Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
4 Best Camping Power Banks
Camping in the great outdoors doesn’t mean you have to disconnect completely. Whether capturing memories on your smartphone, navigating with your GPS, keeping your campsite illuminated, or cooking delicious camp meals, the right camping power bank can keep your gadgets and appliances charged and ready.
Discover the top camping power banks from EcoFlow to stay connected no matter where the trail takes you.
EcoFlow’s Best Camping Power Banks
  1. Best For Portability: EcoFlow RIVER 2
  2. Best For Small Appliances: EcoFlow RIVER 2 Max
  3. Best For Car Camping: EcoFlow RIVER 2 Pro
  4. Best For Extended Trips: EcoFlow DELTA 2
Best for Portability: EcoFlow RIVER 2
The EcoFlow RIVER 2 is the adventurer’s dream for keeping devices powered on the go. The most compact option available, it’s designed to slip easily into your backpack and is light enough to carry on your back or in your hand for hiking or backpacking adventures. The EcoFlow RIVER 2 can power 99% of consumer devices, including phones, cameras, tablets, and camp lights, and ensure they never run out of juice during day trips or overnight escapes.
Its impressive charging speed means less time tethered to your power bank and more time exploring—it takes just 60 minutes for a full charge using AC power, so you can charge up while you pack for your trip. Or keep it eco-friendly with a 3-hour recharge when paired with 110W solar panels and lower. But your recharge options don’t stop there. You can also use DC power from your car if that’s more convenient while camping.
Ideal for the tech-savvy camper who prioritises efficiency and portability, the EcoFlow RIVER 2 has a simple plug-and-play setup so you can focus on the joys of camping. And, even if you need to charge it while you camp, you can still use it to power other devices while it charges.
With 2 AC plugs and multiple USB outlets, you can charge more than one device simultaneously. And don’t worry—you won’t overload it thanks to the BMS, which monitors voltage, current, and temperature to keep your camping safe.
EcoFlow RIVER 2 Portable Power Station | Grab & Go Power
Need to keep your phone and personal devices charged while hiking or camping? RIVER 2 weighs only 7.7 lbs (3.5kg), fits in your backpack, and powers 99% of consumer electronics. Plug in at home & charge 0-100% in 1 hour. Or recharge anywhere there’s sunshine with a portable solar panel. Why settle for a run-of-the-mill power bank?
Specifications
  • Storage Capacity: 256Wh
  • AC Output: 300W total (surge 600W)
  • Solar Charge Capacity (Maximum): 11-30V, 8A, 110W Max
  • Weight: 7.7 lbs (3.5 kg)
  • Dimensions: 9.6 x 8.5 x 5.7 in (245 x 214 x 142 mm)
  • Operating Noise Level: ~60 decibels
  • Charging Options: Solar/AC/Car/USB-C Charging
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Depth of Discharge: 100%
  • Warranty: 5 years
  • App Monitoring and Control?: Yes
Pros
  • Ultra-portable design for easy packing
  • Fast charging capabilities for quick power-ups with X-boost
  • Inexpensive power source
  • Simple set up
  • Eco-friendly recharge option with solar panels
Cons
  • Limited capacity for multiple charges of high-demand devices
  • Not for extended trips
The EcoFlow RIVER 2 Max specialises in powering 80% of essential appliances. It’s perfect for those looking to spice up their camp culinary experiences with a camping stove or keep cool with a portable fan or fridge. It’s ideal for off-grid trips or weekend camping, as it’s more powerful than the EcoFlow RIVER 2 but still compact and easy enough to carry to your campsite with its carry handle.
Take advantage of its 4 AC outlets plus USB ports and stay charged whether it’s just you or a whole group. Enjoy enough power to charge your smartphone 50 times or run a TV for 10 hours. This power bank pairs with EcoFlow 160W Portable Solar Panels and lower and can provide a full charge in just 3 hours. Alternatively, opt for a quicker route with complete AC charging in just an hour.
Look no further if you want reliability in your power source when camping. This model uses an LFP battery that lasts a decade or more, offering better performance and longevity than other power banks that use lithium-ion batteries. Plus, it has a 5-year warranty, so you’ll have peace of mind for longevity.
Investing in the EcoFlow RIVER 2 Max is an easy way to make camping more comfortable, offering versatile charging options and the ability to monitor and control your energy usage from anywhere with the ease of the EcoFlow smartphone app.
Specifications
  • Storage Capacity: 512Wh
  • AC Output: 500W (Surge 1000W)
  • Solar Charge Capacity (Maximum): 11-50V 13A, 220W Max
  • Weight: 13.4 lbs (6.1 kg)
  • Dimensions: 10.6 x 10.2 x 7.7 in (270 x 260 x 196mm)
  • Warranty: 5 years
Pros
  • Powers a variety of small appliances
  • Sufficient capacity for a weekend trip
  • Quick 1-hour recharge time back to full power, 5x faster than others in the industry
  • Good balance of portability and power
  • Durable design withstands outdoor use
Cons
  • Heavier and larger, less suited for backpacking
  • insufficient for high-powered appliances
For campers who bring the car along for the adventure, the EcoFlow RIVER 2 Pro is a powerhouse solution. It’s ideally suited for powering up to 80% of high-powered appliances, such as lights, projectors, portable heaters, electric kettles, and more. Take it on your next car camping trip or extended getaway, and keep your personal devices charged up for days. It’s also great if you do a lot of cooking at your campsite.
The EcoFlow RIVER 2 Pro is the most powerful of the EcoFlow RIVER 2 family, yet it’s still highly portable, coming in at just 17.2 lbs (7.8 kg). It can charge up entirely in just 70 minutes using AC power, or it can be paired with EcoFlow 220W Bifacial Portable Solar Panel and lower to enjoy a 3-hour recharge with solar. You can also use a car adapter or USB-C.
This power bank’s extensive battery life maintains 80% capacity even after 3000 cycles, ensuring you and your companions stay charged and comfortable throughout your trip.
Its variety of input options and versatility make it great for camping and use at home as backup power when needed. With an intuitive smartphone app, you can monitor and manage your usage anywhere.
Specifications
  • Storage Capacity: 768Wh
  • AC Output: 800W total (surge 1600W)
  • Weight: 17.2 lbs (7.8 kg )
  • Dimensions: 10.6 x 10.2 x 8.9 in (270 x 260 x 226 mm)
  • Warranty: 5 years
Pros
  • High capacity for extended usage
  • Supports larger appliances, adding luxury to camping
  • Multiple outlet options for various needs
  • Easy monitoring
  • Eco-conscious choice for energy needs when paired with solar panels
Cons
  • Bulkier, making it ideal for car camping rather than backpacking
  • Longer charge time than other EcoFlow RIVER 2 models
When your adventures call for an extended stay in the wilderness, the EcoFlow DELTA 2 is the ultimate power solution. Its medium-capacity off-grid power offers unparalleled power support for a wide range of devices and 90% of appliances over multiple days. Are you travelling with a group? It’s petite but not short on outlets. With 6 AC outlets and the ability to run up to 13 devices simultaneously, there’s enough energy to go around.
Looking for something that can grow with your energy needs? The EcoFlow DELTA 2 offers expandable storage capacity, allowing you to add capacity and even double it when you pair it with an EcoFlow DELTA 2 Smart Extra Battery or EcoFlow DELTA Max Extra Battery.
If you need to recharge this power bank while you camp, it’s quick and easy. Use AC power to charge it up to 80% in 50 minutes, or leave it plugged in for 80 minutes and enjoy a full charge. You can also use solar power, using EcoFlow 400W Portable Solar Panels or lower to get a 3-6 hour charge.
Power all your camping favourites, like toasters, food processors, portable AC and heaters, fridges, microwaves, and more! While you’re out in nature, use it to charge a phone 89 times, run a camp light for 31 hours, or use an electric grill for a full hour. This versatility also makes it great as a home backup, too.
An upgrade from the previous EcoFlow DELTA Series, the EcoFlow DELTA 2 is more compact than its predecessor at 27 lbs (12 kg), and thanks to its durable LiFePO4 battery, it lasts 6x longer than competitors.
Monitoring features make it easy to stay safe. If you have internet at your campsite, you can monitor energy usage with the EcoFlow smartphone app. Plus, a built-in battery management system does the hard work of keeping your battery safe and preventing overloading.
Specifications
  • Storage Capacity (Minimum): 1024Wh
  • Storage Capacity (Maximum): 3kWh
  • AC Output (Maximum): 1.8kW continuous output (2.7kW Surge)
  • Solar Charge Capacity (Maximum): 500W max (11-60V, 15A)
  • Weight: 27 lbs (12 kg)
  • Dimensions: 15.7 x 8.3 x 11.1 in (40 x 21.1 x 28.1 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options: Solar/AC/Car Charger
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Warranty: Five years (no cycle life restrictions)
Pros
  • Exceptionally high power capacity for long trips and bigger groups
  • Expandable gives your energy needs room to grow
  • Versatile charging options support numerous devices
  • Fast charging for time efficiency
Cons
  • Size and weight may limit portability for some campers
  • Solar panels not included
What To Consider Before Choosing a Power Bank for Camping
Before investing in a camping power bank, consider everything from capacity and portability to outlet and recharge options to find the battery option most suited to you.
Understand how much power you’ll need to support your devices and how long. For long trips, a high-capacity power bank like the EcoFlow RIVER 2 Pro is essential, whereas, for shorter trips, a smaller power bank such as the EcoFlow RIVER 2 may suffice.
Portability
Consider the weight and size of the power bank for your specific camping needs. Are you setting up camp in one place or trekking all over to maximise exposure to the wilderness? If you plan to hike or backpack, a lightweight and compact option would be more suitable. On the other hand, a stationary campsite can handle a slightly heavier or bulkier power bank with greater capacity and output.
Durability
When you’re outdoors, your power bank is too. Look for sturdy construction to withstand outdoor conditions like rain, wind, snow, and extreme temperatures. Consider the battery life and how long it will last before needing to be replaced. The good news? All EcoFlow Portable Power Stations use durable LFP batteries that can withstand the elements and last for years, even after thousands of cycles.
Outlet Options
Consider what devices you plan to power and ensure the power bank has enough outlets for your needs. Is it just you, or are you camping with a group of people who will also have their own devices? If you have larger or more appliances/devices, ensure the power bank supports them.
Recharge Options
Consider how easily and quickly you can recharge the power bank while camping. Solar panels are an excellent option for extended trips or when you want to keep things eco-friendly. You may also want to look for options with multiple recharge methods, such as AC power, car DC power, or USB-C.
How Do I Choose a Power Bank for Camping?
When choosing a camping power bank, assess your power needs, the duration of your trips, and the types of devices you’ll be charging. Then, filter your search by power banks with the specs that meet your requirements. Opt for portability if you’re on foot, but choose a larger capacity for base camps and car camping.
How Big of a Power Bank Do I Need for Camping?
This depends on the number of devices you carry, their power demands, and the length of your camping trip. Always plan for more capacity than you think you’ll need, and consider options like solar panels for quick re-charges within your camping trip so you’ll never run out.
What Is the Best Power Bank To Take Camping?
The best power bank for camping meets your power needs, type of camping, durability requirements, and recharge accessibility. The EcoFlow RIVER 2 is perfect for quick trips and personal devices, while something more robust, like the EcoFlow RIVER 2 Pro or EcoFlow DELTA 2, can offer more output and capacity for longer trips or more intensive appliances.
EcoFlow offers several innovative solutions to bring power and modernity to outdoor escapes, such as the compact EcoFlow RIVER 2 for shorter camping trips and the mighty EcoFlow DELTA 2 for extended adventures. When shopping for a camping power bank, match your buying choice to your unique camping style and energy requirements.
Whether you’re a solo explorer needing to keep your devices charged or a group seeking to power a full campsite setup, EcoFlow’s range of portable power stations offers everyone reliability, efficiency, and convenience.
Ready to elevate your camping experience with reliable, durable, and eco-friendly power? Explore EcoFlow’s portable power stations today and find the perfect match for your next camping trip.
Image 0
Image 0
Image 1
Image 2
Image 3
Image 4
Image 5
