical to ensure you have access to the fuel you need to keep your generator running.
In the case of solar generators, you’ll have the ability to generate electricity anywhere there’s sunlight. It’s also a more eco-friendly way to generate electricity than many alternatives.
Noise Level
Some generators can be extremely noisy and disruptive, so it’s a good idea to consider the noise level of your generator when it’s running. The good news about solar generators is that they’re often significantly quieter than traditional fossil fuel generators..
Budget
Your budget will also play a role in the right generator for you, as the cost of a generator can vary widely. Find an option that can provide what you want while staying within your budget.
What Is the Best Portable Generator for Home Use?
The right portable generator depends on many factors, including your power consumption, required output, and more. Solar generators are an excellent option that are quieter and more eco-friendly in operation than many other generators. But it’s important to consider the specs of your generator to make sure it has the output, storage capacity, and more that you require.
Solar generators come in a wide range of specs for various uses, from short on-the-go trips to more robust units that can power your entire home and provide you with energy independence.
Regardless of what you’re looking for, it’s important to consider factors like power output, storage capacity, fuel type, and more when choosing your ideal generator.
Looking for the ideal generator for you? Browse EcoFlow’s excellent selection of solar generators today!
