Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
3 Best Solar Products for Homes in the UK for 2025
As energy costs continue to rise and sustainability becomes a priority, solar power is increasingly becoming the go-to solution for UK households. We can supply our homes with basic backup power, whole-home backup solutions, or complete off-grid capabilities with solar panels (photovoltaics) and batteries, even for large homes with high power needs.
Whether you’re preparing for power outages, reducing your energy bills, or looking for off-grid solutions, we have the 3 best solar products for 2025 to meet your household energy needs. Let’s dive in.
EcoFlow’s Best Solar Products for Homes
  1. Best for Basic Home Backup: EcoFlow DELTA 2 Max + 220W Solar Panel
  2. Best Affordable, Whole Home Backup: EcoFlow DELTA Pro + 400W Solar Panel
  3. Best for Maximizing Solar Generation and Power Output: EcoFlow DELTA Pro 3 + 400W Solar Panel
This model is the perfect choice if you are looking for a basic home backup product to run your essential appliances during an outage. Without fossil fuels, they can be brought indoors since there is no need to worry about lethal carbon monoxide poisoning. Its 2048Wh capacity and 3400W surge output means it will run virtually any household appliance.
You can keep your refrigerator running, run lights, recharge your electronic devices, and watch the telly at night. Even if you need to run a heater or an air conditioner, it can run those, too.
The nice thing about this model is that while it has a lot of capacity, it does not have so much that it makes it cumbersome to move around. You can move it from room to room or pack it in your shop or car for a road trip. The 220W bifacial photovoltaic panel is perfect for efficient recharging since it collects light from both sides of the panel.
It also makes an excellent generator for boats. It’s an especially great generator for fishing trips where you can run a GPS, fishfinder, lights, and a heater to stay warm on chilly mornings. It’s rugged and durable, and both the panel and the generator are IP68-rated as waterproof according to the International Electrotechnical Commission standards.
EcoFlow DELTA 2 Max Specifications
  • Storage Capacity (Minimum): 2048 Wh
  • Storage Capacity (Maximum): 6kWh
  • AC Output (Maximum): 2.4kW continuous output (3.4kW surge)
  • Solar Charge Capacity (Maximum): 11-60V 15A, single port 500W; dual port 1kW
  • Weight: 50.7 lbs  (23 kg)
  • Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options:  Solar/AC/Car Charger
  • Multicharge Options?  Yes
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Depth of Discharge: 100%
  • Warranty: Five years (no cycle life restrictions)
  • App Monitoring and Control?: Yes
EcoFlow 220W Solar Panel Specifications
  • Rated Power: 220W Front Side/155W Rear Side
  • Efficiency: 22 % – 23 %
  • Solar Cell Type: Monocrystalline
  • Weight: 20.9 lbs (9.5 KG)
  • Folded Dimensions: 32.3×19.7×1.3 in (82.0×50.0×3.2 cm)
  • Unfolded Dimensions: 32.3×72.2×1.0 in (82.0×183.5×2.5 cm)
  • Waterproof/Dustproof Rating: IP68
  • Open CircuitVoltage: 21.8V (Vmp 18.4V)
  • Short Circuit Current: 13A (lmp 12.0A) Front Side / 8.8 A (lmp 8.4A) Rear Side
  • Recommended Portable Power Station: EcoFlow RIVER 2 Pro/EcoFlow DELTA 2
Pros
  • Runs almost any household appliance
  • Compact enough to easily move around
  • Safe to use indoors or outdoors
  • Bifacial photovoltaic panel has a high conversion efficiency
  • Power station and panel are dustproof and waterproof
Cons
  • May not be able to run all dryers or air conditioners
  • Not enough power for a whole-home backup
If you want a whole-home backup, this model is the best generator for blackouts since it’s powerful enough to run any household appliance, including large air conditioners and dryers. For instance, you can expand its 3.6kWh output to 7.2kWh when you combine 2 units with a double voltage hub. So, no matter what you need to run, you will have plenty of power.
You also have options for how you use it. For instance, you can integrate it into your household electricity with the EcoFlow Smart Home Panel or simply plug in appliances as needed.  Its heavy-duty handles and wheels make moving from room to room easy. It’s also durable and waterproof for use on your outdoor adventures.
The 400W photovoltaic panel will recharge it with clean energy, and for heavier energy users, you can add 7 panels per unit for up to 16 panels. With its expandable storage capacity of up to 25kWh, you can convert it into a whole-home off-grid energy solution.
EcoFlow DELTA Pro Specifications
  • Storage Capacity (Minimum): 3.6kWh
  • Storage Capacity (Maximum): 25kWh
  • AC Output (Maximum): 3.6kW continuous output (7.2kW Surge)
  • AC Output (Maximum): Expandable to 7.2kW continuous output (14.4 kW surge) with 2 x EcoFlow DELTA Pro + Double Voltage Hub
  • Solar Charge Capacity (Maximum): 3.2kW with 2 x EcoFlow DELTA Pro (16 x 400W Rigid Solar Panels)
  • Weight: 99 lbs (45kg)
  • Dimensions: 25 x 11.2” x 16.4” inches (63.5 x 28.4x 42cm)
  • Charging Options: Solar/AC/Car Charger/Smart Home Panel/EV Charge Station/Smart Generator (Dual Fuel)
EcoFlow 400W Solar Panel Specifications
  • Rated Power: 400W
  • Efficiency: 22.6 %
  • Weight: 35.3 lbs (16.0 KG)
  • Folded Dimensions: 41.7×24.4×1.0 in (105.8×62.0×2.5 cm)
  • Unfolded Dimensions: 41.7×93,1×1.0 in (105.8×236.5×2.5 cm)
  • Open CircuitVoltage: 48V (Vmp 41V)
  • Short Circuit Current: 11A (lmp 9.8 A)
  • Recommended Portable Power Station: EcoFlow DELTA Series
Pros
  • Powerful battery will run any household appliance
  • Output can be increased for heavy power usage
  • Capacity can be increased to 25kWh
  • Can be expanded to use as a complete off-grid solution for most homes
Cons
  • Heavier than lower capacity models
  • More expensive than lower capacity models
For those with large homes or businesses, shops, or other power needs in addition to your home, you will want to maximise your power generation and output. This model has a minimum capacity of 4kWh, but you can expand your storage to 36kWh with extra batteries.
If you add the EcoFlow Smart Generator 4000 (Dual Fuel), you can get a maximum storage of 48kWh! The output starts at 4kW; with the X-boost, you can get 6kW. If you need even more output, chain 3 units together to get 12kW.
With all that power output, you will want lots of input. While it comes with a 400W highly efficient photovoltaic panel, you can use dual charging to get a maximum 2600W photovoltaic charge when connecting enough panels. So you can easily top up your powerful batteries with clean energy from the sun.
EcoFlow DELTA Pro 3 Specifications
  • Storage Capacity (Minimum):4kWh per Battery. Up to 3 Batteries per DP3 (12kWh)
  • Storage Capacity (Maximum):36kWh
  • (Battery Storage) + 12kWh with a full Smart Generator 4000 (Dual Fuel) = 48kWh
  • AC Output (Minimum): 4kW (6kW X-Boost/8kW Surge) (120/240V)
  • AC Output (Maximum): Expandable to 8kW or 12kW by chaining 2 or 3 x DELTA Pro 3
  • Solar Charge Capacity (Maximum): 2600W Dual-PV Charging (150V) per DP3
  • Weight: 115 lbs (52kg)
  • Dimensions: 27.5 × 13.5 × 16 in (69.5 × 34 × 41 cm)
  • Operating Noise Level: 35 decibels
  • Charging Options: Smart Home Panel 2 (7200W) / AC (3600W) / Dual Solar Input (2600W) / EV Charging (4000W) / Gas Generator (3200W) / Alternator Charging / Car Adapter Charging
  • Multi-Charge Options? Yes – 18 Options
  • Cycle Life: 4000 Cycles to +/-80% Capacity (11+ years of regular use)
  • App Monitoring and Control? Yes
  • Rated Power: 400W
Pros
  • Its already high storage capacity is expandable up to 48KWh to run even the largest homes for backup or as a complete off-grid solution
  • Energy output can be expanded to 12kW when chaining three units together to power even the most heavy-duty appliances
  • Dual photovoltaic charging allows for fast recharge
Cons
  • High capacity makes it heavier and less portable, although it does come with wheels and a sturdy handle to move it easily
What Makes a Good Home Solar Product?
What makes a good home photovoltaic product depends on how you need to use it. If you just want to supplement your daily energy supply, photovoltaic panels alone might be enough, but you won’t be able to use them at night.
If you want to live off-grid, avoid those peak electricity hours when your electrical company charges you the most, or if you want energy during electrical outages, you need photovoltaic batteries to go with those panels so you can store your power.
Here are some additional factors to consider.
Capacity is easily the most important factor for home use. How much capacity you need depends on how much energy you use and how you want to use it. If you want a backup solution for essential appliances, a whole home backup, or a complete off-grid solution, these all require different capacities.
Durability
Durability is also essential. Your panels and power station should be well-built, sturdy, and have good dust and waterproof ratings for use indoors or outdoors.
Efficiency
Not all photovoltaic panels are created equal. Most have conversion efficiencies between 16-22%. With all the affordable, highly efficient EcoFlow photovoltaic panels generating 22% or more, you don’t want to buy anything with a lower efficiency rating because you would need more panels to create the same amount of electricity.
Warranties
People often overlook warranties when shopping for a bargain, but buying cheap products from an obscure manufacturer with limited warranties means they don’t stand by their products. Your system should have a 5-year warranty with no restrictions.
When it comes to solar solutions for UK homes, EcoFlow delivers exceptional performance, durability, and flexibility. Whether you’re looking for a reliable backup power source, an affordable whole-home backup solution, or maximising your power generation and output with the EcoFlow DELTA Pro 3, there’s a generator to meet every need.
Invest in clean energy, reduce reliance on the grid, and ensure you’re always powered up no matter what life brings.
Image 0
Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
