Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
Is It OK to Have a Mini Fridge in the Bedroom?
Having a mini fridge right in the comfort of your room is a luxury like no other. If you’re ready to make this exciting addition, there are some things you should consider before diving in.
To help you make an informed decision, we’ve created an informative guide outlining some important things you should know before installing your mini fridge.
Are Mini Fridges Safe in Bedrooms?
Generally, having a mini fridge in your bedroom is perfectly safe with the correct precautions. Here’s a list of what to consider:
Potential Hazards
The most important thing you must consider for your safety is where this item will be plugged in. You should always use a dedicated outlet that can withstand the power required by the fridge. Avoid using extension cords or power strips, and you should be in the clear.
Impact on Sleep Quality
If you’re a light sleeper, you may want to consider this warning. Mini fridges, while generally quiet, still make a certain noise that could keep you awake. Others may find the white noise peaceful, but it is worth considering before purchasing your own mini fridge.
Ventilation
Like traditional fridges, mini fridges need space for ventilation. While they usually only require a few inches of room for airflow, this is very important and can help avoid other safety concerns down the line.
Why You Shouldn’t Have a Mini Fridge in Your Bedroom?
While there are plenty of reasons to have a mini fridge in your room, some may argue against keeping one out. Here are the main cons you should consider before adding one.
Noise Levels
Installing a mini fridge or freezer in your space may not be the best for those who enjoy a quiet night of sleep. While small, these fridges can make a steady noise when the compressor comes on and have been known to keep up some light sleepers.
You’re in luck if you’re a light sleeper but have your heart set on adding a mini fridge to your room. The EcoFlow Glacier Portable Refrigerator is a great model that operates quietly, especially when on Eco Mode. It’s a great alternative option to traditional mini-fridges and can help to reduce unnecessary noise in your room during sleeping hours.
Increase in Temperature
Since these items need room to ventilate, they kick off a certain level of heat that may be noticeable in a smaller room. Luckily, the EcoFlow Wave 2 Portable AC can quickly help cool off the space, so you can keep the mini fridge where you like.
Increased Energy Consumption
Once you’ve installed your mini fridge, you may notice a spike in your energy bill. These machines do require more energy than the average appliance, though there are workarounds to lessen the blow to your energy consumption.
The EcoFlow RIVER 2 Pro is a great addition that can supply power to these machines without increasing your monthly bills.
How to Safely Keep a Mini Fridge in Your Bedroom
If you’re committed to adding a mini fridge to your room, here are some safety tips to remember after it arrives.
Proper Placement
You should always find a designated spot for your mini fridge that’s separate from other items in your room. Keep things away from the plug and outlet, and avoid placing too many items on top. These fridges need room to “breathe” as they can overheat when overcrowded by other items.
If you’re living in a camper van out on the open road, you can add a mini fridge to your living space, as well. The EcoFlow DELTA Pro Solar Generator (Portable PV400W) is easy to set up and is great for life on the go. This power source is safe to use on mini-fridges, meaning you can set it up wherever you travel.
Regular Maintenance
As with any machinery, regular maintenance will keep it running safely and soundly for many years to come. Without proper maintenance, these machines can run their course quickly and may lead to spoiled food and drink items. Service them often and schedule repair visits from a local professional if needed.
Distance From Bed
As a general safety tip, no type of machinery should be too close to your bed. These items can overheat if they aren’t sufficiently ventilated, making them a potential electrical or fire hazard. The best practice is always to take the time to move things around and give plenty of space between your bed and the fridge.
Can I Sleep Next to a Mini Fridge?
You can sleep with a mini fridge in your room, though you shouldn’t sleep directly next to one. These pieces of machinery, though small, generate heat and may make for uncomfortable sleeping quarters. You should also allow plenty of room for ventilation and keep the cords and outlet clear of clutter.
Having a mini fridge in your bedroom is an excellent addition for some, though it may not be for everyone. Following these tips will help you better understand your options and see if this is the right purchase for you.
If you’re ready to buy your very own mini fridge, EcoFlow’s Glacier Portable Refrigerator is the perfect option. Lightweight and solar-powered, the EcoFlow Glacier also acts as an icemaker, keeping food and drink cool 24/7.
Image 0
Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
