Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
Petrol and Diesel Generators vs Portable Power Station: What to Get?
A portable generator or portable power station — aren’t they the same thing? Hardly.
From power intake, charge capabilities, weight, noise, environmental impact, and more, there’s a world of difference between the two powerhouses, and they aren’t equally suitable for all people.
You might live in your RV and need power on the go. You might want to charge and power your devices while freeing yourself from reliance on the grid or fuel. Or, you might want a backup generator for your home in case of a blackout or extreme weather conditions.
In the following guide, you’ll learn the differences between portable power stations and petrol and diesel generators and which is the best option for you.
What Is a Petrol or Diesel Generator?
Portable generators typically run on fossil fuels — usually petrol, diesel or propane. When you feed them fuel, they can convert it into electric energy. Some generators have an internal steam turbine or diesel engine that you can power by water flow in addition to fuel combustion.
A standard petrol and diesel generator has an inverter to convert the fuel into electric energy. The capacity generated can range from 1000 to 20,000 watts. One big downside of petrol and diesel generators is that sometimes the charge is too strong for small appliances and devices. If you plug them in, they may short-circuit or blow a fuse.
But if it’s large-scale capacity you’re looking for, a petrol and diesel generator can light up an RV, a whole home, and many large appliances on a campsite. Some of the larger portable petrol and diesel generators can supply a capacity of up to 8500 watts
The main downside to this much power? They can weigh as much as 250 pounds (113 kg), which pushes the envelope on portability.
What Is a Portable Power Station?
While portable power stations (PPS) don’t generate electricity, they can store significant power in a battery and power many devices and systems. With EcoFlow Portable Power Stations, you have the option to attach solar panels, turning your PPS into a solar generator.
Solar energy is currently the best alternative to petrol, diesel, oil, and coal. Research has shown that solar is better for the environment than all forms of fossil fuel. After your initial investment in a solar generator, collecting power is virtually cost-free, and solar panels capture the sun’s energy very quickly. The market for solar is currently growing at an exponential rate.
If you don’t add solar panels to your PPS to generate power, it essentially functions as a giant battery. A PPS typically recharges by plugging into a wall outlet or car adaptor. Depending on the size and battery technology, how much energy a PPS can store will vary. When the power is depleted, you can plug the PPS into an AC outlet, car adaptor, or solar panel to recharge.
A small PPS can easily charge your personal electronic devices, and larger-capacity units can supply a complete home backup or off-grid power solution.
Two of the most significant advantages of portable power stations are that they don’t produce disruptive noise or toxic emissions. With a PPS, you get clean and silent power.
EcoFlow River 2 — Power in a Portable, Compact Frame
The EcoFlow River 2 Portable Power Station is the solution if you value portability without compromising power. With 256Wh capacity, it’s the perfect grab-and-go solution when you need to charge devices while camping or adventuring.
The River 2 can charge several devices at once, and recharge to full capacity in one hour! Plus, with multiple recharge options, including outlets, car adaptors, and solar panels (sold separately), you can free yourself from the grid without giving up charging capabilities.
EcoFlow DELTA Pro—Power Your Life
If you want all the power of a petrol or diesel generator without the fumes, treat yourself to the DELTA Pro Portable Power Station. With a starting capacity of 3600Wh that you can crank up to 25,000Wh with additional Smart Batteries, it supplies enough juice to power your life.
Given the capacity it supplies, the DELTA Pro remains surprisingly compact and portable, weighing less than 100lbs (45kg). With expandable capacity, home integration, remote app control, and a full charge time of just 1.8 hours from an AC outlet, it’s easy to see why the DELTA Pro is the PPS of choice for homeowners, RV drivers, campers, and professionals.
Oh, and did we mention it’s noise and fume-free?
What Are the Main Differences Between Petrol or Diesel Generators and Portable Power Stations?
Though they can look similar and accomplish the same goal, petrol and diesel generators and portable power stations couldn’t be more different.
Power Generation
Where petrol and diesel generators produce electricity, PPS units can only store it. Petrol and diesel generators have a real leg up here.
That said, portable power stations like the River 2 and DELTA series from EcoFlow are compatible with solar panels. Attach a couple of photovoltaic panels, and you’ll have a solar generator; no fuel required.
Power Output
Portable stations lose out here to petrol and diesel generators. While they can store a significant amount of energy, they don’t quite compare with petrol and diesel generators for capacity. Petrol and diesel generators can produce up to two times as much power as portable stations.
However, technology from EcoFlow is changing that, supplying users with high-capacity PPS units. No more need to let petrol and diesel generators bully your PPS out of the ring — they can go head to head.
Portability
Some petrol and diesel generators can be as tall as 8 ft (2.5m) and as wide as 15 ft (4.5m) — the only thing “portable” about them is that they come docked on carts with wheels.
With EcoFlow portable power stations, what you get is all in the name. The portability means that even the most robust PPS units like the DELTA Pro are still easy to grab using the carry handle and move to your campsite, room, or wherever you need clean, reliable power.
Runtime
Since petrol and diesel generators run on fossil fuel, they will keep running as long as you keep up the supply and maintenance — and those costs add up quickly.
Portable power stations rely on the battery’s lifespan. However, 6500 battery cycles add up to quite a few years of runtime for any single device.
Maintenance
Fuel combustion engines are complicated beasts prone to misfire and malfunction. Portable power stations, on the other hand, are as hassle-free as it gets — plug them in, charge them up, and they work, no maintenance necessary.
Noise
There’s no contest here. Petrol and diesel generators are loud, whirling, disruptive things. Portable power stations are virtually silent and run smoothly.
Greenhouse Gases and Carbon Monoxide Emissions
Petrol and diesel generators are notorious for noxious exhaust and emissions. Portable power stations are clean, and with the solar hookup, they provide clean, renewable energy that helps reduce your carbon footprint.
There’s also no contest between the two.
Fire Hazard
Again, petrol and diesel generators get low marks here. Fuel combustion engines light fuel on fire and harness the power of the mini-explosion to produce electricity. They’re safe for the most part, but fire is far more likely to break out when using a petrol or diesel generator, not a PPS.
Which One Should You Get?
Choosing between petrol and diesel generators and portable power stations can be challenging. The former offers greater overall capacity, and the latter is clean, quiet, and efficient. If there only were a way to combine the best of both worlds.
The New EcoFlow Smart Generator links the EcoFlow DELTA Pro or Max portable power station to a dual fuel generator, meaning you have a propane or petrol-powered backup if solar or another charging method is temporarily unavailable.
Power at Your Fingertips
Don’t get caught in a storm, blackout, or off-grid without a backup plan. With an EcoFlow Portable Power Station, you can ensure clean, reliable power for all your electricity needs.
Image 0
Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
