Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
Best EcoFlow Black Friday Deals
EcoFlow’s Black Friday deals are here, and we’re offering some incredible discounts on everything from solar panels to portable power stations to solar generators.
At EcoFlow, we offer a comprehensive range of off-grid power solutions.
It doesn’t matter if you’re looking for whole-home backup power to protect against blackouts or on-the-go electricity for your next outdoor adventure. There’s a Black Friday bargain for you.
Check out what we’ve got in store for you.
Best Black Friday Deals for Solar Panels
400W Portable Solar Panel
At 400W, this solar panel offers the highest rated power output EcoFlow offers, yet it’s still portable enough to take on your next camping trip.
Boasting an impressive 23% efficiency rating and IP68 waterproofing, you can trust this panel to generate reliable power conveniently wherever you go.
Pros
  • Has a carrying case doubling as a supporting stand
  • Ideal for on-the-go adventures for those needing to generate more power
  • 23% conversion rate offers effective electricity generation
  • Can be a bit bulky for hiking or extended walking trips
Cons
  •  More expensive than other portable options
110W Portable Solar Panel
EcoFlow’s 110W Portable Solar Panel is a lightweight and portable solar panel option, ideal for those looking for a companion for their RIVER 2 when backpacking or hiking. Its one-piece folding design and IP68 waterproof rating make it a great option to bring along on all your adventures.
Pros
  • Lightweight and portable
  • IP68 waterproof rating
Cons
  •  Not well suited for powering high-wattage appliances
160W Portable Solar Panel
The 160W Portable Solar Panel is an excellent addition to your next weekend camping or car camping trip. Its foldable design makes it easy to pack up and move to the next destination, and its case doubles as a stand that makes it effortless to adjust for the best solar charging angle.
Pros
  • Can withstand almost all environments
  • Convenient case doubles as a stand
Cons
  • Requires significant peak sunlight for extended trips
220W Bifacial Portable Solar Panel
This solar panel’s unique two-in-one bifacial design allows you to capture up to 25% more solar energy, giving you even faster charging times for your portable power station
With durable tempered glass, you can trust that the 220W Bifacial Solar Panel is built to last.
Pros
  •  Collect up to 25% more solar energy than single-sided panels
  • Saves space as it’s 10% smaller than comparable 220W panels
  • Maximises electricity generation from available sunlight
Cons
  • More expensive than other options
Best Black Friday Deals for Portable Power Stations
DELTA Pro
The DELTA Pro is EcoFlow’s flagship portable power station, offering an impressive 3600Wh storage capacity that can be expanded all the way up to 25kWh.
You can run multiple high-wattage home appliances simultaneously with its impressive 3600W (7200W Surge) AC output. DELTA Pro gives you home backup power or a whole-house solar generator that provides off-grid electricity for extended outages. With 1600W of solar charging input, you can generate clean, renewable solar energy indefinitely.
Pros
  • Expandable up to 25kWh of storage
  • Lasts 10 years or more with innovative LiFePO4 electricity storage
  • Impressive 3600W AC output (7200W surge).
  • Can power up to 4500W of high-wattage appliances simultaneously with X-Boost
Cons
  • Most costly EcoFlow portable power station
  • At 50kg, portability is limited
DELTA 2
With 1800W AC output, the DELTA 2 is a great entry-level home backup solution that powers over 90% of home appliances.
Looking for something to keep you powered on extended road trips with the family? The DELTA 2’s got you covered there too. With an expandable capacity, the DELTA 2 can grow with you if you need more power.
Pros
  • Expandable capacity
  • Works for entry-level backup
  • Powers over 90% of home appliances
Cons
  • May require extra batter expansion for high electricity storage applications
Best Black Friday Deals for Solar Generators
River 2 + 110W Portable Solar Panel
Want to keep your personal devices powered on your next backpacking or hiking trip?
The RIVER 2 + 110W Portable Solar Panel has got you covered. This solar generator is extremely lightweight and compact, and the 110W solar panel provides an impressive 23% conversion for faster solar charging.
Pros
  •  Ultra-portable option, ideal for backpacking or hiking
  • Great for keeping personal devices powered
Cons
  • Not suited for high-wattage appliances
Best Black Friday Deals for Camping
RIVER 2 Pro
The RIVER 2 Pro offers a notable 768Wh capacity paired with an 800W output that can increase to 1600W with X-Boost – allowing it to run 80% of high-wattage appliances.
It’s incredibly lightweight, features four ways to charge, and has a fast recharge time, making it an ideal companion on outdoor adventures.
Pros
  • Can run 80% of high-wattage appliances
  • Versatile charging options
  • Safe LFP battery offers 10+ years of use
Cons
  • Not suited for solar panels with rated power over 220W
RIVER 2 Max
Bring family camping trips and off-grid adventures to the next level with the RIVER 2 Max.
Power camping appliances like a cooktop or portable fridge. It’s an excellent option for those camping in place.
Pros
  • Fast recharge of 0-100% in just 60 minutes
  • Lightweight
  • Offers 1000W output with X-Boost
Cons
  • Storage is not expandable
Shop the Best Ecoflow Black Friday Deals Today!
Whether you need solar panels or a portable power station or want to bring your next camping trip to the next level, EcoFlow has what you’re looking for!
Take advantage of these fantastic Black Friday deals by purchasing your ideal power solution today.
Image 0
Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
