Electricity bills are a major monthly cost for homeowners, so paying close attention to any significant changes in your monthly energy costs is essential. If you’ve recently noticed a spike in your electricity bill, you’re not alone.
Understanding the reasons behind high electric bills can help you reduce your household’s energy consumption and cut costs. If you’re an energy saver or want to spend less each month on electricity, here’s what to know about a high electric bill and how to save money.
What Are the Common Causes of High Electric Bills?
High electric bills happen for several reasons. It could be as simple as moving to a new place with higher electricity rates or as complex as global events impacting electricity prices at the source. If you can pinpoint what’s led to your increased electricity costs, you’ll be better equipped to tackle the issue and find ways to lower your bill.
1. Weather Changes
Extreme temperatures can significantly impact your electricity bill. During hot summers or cold winters, heating and cooling systems work harder to maintain indoor comfort, increasing energy usage. For example, if your AC system is set too low during the heat of the summer, it’ll use more energy to maintain this temperature than it would when the weather is cooler outside. In the same way, cold winter weather can make it more difficult to sufficiently heat a home, leading to more energy used and higher costs if you want to stay toasty indoors.
2. Changes in the Cost of Fuel
Fluctuations in fuel prices locally or around the world can change the cost of electricity. When the cost of fuel used to generate electricity rises, those increases are often passed on to consumers. Fuel from the electricity grid comes primarily from fossil fuels, which include natural gas, coal, and petroleum. If demand increases for these fuel sources, their cost can rise.
Similarly, if the supply of these fuel sources dwindles, they’ll become more expensive. Fuel costs can fluctuate for many reasons that are out of your control.
3. The Impact of Current Global or Nationwide Events
Global events such as economic shifts, natural disasters, or geopolitical tensions can influence prices. For instance, supply chain disruptions can lead to higher utility costs, which may be reflected in your bill.
Another example would be conflicts in major oil-producing countries, such as Saudi Arabia. Sanctions or volatile politics can make it harder to access these fuel sources, driving costs upward.
4. Increased Square Footage
If you’ve added space to your home or moved to a larger house, your energy needs will naturally increase, resulting in higher electric bills. The more house space you have to cool or heat, the more energy you’ll use.
5. Inefficient Appliances
Older appliances aren’t usually as energy-efficient as newer, modern models. Inefficient appliances consume more electricity, contributing to higher bills. Did you move somewhere new with different appliances and see your electricity costs spike? It could be because your current appliances don’t work as well as those you previously used.
Another factor is time. Appliances may be efficient at first, but general wear and tear can cause their efficiency to decrease. If you haven’t switched appliances but notice increasing electricity costs, consider investing in new Energy Star appliances designed to be more efficient.
6. More Residents
Increasing the number of people living in your home can lead to higher energy consumption, as more electricity is used for lighting, heating, cooling, and powering devices. While this might seem simple, it can significantly impact your monthly utility bill.
7. Electricity Rate Increases
Utility companies occasionally raise their rates to cover infrastructure upgrades, maintenance, or increased operational costs. Check with your provider to see if a rate hike might affect your bill. You can also expect electricity rates to rise if inflation rises, as electric companies must keep up with increasing costs.
8. Improper Insulation
Poor insulation in your attic or via gaps in windows and doors can cause your heating and cooling systems to work overtime, as your home loses conditioned air more quickly. The inefficiency increases energy consumption and drives up your bill.
9. Using Energy During Peak Hours
Did you know that electricity rates can vary depending on the time of day? Using energy-intensive appliances during peak hours, when demand is highest, can lead to higher costs. Check with your local utility company to learn about peak hours and when to use energy for lower rates.
10. High Water Heater Temperature
Your water heater uses a lot of energy that can impact your electric bill. If you set your water heater at a higher temperature than necessary, it will consume excess energy. Even if you’re not utilising your water supply at its hottest temperature, the water heater works to maintain this temperature in its chamber, and this guzzles electricity.
Lowering the temperature setting can reduce your electricity usage.
Ways to Potentially Save Money on Your Electricity Bill
Ready to see your energy bill total go down? Try these tactics to minimise your use or optimise your home to be more efficient.
Find a New Energy Supplier
Comparing rates from different energy suppliers can help you find a more cost-effective option. Switching suppliers might give you access to lower rates and better plans suited to your energy needs.
Opt for Fixed Energy Rates
Fixed-rate plans provide stability by locking in a consistent electricity rate. This can protect you from seasonal price fluctuations and sudden rate increases. If fixed rates are available, consider switching to this cost model.
Use a Smart Thermostat
Smart thermostats optimise your home’s temperature settings based on your schedule and preferences. Their ability to adjust heating and cooling automatically is one way to save on electricity bills.
Minimise Energy Use
Creating new, simple habits can make a big difference in reducing electricity consumption. Always turn off lights when not using them, unplug devices when you leave or are done using them, and opt for energy-efficient bulbs. If you can get the whole family on board, little changes can lead to big savings.
Upgrade Appliances and Insulation
Investing in energy-efficient appliances and improving your home’s insulation can lead to long-term savings. Look for ENERGY STAR-rated appliances and consider adding insulation to your walls or your attic to reduce further heat loss.
Use Solar Energy
If you don’t want to change your energy habits or make any renovations or updates to your home or appliances, solar power is an alternative that can provide you with free energy after an initial investment.
Harnessing solar power is one of the best ways to reduce your reliance on traditional electricity sources. Instead of relying on the grid for electricity at home, consider connecting some appliances (or your entire house) to a solar power system that can keep energy flowing by capturing sunlight.
For a permanent installation, consider pairing EcoFlow Solar Generators, such as the EcoFlow Delta Solar Generators, with EcoFlow Rigid Solar Panels, which can create an efficient home solar energy system. Such a setup cuts down your electricity bill and promotes sustainable living.
Knowing what’s causing high energy costs is the first step to lowering your bill for good. There are so many potential reasons for increasing electricity costs, so pinpointing the culprit for your specific issue may take some trial and error. But, once you figure it out, you’re on your way to fixing it by changing your energy use, home infrastructure, appliances, or energy source.
Solar energy provides free energy from the sun, giving you energy independence and allowing you to produce and use electricity without input from your utility company. Ready to see a change in your electric bill? Consider investing in EcoFlow’s solar generators to start your journey toward cost-effective energy solutions.
