3 Best Home Generators for Power Outages in 2025
In 2024, power outages don’t have to leave you in the dark. Discover three of our best home solar generators, each designed to meet various power needs during blackouts.
Whether you’re looking for a whole home backup or want to power essential appliances, we’ve got you covered. Explore the unique benefits of these generators and find the perfect fit for your home’s emergency power requirements.
EcoFlow’s Top Home Generators for a Power Outage 2024
  1. Best for Whole-Home Backup: DELTA Pro Solar Generator (PV400W)
  2. Best for Overnight Power Outages: DELTA 2 Max Solar Generator (PV220W)
  3. Best for Shorter Power Outages: DELTA 2 Solar Generator (PV220W)
When it comes to securing your home against outages, the EcoFlow DELTA Pro Solar Generator is an incredible choice. Its innovative design offers a seamless blend of power, versatility, and sustainability, making it ideal for whole-home backup.
The DELTA Pro features fast charging capabilities, and the high conversion on the EcoFlow 400W Portable Solar Panel offers excellent recharge times. Coupled with its long-lasting LFP battery, offering 6,500 cycles before reaching 50% capacity, you’re looking at years of dependable use.
This generator is more than just a backup power source or even peace of mind; it’s a major step towards sustainable living. Its ability to harness solar energy has the potential to reduce reliance on the grid, lower energy bills, and minimize your carbon footprint. With the DELTA Pro, you’re not just choosing a backup generator; you’re investing in a smarter, cleaner, and more resilient home.
Portable Power Station Specifications
  • Storage Capacity: 3.6kWh (Expandable to 25kWh)
  • AC Output: 3600W (Surge 7200W)
  • Solar Input: 1600W Max
  • Cycle Life: 3,500 cycles to 80% capacity, 6,500 cycles to 50% capacity
  • Battery Type: LFP (LiFePO4)
  • Dimensions: 25 × 11.2 × 16.4 in (63.5 × 28.4 × 42cm)
  • Weight: 99 lbs (45kg)
  • App: Yes
Solar Panel Specifications
  • Rated Power: 400W
  • Efficiency: 23%
  • Cell Type: Monocrystalline
  • Construction: Portable
  • Waterproof Rating: IP68
  • Dimensions: 42.0 × 94.1 × 1.0 in (106.8 × 239.0 × 2.4 cm)
  • Net Weight: 35 lbs 16kg (16kg)/Approx. 41.9 lbs (19.0kg) with Kickstand Case
Pros
  • Versatile Capacity: Capacity expandable up to 25kWh, suitable for whole-home backup.
  • Rapid Charging: Offers fast charging speeds.
  • Reduces Grid Reliance: Solar integration reduces reliance on the grid.
Cons
  • Size and Weight: It may be bulky for casual, light-use scenarios.
The EcoFlow DELTA 2 Max Solar Generator is an excellent option for handling overnight outages, offering assurance with its robust capacity and versatility. Ideal for running your essentials for hours, this solar generator provides a reliable backup power source.
One of the key benefits of the DELTA 2 Max is its rapid rechargeability, making it a reliable asset during outages. Its compatibility with solar charging aligns with sustainable energy practices, offering an eco-friendly backup option.
The DELTA 2 Max Solar Generator stands out as a versatile, green, and reliable power solution for any household looking for reliable overnight power during an outage.
Portable Power Specifications
  • Storage Capacity: 2048 Wh (Expandable to 6kWh)
  • AC Output: 2400W (Surge 4800W)
  • Solar Input/Charging: 1,000W (Max)
  • Cycle Life: 3000 cycles to 80%+ Capacity
  • Dimensions: 19.6 × 9.5 × 12 in (497 × 242 × 305 mm)
  • Weight: 50 lbs (23kg)
  • App: Yes
  • Rated Power: 220W
  • Efficiency: 22-23%
  • Dimensions: 32.3 × 72.0 × 1.0 in (82 × 183 × 2.5 cm)
  • Net Weight: Approx. 20.9 lbs (around 9.5 kg)
Pros
  • Expandable Capacity: Can add additional capacity to meet your energy storage needs.
  • Fast Charging: Features fast recharge capabilities.
  • Versatile Use: Powers a wide range of appliances efficiently.
Cons
  • Heavier Build: Less portable than smaller models.
The EcoFlow DELTA 2 Solar Generator is the perfect solution for handling shorter power outages. This generator can power over 90% of household appliances, from microwaves to fridges, even during blackouts.
Its bifacial solar panel design enhances solar charging efficiency, offering up to 23% conversion and fast charging speeds, fully recharging in 6 hours with one set. This feature particularly benefits those who prefer an eco-friendly approach without compromising speed and efficiency.
Embrace sustainability and reliability with the DELTA 2 Solar Generator, a smart choice for shorter power outages, ensuring comfort and security in your home.
  • Storage Capacity: 2048Wh
  • AC Output: 6 outlets, 1800W total (Surge 2700W)
  • Solar Input/Charging: 11-60V, 15A, 500W max
  • Cycle Life: 3000 cycles to 80+% capacity
  • Dimensions:  15.7 x 8.3 x 11 in  (400 x 211 x 281 mm)
  • Weight: 27 lbs  (12 kg)
  • App: Yes
  • Rated Power: 220W
Pros
  • High Efficiency: Fast solar charging with a high conversion rate.
  • Versatile Use: It powers 90% of home appliances.
  • Eco-Friendly: Supports sustainable energy use with solar panel integration.
Cons
  • More Limited to Shorter Outages: Best suited for brief power disruptions, not long-term emergencies.
What to Consider When Choosing the Best Home Generator for Power Outages
Below are a few factors you should consider when choosing your ideal home generator for power outages:
Capacity and Power Output
Consider the generator’s storage capacity and output capabilities. These specs impact how many devices you can power and for how long, especially during prolonged outages.
Charging Speed
Look for generators with fast charging capabilities. Quick recharge times mean less downtime and more consistent power availability.
Portability and Size
Portability is crucial, especially if you plan to use the generator for other activities, like camping or using power tools, in addition to home backup.
Durability and Weather Resistance
Ensure your generator is durable and can withstand various weather conditions, especially if you plan to use it outdoors or in emergency situations.
Ease of Use and Connectivity
Consider generators that are easy to set up and have user-friendly interfaces and smart connectivity options. They also offer greater convenience and control over power management.
What Are the Benefits of Adding a Solar Generator to My Home for Power Outages?
Getting a solar generator offers not just reliable power backup during outages but also an environmentally friendly energy solution. Here are some of the key benefits:
  • Eco-Friendly Energy Source: Solar generators harness renewable solar energy, reducing reliance on fossil fuels. Using solar energy instead of traditional energy sources not only minimizes your carbon footprint but also contributes to a cleaner environment.
  • Cost-Effective in the Long Run: While the initial investment may be higher, solar generators can yield significant savings. By generating your own electricity from sunlight, you can cut down on electricity costs.
  • Quiet Operation: Solar generators operate quietly. This makes them ideal for residential areas.
  • Reliable Power Supply During Emergencies: A reliable backup power source is a game changer. The right solar generator can provide crucial backup power during outages, ensuring that essential appliances stay operational.
  • Independence from the Grid: By generating your own electricity and storing it in a solar battery, you can become less dependent on the power grid. This decreased dependency is especially beneficial in areas prone to frequent or prolonged power outages.
  • Safe to Use Indoors: Solar generators don’t emit harmful gases and can safely be used indoors. This fact distinguishes solar generators from gas generators, which pose risks of carbon monoxide poisoning if used improperly.
What Is the Best Home Generator for Power Outages?
The best home generator for power outages is one that aligns with your specific energy needs and home setup. For comprehensive whole-home backup, opt for solar generators with a large storage capacity, high electricity output, rapid charging, and the option to expand.
Looking for the Best Home Generator for Power Outages? Shop EcoFlow!
We’ve explored our top home solar generators for power outages in 2024, each tailored to different needs. From the robust DELTA Pro for whole-home backup to the versatile DELTA 2 for shorter outages, we have reliable, eco-friendly solutions that will transform electricity usage in your home and keep you out of the dark.
Ready to secure your home against power outages? Explore our range for the perfect fit and embrace uninterrupted power anytime. Shop EcoFlow today for cutting-edge power solutions.
